Four years jail...
Discussion in 'UK Motorcycles' started by TOG@Toil, Feb 29, 2008.
  1. Have you never heard of equal and opposite reaction?
    The Older Gentleman, Feb 29, 2008
    #61
  2. TOG@Toil
    Eiron Guest
    TOG discussing physics. Where's the popcorn?
    Eiron, Feb 29, 2008
    #62
  3. TOG@Toil
    Pete M Guest
    Steve Berry on Radio 2 the other day summed up the whole cyclist vs
    human argument.
    http://www.bbc.co.uk/radio/aod/main...radio/aod/radio2_aod.shtml?radio2/r2_vine_wed
    Skip to 1 hour 40.
    Pete M, Feb 29, 2008
    #63
  4. TOG@Toil
    Ekul Namsob Guest
    Indeed. The bit that says that you /must/ check before opening your door
    is, however.
    Cheers,
    Luke
    Ekul Namsob, Feb 29, 2008
    #64
  5. TOG@Toil
    Pete M Guest
    #65
  6. I seem to remember Chris Malcolm, of this parish, passing on as
    standard motorcyclist's advice, that when someone opens a door in your
    path you should open the throttle and take it off its hinges, rather
    than risk it stopping you. What I can't remember is whether he was
    recounting a personal experience.
    Brendan
    Brendan Halpin, Feb 29, 2008
    #66
  7. TOG@Toil
    Ekul Namsob Guest
    You appear to be suggesting that 'cyclists' as a whole do not care for
    the safety of others.
    Ta ra,
    Luke
    #67
  8. TOG@Toil
    Ekul Namsob Guest
    Go on, what's your point? Are you claiming that people are not, in fact,
    legally obliged to check before opening their doors or are you just
    writing as a means of keeping your typing fingers busy?
    Cheers,
    Luke
    #68
  9. TOG@Toil
    Simon Brooke Guest
    Yes, that's why she didn't get life.
    Simon Brooke, Feb 29, 2008
    #69
  10. TOG@Toil
    Simon Brooke Guest
    So she was. She was breaking the law. The cyclist wasn't. Lucky she didn't
    get a stiff fine and points on her licence.
    #70
  11. TOG@Toil
    torx Guest
    Cyclists are vermin who should be removed from the face of the earth.
    torx, Feb 29, 2008
    #71
  12. Grimly Curmudgeon, Feb 29, 2008
    #72
  13. TOG@Toil
    AW Guest
    Granted. But the HC also says of cyclists, albeit without the legal
    obligations:
    67
    Leave plenty of room when passing parked vehicles and watch out for
    doors being opened or pedestrians stepping into your path
    be aware of traffic coming up behind you
    But this is digressing. The legal point is clear.
    AW, Feb 29, 2008
    #73
  14. TOG@Toil
    AW Guest
    Indeed. Though I doubt that's actually law, per se. The _HC_ says
    you must check and if an accident results it gets taken up under due
    care & attention or somesuch. </splitting hairs>
    AW, Feb 29, 2008
    #74
  15. TOG@Toil
    AW Guest
    She checked - thus could not be accused of due care or similar which
    is the law that would be taken into account. She failed to spot the
    cyclist but that in itself is not an offence. The cyclist was also in
    the wrong, if not actually breaking a law.
    The police attended and didn't even bother issuing a producer.
    Legally 100% culpable, sure. But in actual fact there was fault on
    both sides.
    AW, Feb 29, 2008
    #75
  16. TOG@Toil
    AW Guest
    I don't really see the difference between this and a cyclist being hit
    after going through a red light - sure, running the red light is
    breaking a law, which riding like a twat isn't, but fundamentally the
    issue is the same - an accident caused by fault on both sides. The
    greater fault lies with the motorist in both examples but the cyclist
    has put himself in a position where the inattention (or whatever) of
    another caused an accident.
    AW, Feb 29, 2008
    #76
  17. TOG@Toil
    Eiron Guest
    She's watching you type, isn't she?
    Eiron, Feb 29, 2008
    #77
  18. TOG@Toil
    Colin Irvine Guest
    You might not be required in law to follow it, but the courts do use
    it in determining culpability.
    Colin Irvine, Feb 29, 2008
    #78
  19. TOG@Toil
    Martin Dann Guest
    She also had three previous FPNs for speeding, AIUI at least one was on
    the same stretch of road.
    IMHO she should be banned from driving for life.
    Martin Dann, Feb 29, 2008
    #79
  20. TOG@Toil
    Beav Guest
    Beav, Feb 29, 2008
    #80
