foglamps
Discussion in 'Classic Motorbikes' started by Austin Shackles, Nov 5, 2009.
  1. Austin Shackles
    YTC#1 Guest
    Do they sell sig snippers as well ?
    YTC#1, Nov 10, 2009
  2. Austin Shackles
    YTC#1 Guest
    You read funny
    YTC#1, Nov 10, 2009
  3. sadly, RVLR doesn't proscribe the use of fog lights at the same time as
    dipped lights, exceopt in the clause referred to about dazzle and
    visibility.
    However, you can get 'em on that in any case. Fact of the matter is, no-one
    ever gets done for it - I want legislation to make it impossible to use both
    at once, and to bring fog lights into the MOT checks which they aren't at
    present: I know this, my disco II has been through an MOT and a taxi test
    with one of the front fogs broken.
    Austin Shackles, Nov 16, 2009
  4. Tempting. However, what I was after, as I said, is to make it so you can't
    have dips and fogs on simultaneously.
  5. Mine do... however, that would only stop the incompetent, not those who
    wilfully turn 'em on for whatever misguided reason.
  6. That's OK if we don't get real fog. In seriosuly thick fog like we rarely
    get now, ordinary rear lights just don't penetrate - RFLs *used properly*
    when it's really foggy are actually a good thing.
    proper use includes turning the fecker off when there's another vehicle in
    view behind you, such as in traffic queues. The only one in a queue who
    should have the RFL on is the tail-end-charlie.
  7. Austin Shackles
    The percentage of time where lit RFLs are doing something usefull is
    0.0 followed by several thousand more zeros then a 1 at the end. If it
    really is /that/ foggy, another car won't be closing at any sort of
    speed so will still see your rear lights. Anyone with enough
    intelligence to switch their RFLs off when a car's approaching from
    behind will also have enough intelligence to flick their brake lights
    or flashers a couple of times.
    For the rest of the time, which is effectively 100%, all they do is
    reduce visibility for everyone behind & mask brake lights.
    Krusty, Nov 16, 2009
  8. Austin Shackles
    Tim Guest
    I thought (waits for correction) that it was some construction
    requirement that front fogs could only come on with dipped lights and
    not with just side lights.
    Tim, Nov 16, 2009
  9. Austin Shackles
    ian field Guest
    You obviously haven't seen the fuckwits driving in fog.
    ian field, Nov 16, 2009
  10. Austin Shackles
    Higgins Guest
    Not sure why you would want to ban using fog lights with dipped lights.
    That's usually the best combination as full beams just bounce straight
    back at you in fog.
    Higgins, Nov 16, 2009
  11. Austin Shackles
    Adrian Guest
    Unless the fog's so thick that dip bounces back - in which case, sides +
    fogs...
    Adrian, Nov 16, 2009
  12. Austin Shackles
    Which hardly ever happens. So again, why have something that reduces
    visibility for other users for the vast majority of the time they're
    used, just because they may serve a useful purpose in an increasingly
    small (& already tiny) number of situations? Makes no sense at all.
    I've never used rear foglights & never will, apart from when there's a
    **** behind me with front fogs on. Amazingly nobody's ever run into the
    back of me.
    Where 'see' equals 'be dazzled by'.
    Krusty, Nov 17, 2009
  13. Austin Shackles
    Obviously not as despite having been driving for 26 years without using
    foglights, nobody's ever driven into the back of me.
    How many times have you been rear-ended in fog?
  14. Austin Shackles
    Adrian Guest
    Where you live.
    You've probably never found yourself in fog so thick that you're not even
    100% sure where the road is, have you?
    Adrian, Nov 17, 2009
  15. Austin Shackles
    Or anywhere else I've lived, from mid Wales to Dartford.
    Yes, loads of times. I'd love to know how you think there'd be enough
    difference in speed between cars in those conditions for someone not to
    see normal rear lights in time.
    How many times has someone ran into the back of you in fog?
  16. Austin Shackles
    Adrian Guest
    Because, of course, everybody has a similar perception of an appropriate
    speed in poor visibility.
    Last time it happened was just after I stopped beating my wife...
  17. Austin Shackles
    If the fog's so thick you're not sure where the road goes, nobody will
    be going more than a crawl.
    Heh.
  18. Austin Shackles
    Adrian Guest
    You might not.
  19. Austin Shackles
    No I don't, I buy insurance because the law requires me to. I don't buy
    insurance because a crane might fall on my car, or I might get hit by a
    meteor, or a falling tree, or a badger that someone's launched from a
    trebuchet, or a million other things that could potentially happen to
    me but never have.
    If I felt I needed insurance for that, my safety gene would never let
    me ride a bike.
    Oh FFS, you'll be saying 'think of the children' next. Tell me
    something, do you carry powerful white & red lights in your car & on
    your bike? No? What happens if you brake down with total electrical
    failure on a foggy night & someone runs into your parked car/bike, you
    selfish ****.
  20. Using the patented Mavis Beacon "Hunt&Peck" Technique, Krusty
    That happened to me once.
    Although I'm not totally sure it was a badger. It might have been a
    penguin. It was going pretty fast.
    Wicked Uncle Nigel, Nov 17, 2009
Similar Threads
Loading...
