for love of a bike........
Discussion in 'Motorbike Technical Discussion' started by t, Jul 20, 2005.
  1. t
    t Guest
    Well, I think I finally am on the right track with the carbs. From the
    descriptions of Mr. Kritter, it sounded like my bike was running way too
    rich, even at 1.5 turns out on the pilot screws. Made me think someone
    might have upgraded parts somewhere. So I took a warm up on the bike
    and brought it back. Tweeked the carbs, and thought I'd take it back
    out to see what kind of response I'd get.
    I was so wrapped up in thinking about carbs, it didn't even register my
    clutch felt a little mushy. At least, not til I got a quarter mile from
    the house and it quit altogether. Helluva time shifting when you have
    no clutch. But second gear got me home. Now to figure out what went
    wrong there, so maybe I can get back out and finish checking the carbs.
    83 Honda Shadow 750
    t, Jul 20, 2005
  2. Oh, you can shift a motorbike gear box all day with no clutch, as long
    as you're moving...
    Is it a hydraulic clutch, or a cable-operated clutch? Hydraulic
    clutches get air in the system and the lever will nove easily, while
    the slove cylinder doesn't disengage the clutch at all...
    krusty kritter, Jul 20, 2005
  3. t
    t Guest
    that's pretty much what i had to do to get home......
    hydraulic. got home and pulled the cover off the cylinder, which had
    fluid in it. seemed a little low, but within specs. once it cools off
    later, i'll pull it further apart to check and bleed the system.
    t, Jul 20, 2005
