Fork Spring Question
Discussion in 'Bay Area Bikers' started by John Beck, May 5, 2004.
  1. John Beck
    John Beck Guest
    I have a 82, Honda CB450SC Nighthawk (AKA The SOB450). The suspension
    is shot and I cannot find replacement fork springs (I went to Greg at
    Santa Clara cycle and he spent a lot of time calling suppliers to no
    avail). The bike isn't worth taking to a suspension shop - so I have
    two options:
    1) Find fork springs from another bike which will work - note: they are
    comparable to the fork springs from any early 80's Honda Twin ~400cc
    bike... according to Clymer's
    diam = 0.92 inches (say 1")
    Length Spring A = 9.4"
    Length Spring B = 14"
    2) Find industrial compression springs which fit. In which case I need
    some approximate spring constants. [If I go this way, I'll buy a
    variety of springs and mix & match the springs until I get the ride I like]
    Can anyone help me out on these?
  2. John Beck
    John Beck Guest
    Hmmmm. Interesing equation, but I'm suspicious because it doesn't
    specify the material or the units (it is inches or mm?) -- I presume
    that 1.2x10^7 is some scaling factor which would change if I measure the
    spring in different units - or use different material.
    Can you tell me where you got this equation? I'd like to find out more
    about it so I cna use it confidently.
    John Beck, May 6, 2004
  3. John Beck
    John Beck Guest
    Aha! I found a webpage which shows that equation:
    http://www.efunda.com/DesignStandards/springs/calc_comp_designer_eqn.cfm
    And it indicates that instead of using a constant number (1.2x10^7) one
    needs to supply the shear modulus, G, for the material used. (and from
    the units of the shear modulus, the other units may be determined).
    Alas, I cannot easily measure the shear modulus of my old springs - It
    is easier to measure the length, then put a 10kg mass on top of the
    spring and measure the compressed length to determine K (which is in
    units of N/mm - or Lbs/in). Of course, this does not tell me what the
    spring constant of a NEW spring would be...
  4. there are a range of alloys that are used, differing amounts of nickel,
    etc, can change the constant +/- a fair amount.
    John R Pierce, May 7, 2004
  5. John Beck
    John Beck Guest
    Hmmm. I suspect that range is appropriate for my weight, but I doubt
    Honda put springs that stiff into a little 450 Nighthawk.
    Has anyone experimented with industrial springs in their forks?
    John Beck, May 7, 2004
  6. John Beck
    John Beck Guest
    One may not, I but I have seen brass, titanium, even PLASTIC springs. I
    understand racing suspensions use titanium alloys (since money is no
    object). [Yes, I know that this is quibbling - I am not putting
    plastic or titanium springs in my Nighthawk] However, repeated heating
    changes the hardness of steel, which will change the shear modulus - so
    over use spring steel softens and becomes ... well, sprung steel ;)
    Cool! You have allayed my suspicions. The shear modulus in your
    equation is probably typical for the coil springs used in suspensions.
    So I can probably measure it (as you said) and determine what the old
    values
    were and add 50% spring rate to account for the fact that I'm a pretty
    big guy!
  7. John Beck
    Ryder Rick Guest
    Why not shim them up with some pvc pipe spacers for the correct amount of
    sag and see how they work?
    You could also post the length and diameter of your springs and those of us
    with a stash of old springs could see if we have something close.
    RickB
    Ryder Rick, May 8, 2004
  8. John Beck
    John Beck Guest
    I tried it and the amount of force required to compress the springs
    makes it very difficult to start the threads properly on the fork cap.
    Cool. Here are the specs...
    John Beck, May 10, 2004
  9. John Beck
    John Beck Guest
    Wow. The pre-load on my little 450 is < 1" (how far the cap screws in.)
    I wonder why no one makes fork caps with an adjust for pre-load. I
    mean, all ya need is a threaded hole with a screw (and a lock-nut). I
    could mod the caps and allow for an additional 2 or 3 inches of preload
    .... maybe I need to track down a spare set of fork tube caps...
    John Beck, May 11, 2004
  10. John Beck
    John Beck Guest
    Hmmm.
