Four years jail...
Discussion in 'UK Motorcycles' started by TOG@Toil, Feb 29, 2008.
  1. TOG@Toil
    Beav Guest
    That would've caused a few raised eyebrows.
    Oh aye, braking is fine if it's done in a straight line.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Mar 3, 2008
  2. TOG@Toil
    Beav Guest
    When I were a lad the examiner on my car test told me "Ped's ALWAYS have
    right of way, not matter who tells you differently".
    I'm not sure if he was right, but it's something that's stuck and I even
    told the boychic the same thing when I taught him to drive. If it's not 100%
    correct, it's worth bearing in mind with the dickheads we have wandering
    about these days looking for a free meal ticket.
    Give the cunts a wide berth, I say.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Mar 3, 2008
  3. That's normal, if not a bit on the low side. I usually see 3-4 on the
    way from London Bridge to Gresham Street alone.
    Stealth van, innit?
    The Roaming Boxhead, Mar 3, 2008
  4. TOG@Toil
    I took out another one today. One down how many to go.
    Hog, Mar 4, 2008
  5. Good advice, is that.
    One that has stuck in my mind from my learner days is: "Always remember
    that when you're driving a car, you're handling a loaded gun."
    The Older Gentleman, Mar 4, 2008
  6. TOG@Toil
    Squashme Guest
    Squashme, Mar 4, 2008
  7. TOG@Toil
    Nick Guest
    That's a funny old route to take on a bicycle: there are parallel roads
    just to the north which are residential and much quieter (and signed as
    the main cycle route).
    You do see people cycling down there but it can be very exciting since
    the traffic is travelling at 50mph plus by that point - it's a 30 limit
    but changes to 50 just after the lights so people start accelerating
    early.
    Nick
    Nick, Mar 4, 2008
  8. TOG@Toil
    Nick Guest
    Mr Nugent was putting forward a hypothesis that the reason cyclists were
    banned from going through red lights was because although they did not
    present a great risk to other road users in themselves, they could cause
    motorists to take evasive action which would endanger other road users.
    It seemed to me that the same argument would be true for pedestrians and
    hence it was incongruous that they were legally allowed cross against
    the lights.
    It is quite a simple argument to understand. You might want to dispute
    it but I would have hoped that you could follow it.
    Nick, Mar 4, 2008
  9. TOG@Toil
    Nick Guest
    In reality cyclists are a bit like pedestrians and a bit like cars. If
    they are tootling along a 3 or 4 miles an hour on the pavement they are
    similar to a pedestrian.
    If they are going at 25 mph + they are dangerous to pedestrians like a
    car is. It is also true that some cyclists regard pedestrians as lesser
    beings.
    However as you say unlike a motorists they do squash easy and hence have
    a very real vested interest in avoiding collisions.
    Nick, Mar 4, 2008
  10. Or (more simply) they are counted as traffic and therefore have to obey
    the traffic regulations..
    No. Pedestrians are not counted as traffic and hence don't fall under the
    same regulations.
    The traffic regulations don't apply to them (except for one or two
    where they are explicitly mentioned).
    I understood it. I just disagreed with it.
    Phil.
    Phil Launchbury, Mar 4, 2008
  11. No. Cyclists are (or were) forbidden to ride on the pavement since the
    pavement is for foot traffic only. (In law cycles are defined as
    carriages and hence required to be on the highway, not the pavement).
    And in fact is specifically prohibited and punishable by a
    fixed-penalty fine.
    Phil
  12. TOG@Toil
    Mark T Guest
    Phil Launchbury writtificated
    You've missed his point:
    At 3-5mph a cyclist will be part of the pedestrian 'flow', at higher speeds
    a cyclist will not be a part of that flow.
    The increasing provision of shared use paths, with low design speeds, kinda
    supports this.
    Mark T, Mar 4, 2008
  13. depends on the pavment some are mixed use.
    roger
    Roger Merriman, Mar 4, 2008
  14. But it's still illegal for a cyclist to ride on the pavement. Which was
    *my* point.
    Shared use paths have a different classification to pavements.
    Phil.
  15. Silly boy :)
  16. to footpaths yes, a pavement is a pavement what ever may be painted on
    same as the road.
    roger
  17. TOG@Toil
    Nick Guest
    Yes this is a fair point. I wondered how to put it. Any discussion would
    clearly hinge on how important a reason it was. Clearly more than
    insignificant but I would argue less than a primary factor.
    But I really wasn't intending to get bogged down on such a small point.
    Nick, Mar 4, 2008
  18. TOG@Toil
    Nick Guest
    Yes it is perfectly legal on the pavement by my house.
    Nick, Mar 4, 2008
  19. TOG@Toil
    Mark T Guest
    I know that, you know that, Nick knows that, everyone knows that; but why
    were you making that point?
    I presumed it was to explain why you disagreed with Nick's idea of s-l-o-w
    3-4mph cyclists being a bit like pedestrians, but couldn't really see the
    relevence to it, particularly when it is legal to cycle on the bits of
    pavement with paint slapped on 'em, and on many pedestrianised streets.
    Disclaimer: pavement used as a non technical term.
    Mark T, Mar 5, 2008
  20. Yes. They are not remotely like pedestrians and don't have access to
    the pavement unless it's specially marked.
    Phil.
    Phil Launchbury, Mar 5, 2008
