For the aeroplane loonies
Discussion in 'UK Motorcycles' started by Paul Corfield, Oct 21, 2006.
  1. Paul Corfield
    I'll never let that get in the way of the fact that Concorde used the
    same engines as a type 32 destroyer.
    This is only a game and I can use the facts however I want to.
    Andy Bonwick, Oct 25, 2006
  2. Andy Bonwick wrote
    Andy old bean, I hate to shatter your illusions but the most important
    bits on an aeroplane, apart from the hostesses pushing the drinks
    trolley are the wings. It is all rather pointless without either of
    them really.
    steve auvache, Oct 26, 2006
  3. The engines are used as gas generators in most major power stations.
    A total boiler / steam generator failure, switch on a single Olympus.
    At do?
    Mick Whittingham, Oct 26, 2006
  4. Paul Corfield
    That's a bit of an exaggeration but it's true they're used in some
    stations.
    Nearly but not quite again.
    The gas turbines run most of the time and waste heat runs the
    steamers.
    RR also wanted to use the Trent engine in more power stations but it's
    too dirty so it's not considered a good thing.
    The above was apparently one of the reasons why RR purchased my old
    employer because they made a suitable steam unit to twin up with the
    Trent. Whoops.
    It will now.
    Andy Bonwick, Oct 26, 2006
  5. More than happy to be updated.
    My information comes late 1970s. I did an analysis of the engine control
    systems which were at that time Marconi Elliot.
    The idea was to be able to test the controllers and the auto start
    without taking the engine off line from its back up role.
    The thing that stuck in my mind was that some of the power plants even
    had re-heat. And in the event of a flame out they would be relit without
    the normal pause, to drain down the re-heat pluming.
    To any RAF 'sooties' out there this would be a full power wet re-start.
    In an aircraft this would result in a hoooge explosion and a megga flame
    out the hot end, often with added bits.
  6. Paul Corfield
    Owen Guest
    Perfectly ...
    Owen, Oct 26, 2006
  7. Paul Corfield
    Heh. Works for me.
    Pip Luscher, Oct 26, 2006
  8. Paul Corfield
    Not at all. I'm a selective Luddite.
  9. I'd prefer to think of it as a warship being powered by Concorde
    engines: sounds way cooler.
    The Older Gentleman, Oct 27, 2006
