For WUN
Discussion in 'UK Motorcycles' started by The Older Gentleman, Jun 6, 2005.
  1. (With apologies to Meatloaf)
    The Nigel is screaming and the Eaton is howling, way down in Holwell
    tonight.
    There's a Z on its stand with its tank on the shelf and the cams shining
    oh so bright
    There's spanners on the floor and feelers in the head, and a bloody
    useless magnet-onna-stick
    Oh, and down in the tunnel where the camchain is rising, I swear I saw a
    valve shim, stuck in a crevice, it was saying to him "God, what a
    dick...."
  2. The Older Gentleman
    JB Guest
    *excellent*! (although having been there myself, the humour may be lost on
    the unfortunate Mr. Eaton atm).
    Jb
    JB, Jun 6, 2005
  3. Using the patented Mavis Beacon "Hunt&Peck" Technique, The Older
    <G> ****.
    This List is getting ever so long...
    and Ducati Race Engineer.
    Wicked Uncle Nigel, Jun 6, 2005
  4. The Older Gentleman
    On Mon, 6 Jun 2005 07:41:01 +0100,
    Oh camshims are the only thing in this old barge
    that're round and flat and thin
    and wherever you block and whatever you wedge
    they're always gonna find a way in
    But you gotta get it out, gotta take it out now
    before the final valve is done
    so you gotta make the most of your one sump together
    when it's open you know
    you'll both be so undone
    _______
    \`\ | /`/ GSX-R1000K3
    Ace, Jun 6, 2005
  5. The Older Gentleman
    TOG Guest
    He's gonna hit the Blinger with a battering ram
    And an angle grinder wielded right
    Plus a bloody big hammer, and a grab-onna-stick and a little fibre
    optic light
    It's never gonna roll till he delves into that hole
    And pulls the little fucker out
    If he hits the starter now, there'll be a bloody big "Ka-pow!"
    And he'll never have to worry, no he'll never have to worry,
    About the tappets being five thou over-tight....
    TOG, Jun 6, 2005
  6. Like a shim outa Hell it'll be gone when the morning comes
    When the engine turns over
    That shim out of Hell will be gone, gone, gone
    When the stripdown's done
    And the shim's fished out
    And the crankshaft shining through
    And like a shimmer before the camchain tunnel
    I'll come shimming on back to you
    Grimly Curmudgeon, Jun 6, 2005
  7. The Older Gentleman
    TOG Guest
    <snip>
    Would all artistes please gather on the stage for a curtain call? Many
    thanks.
    TOG, Jun 6, 2005
  8. The Older Gentleman
    On Mon, 06 Jun 2005 13:24:34 +0100, Grimly Curmudgeon
    <snip>
    And he knows that he's blinged if it never gets out
    And maybe he's blinged if it do
    But with any other heap he'd have let it fall apart
    And now he'd prob'ly be reaching for glue
    If he gotta be blinged you know he wanna be blinged
    Searching for the shim he knew
    Gotta be blinged you know heanna be blinged
    _______
    Ace, Jun 6, 2005
  9. The Older Gentleman
    Salad Dodger Guest
    It was a hot summer night and the crank was turning
    There was a engine oil all over your hand
    When you lifted off the cam you saw the sprocket turning
    Then the bastard shim was
    Falling through your trembling hands
    You were squinting your eyes with your maglite shining
    It would turn the engine's contents to paste
    It was lying all hidden in the crankcase lining
    By the light of the torch
    You know there's not another moment
    Not another moment
    Not another moment to waste
    The engine's so heavy that your knees grow weak
    It weighs in at three hundred pound'
    You're straining your back but no matter what you do
    You just can't seem to get it off the ground
    And then you dropped the shim right into your sump
    Oh it must have been while you were making tea
    You dropped the shim right into your sump
    And you swear it's true
    You were gonna get someone to do it.
    Now your body is shaking like a cat on a hotplate
    And you guess that you're beginning to fizz
    Oooh, you're finally alone and you can do what you want to
    The night is young
    And you still don't know where
    Still don't know where
    Still don't know where it is.
    | ___ Salad Dodger
    |_\_____/_| ..75805../..18781.../..3196./.19406
    \|^|/ ANORAK#17 IbB#4
    '^' RBR Landmarks: 24 Pts: 400 Miles: 1589
    Salad Dodger, Jun 6, 2005
  10. Using the patented Mavis Beacon "Hunt&Peck" Technique, Salad Dodger
    <Genuine LOL>
    Well, it's nice to know that I'm providing some amusement for the
    amateur comedians.
    The "Ballad of WUN's shim" is now complete. OK?
  11. The Older Gentleman
    I doff my cap to you sir.
    You am da man.
    _______
    Ace, Jun 6, 2005
  12. <snip>
    Excellent.
  13. <Tom mode>
    Don't You Believe Him
    </tm>
  14. Pah. Pay no attention to that grump behind the curtain.
    Grimly Curmudgeon, Jun 7, 2005
  15. Looking at it in the cold light of day... not great.
    'Es no bad, inne.
  16. The Older Gentleman
    I dunno. Nobody did the obvious:
    #Shim shimmeny, shim shimmeny, shim shim sheree,
    #A shim is as fucky as fucky can be
    #Shim shimmeny, shim shimmeny, shim shim sheroo,
    #Bad luck will rub off when it drops down - and Nooo!
    Pip, Jun 8, 2005
  17. The Older Gentleman
    Salad Dodger Guest
    Or: <Charles Aznavour>[1]
    Shim may be in a place I can't quite get
    Not with a sticky mag-a-net
    Maybe dismantling is the price I have to pay
    Shim may be the pingfukkit that pings
    May be the end of that which blings
    May be under many different things
    Within the sump of a big K
    Shim may be the beauty or the beast
    May be the famine or the feast
    May turn each day into a Heaven or a Hell
    Shim may be the mirror of my dreams
    A smile reflected in a stream
    Shim may not be where she may seems
    Inside her shell....
    Shim, who always seems so happy in a crowd
    Whose place can be so private and so proud
    No one's allowed to see them when they fall
    Shim maybe the love that cannot hope to live
    May come to me from oil can and a sieve
    That I use to finds things small
    Shim maybe the reason I survive
    The why and wherefore I'm alive
    The one I care for through the rough and ready years
    Me, I'll take the laughter and the tears
    And make them all my souvenirs
    For where shim goes I've got to be
    The meaning of my life is
    Shim....Shim
    Oh, shim....
    [1] spellchecker suggests "unsavoury" :)
    | ___ Salad Dodger
    Salad Dodger, Jun 8, 2005
  18. Using the patented Mavis Beacon "Hunt&Peck" Technique, Salad Dodger
    (Snip)
    ROTFLMAO.
    <stamps feet, whistles>
    You utter, utter, *utter* ****.
    I'm almost glad I dropped the fucking thing now.
    Wicked Uncle Nigel, Jun 8, 2005
  19. The Older Gentleman
    Probably needs replacing now, that shim. I mean, look at the mileage
    that's been put on it over the last couple of days.
    Pip, Jun 8, 2005
  20. The Older Gentleman
    National Treasure.
    Pip, Jun 8, 2005
