Fork specs
Discussion in 'Australian Motorcycles' started by Yeebers, Jan 24, 2008.
  1. Yeebers
    Yeebers Guest
    Figured this was as likely to get off topic as the last one so I started
    a new thread..
    I've measured the forks. I assume some of these values will be
    irrelevant. For those of you tuning in for the first time, they're
    upside down. Appearance is gold top then a stainless ring with seal,
    then the stainless sliding tube then the axle mount, all one unit.
    In terms of diameter, the forks narrow between the 2 vertical grips the
    triple clamp has on it. The uppermost portion is 165mm in circumference,
    and the lowermost portion is 170mm. The silver end is 190mm around, the
    slider tube is 135mm.
    In terms of height, as it is on the bike (I assume I'll need to fully
    expand or contract it for perfect measurements):
    Upper gold part 492mm, silver part 43mm (making an 'outer' of 535mm).
    Tube is 127mm sticking out of the outer making the tube ad slider a
    'neat' 666mm tall.
    The axle part's 134mm high making a total height of 800mm.
    The axle hole (love that ;)) starts at 773mm and ends at 785mm from the
    top of the assembly.
    Dry weight is 155Kg.
    So (long shot..) does anyone know off the top of their head another bike
    that has the same size forks from their experience ? Tho if you know how
    to research that, let me know :)
  2. Yeebers
    I suggest that you follow these steps:
    1. Get a service manual for the bike;
    2. Buy/borrow a pair of vernier calipers;
    3. Disassemble your intact fork;
    4. Measure the stanchion[1] in all dimensions;
    5. Go to that place where Clem bought his new Triumph fork
    stanchions[2], and see if they can help you.
    [1] The shiny chrome-plated tube. In your case, the "lower bit";
    [2] Where was it again, Clem? I can't find the post in Google Groups.
    BT Humble, Jan 24, 2008
  3. Yeebers
    Hang; what's damaged. Is there NOTHING reusable out of either leg?
    If not; then you may as well just fit the front end off whatever you find
    around cheap.
    http://cgi.ebay.com.au/suzuki-rgv-u...ryZ35232QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
    Ring up Alistair Maxwell at (dammit; what's that big wreckers out Penrith
    way) and tell him your sob-story..
    Is it
    Liverpool Bike Wreckers
    It'd certainly help if you could match your forks to a Jap bike. Go to the
    dealer and have a wander around the used bikes and see if anything matches.
    (And if so; look here: http://www.bikebandit.com/oem-parts )
    If it's just the shiny inners you want then follow BTs advice.
    This is where I got mine but they don't list Hyosung:
    http://www.lm-spares.co.uk/acatalog/copy_of_Fork_Kits.html
    Have you asked for advice here:
    http://www.bikez.com/msgboard/msg.php?id=21681&type=bike
    Knobdoodle, Jan 24, 2008
  4. When mesuring round things in engineering, it's customary to quote
    their diameter, as measured with a set of Vernier calipers, not their
    circumference.
    Also, when trying to source secondhand parts, it's customary to hassle
    wreckers with repeated phone calls rather than to leave messages.
    Hyosung have been selling far too many bikes to n00bs over the last
    couple of years for quite a few of them not to have ended up in
    wreckers by now.
    Which wreckers have you called directly and had them tell you over the
    phone that they positively *don't* have a straight forkleg for the
    GT250/650 (bet you dollars to doughnuts they run the same front end).
    This business of trying to transplant a front end off something else
    is so far down the list of absolute last-ditch desperate options to
    try, it sits below donating what's left of the bike to the local patch
    club for their next bonfire.
    There's bound to be a forkleg out there; look harder.
    intact.kneeslider, Jan 25, 2008
  5. Yeebers
    Yeebers Guest
    Yeah I did, thanks The Biker. That was where I found a most helpful
    gentleman who promptly replied to all my parts requests .. and even sent
    me a parts manual. My initial quote for a single left leg was 350us but
    with currency the way it is it's likely changed in the weeks since I
    spoke with him. Once I factored in exchange GST and the rest of the crud
    that comes with importing it didn't work out much cheaper even tho his
    mirrors were 35/pair and the local could only get them for 'only' 130+..
    I'm coming close to just paying the local dudes to do it all or at least
    get the parts and have me put them on (then ride slowly to the shop and
    get them to check my handiwork .. mechanic I ain't (but I can change a
    clutch cable..) ;) )
    Yeebers, Jan 27, 2008
  6. Yeebers
    Nev.. Guest
    What.. threaten to go public with the RRP of the parts which they sell
    to the public? **** ME. A whisper of that and they'll be knocking down
    his door with two sets of forks. That reminds me.. I have to tell the
    folks down at Ferrari that I'm going to ACA with their new car catalogue
    if they don't give me a free car...
    Nev..
    '07 XB12X
    Nev.., Jan 27, 2008
  7. Yeebers
    CrazyCam Guest
    Changing a clutch cable is rather simpler than bolting in a fork leg.
    Unless you have a torque wrench, know how to use it, and have the
    appropriate torque settings for the bolts involved, I'd strongly
    recommend that you let the local shop do the job.
    I have heard that the metallurgy of the Hyosung isn't that flash, and,
    if you start stripping threads or breaking bits, you might never get a
    going bike.
    regards,
    CrazyCam
    CrazyCam, Jan 27, 2008
