Frag back in hospital
Discussion in 'UK Motorcycles' started by Adrienne M Jenn, Feb 23, 2004.
  1. Called in to Frags yesterday but he wasn't there. From text messages
    from him I gleaned the following:
    "in Milton Keynes hospital. Phoned 999 after muscles on bad leg all
    went into spasm. Fucking agony. Should get transferred to Oxford I
    hope."
    Fingers crossed that it gets sorted this time.
    Adie - capable of leading darsy astray
    Triumph T595 (for Sale) / GSF600 bandit
    MRO#11 BOTAFOF#7 BOTAFOT#130 DIAABTCOD#17 MIB#24 YTC#16 BOB#15 ex-UKRMMA#22
  2. Adrienne M Jenn
    Cane Guest
    Knowing his luck he'll get MRSA.
    Cane, Feb 23, 2004
  3. Adrienne M Jenn
    Ouch! The poor sod :eek:/
    Quite.
    CT, Feb 23, 2004
  4. Adrienne M Jenn
    He's been pumped full of morphine by MKGH staff who are "sneery and
    confused" in attitude and is still waiting for transport to Oxford.
    All this will address is the current acute problem, afaik. I have all
    my fingers firmly crossed for the old boy though.
    Pip, Feb 23, 2004
  5. Adrienne M Jenn
    'Hog Guest
    Or a large hairy Orderly with a curious medical/sexual fixation
    'Hog, Feb 23, 2004
  6. Adrienne M Jenn
    Spete Guest
    Tell him good luck.....
    Spete, Feb 23, 2004
  7. Adrienne M Jenn
    MattG Guest
    Halla wrote:
    And from me, if you'd be so kind.
    MattG, Feb 23, 2004
  8. Adrienne M Jenn
    Tim Guest
    ditto
    Tim two#21, YGL#3 & BOTAFOT#84
    Due to the limitations of current email, the lip movements may be
    out of synchronisation as you move your finger under the text while reading.
    tim dot ukrm2 at dsl dot pipex dot com
    Tim, Feb 23, 2004
  9. Adrienne M Jenn
    SteveH Guest
    Jesus, not again.
    Pass on our best wishes if you get to see him.
    SteveH, Feb 23, 2004
  10. Tim wrote
    aol
    steve auvache, Feb 23, 2004
  11. Adrienne M Jenn
    tallbloke Guest
    Awww Shit.
    Hope he is more comfortable now the meds are kicking in.
    tallbloke, Feb 23, 2004
  12. Adrienne M Jenn
    Alan.T.Gower Guest
    The poor sod, he's been through hell. Get well Frag.
    Alan.T.Gower, Feb 24, 2004
  13. Adrienne M Jenn
    Christofire Guest
    Indeed, seconded.
    Christofire, Feb 24, 2004
  14. Adrienne M Jenn
    Richard Wood Guest
    One of the foremost things with a frame on is preventing
    infection.
    Like never let blood/ooze, swabs, cottonwool, etc thats been
    on one pin site touch another.
    So when the stupid fucking cow in MKGH used the same swab
    to take samples of 4 pin sites to check for MRSA I did call
    her a stupid fucking cow IIRC.
    Hope I did anyway.
    frag
    Richard Wood, Feb 26, 2004
  15. Adrienne M Jenn
    Richard Wood Guest
    Wha? "sneery and confused"? That must have been me. Describing them
    or myself. Duh!
    frag
  16. Adrienne M Jenn
    Richard Wood Guest
    Thanks Adie, sorry I wasn't there when I wur supposed to be :)
    And thanks to everyones best wishes, this will be the last
    unscheduled visit. I've got one more to remove the frame in just
    over 5 months time, few out patient visits between now and then.
    For the more curious (or gruesome, or all three) more details:-
    I have three solid metal "pins", 4mm dia, going from upper two frames
    into top of femur.
    Immediately below the bottom of these three the new break was broke,
    some fancy name they give it.
    Below that theres another couple of these pins and a wire to hold the
    middle bit of femur, then below that three wires going through bottom
    bit of femur.
    Difference between pins and wires : pins 4mm thick, screw into bone,
    poke out of leg on one side. Wires, 0.5mm thick, go though bone and
    come out other side and are held under tension.
    Problem : the break immediately below the third upper pin decided
    that being a horizontal break would be a boring life. It wanted to
    break places no other break had broken. It wanted to be a high
    flying break. It wanted to go places. Up. And indeed it did. It
    went diagonally, right across the bit of the pin going through
    the bone.
    End result : break goes across pin, pin therefore holds top and
    middle part of femur together. Adjusting frame to move top and
    middle parts of frame apart result in, err, nothing, apart from
    a shit load of tension around that third pin. Oh, and a lot of
    pain.
    Anyway, they saw this on x-ray and told me to crank it "open" at
    twice the speed in the hope it would give and go "ping" and then
    all would be good. It didn't. It hurt more and more and more.
    And then for whatever reason the upper leg muscles went into
    amazingly painful cramp. As if I could stand on the leg in the
    first bloody place, not.
    Dawn judged from the volume of my screams I was experiencing what
    women go through at childbirth. Just have caeserians, ok?
    Anyway, the paramedics decided they'd better cart me off to MK A&E
    after I'd gone through 3 bottles of Entenox (2 ambulances) and
    they didn't have any more after the 4th bottle.
    And in between spasms whilst lying in a hospital bed, I nagged
    them enough to take me to Oxford ASAP Monday. TBH MK docs didn't
    have a bloody clue what to do, the morphine made no difference
    to the pain when the leg did spasm.
    At Oxford they gave me enough Entenox I didn't care about
    anything (shit, that stuff rocks! The *only* stuff that made a
    *big* difference) and then unscrewed the offending nail and
    released the tension. Yes, apparently the leg did lengthen
    before his eyes when he did this (!).
    So, here I am, back on track, back at home. With more drugs.
    5 weeks of stretching to go, then 4 months drinking shit
    loads of milk whilst bone hardens and it comes off. Woo!
    And if anyone recommends an Iilzarov frame to any of you,
    tell them to FOAD and go grab a bone saw. When they say
    "It'll be painful" by JHC do they mean it.
    frag
  17. Richard Wood wrote
    Gif. Gif.
    Just in time for summer ride outs.
    steve auvache, Feb 26, 2004
  18. Adrienne M Jenn
    DangerScouse Guest
    Richard Wood says...
    Welcome back frag.
    I hope you did too. Stoopid woman.
    Lesley
    ZXR400SP
    SBS#11[with oak-leaf cluster]
    BOTAFOT#101A UKRMHRC#12
    BONY#54P BOB#18
    Un-cork me to reply
    DangerScouse, Feb 26, 2004
  19. Adrienne M Jenn
    BRC Guest
    "Richard Wood" wrote
    {{hugs}} You poor thing! Not so much fun then huh. Well glad to hear
    you're back at home anyway medear. Will drop in when we come down to pick
    up me mates bike.
    BRC, Feb 27, 2004
  20. Adrienne M Jenn
    Richard Wood Guest
    Cheers.
    But you'll need to give me a *looooong* time to get to the front door if
    Dawns not here. Like ring me when you're going past Birmingham :)
    frag
    Richard Wood, Feb 27, 2004
