Fog lights
Discussion in 'UK Motorcycles' started by HooDooWitch, Nov 21, 2003.
  1. HooDooWitch
    ...and the SMIDSY. I can't see how indicators prevent them.
    sweller, Nov 21, 2003
  2. HooDooWitch
    flashgorman Guest
    That was the other bloke mentioned that. I was just thinking of people
    changing lanes with an indicator the size of christmas tree light bulb.
    flashgorman, Nov 21, 2003
  3. HooDooWitch
    WSotW Guest
    och how can ye forget that, I'll set wee Shuey on yer
    WSotW, Nov 21, 2003
  4. HooDooWitch
    Slider Guest
    "The other bloke" was referring to a similar event where a chap changes
    lanes into someone overtaking them. Not so much a SMIDSY I suppose as a
    YTCism.
    Slider, Nov 21, 2003
  5. HooDooWitch
    flashgorman Guest
    Any fool knows that the amount of room required to make a lane change is in
    inverse proportion to the amount of time an indicator has been on for.
    Similary when waiting at a junction the size of gap required to pull out
    safely will decrease the longer you wait - until after a while you don't
    need any gap at all at can just pull out at will.
  6. HooDooWitch
    I do this all the time - it's fine.
    darsy, Nov 21, 2003
  7. HooDooWitch
    HooDooWitch Guest
    If I didn't do this every day, it'd add 5 minutes onto my commute.
    It seems to. Next time you try it, just look left. :)
    You gotta wear day-glo to get the full effect.
  8. HooDooWitch
    flashgorman Guest
    What about if it was foggy? You'd need some sort of special light I reckon.
  9. HooDooWitch
    HooDooWitch Guest
    If I got a laser pen, and some Duck Tape ...
  10. HooDooWitch
    If you stuck it on to the pillion grab handle, facing forwards so that
    the beam strikes the dayglo gear ...
    Pip, Nov 21, 2003
  11. HooDooWitch
    nah, 25hz strobe light.
    darsy, Nov 21, 2003
  12. HooDooWitch
    HooDooWitch Guest
    .... and ran a cable to the rev counter ... ;)
  13. HooDooWitch
    deadmail Guest
    Oh, at least one sees bikes. I had an incident recently when I did this
    and a car driver decided not to let me in.
    Fair enough really, it's taking the piss barging in like this and if
    someone doesn't give way to me then that's only to be expected.
    deadmail, Nov 21, 2003
  14. HooDooWitch
    jsp Guest
    Pull the brake lever?
    John
    SV650
    Black it is
    and naked
    jsp, Nov 21, 2003
  15. HooDooWitch
    sweller said....
    My ZZR has fucking huge indicators and I never use them. I've not been
    SMIDSY'd on it yet.
    Lozzo
    ZZR1100D, GPZ500S, CB250RS x3
    BotToS#8, GP#2, SBS#10, SH#3, DFV#14, KoBV#3.
    http://www.glfuk.com/ for MJK Leathers in the UK.
    Lozzo, Nov 21, 2003
  16. HooDooWitch
    jsp Guest
    Personnally I'd rather they just took them off most cars. I get fed up
    of following cars with fog lights on because their drivers are too thick
    to know how to turn them off or when to turn them on.
    John
    SV650
    Black it is
    and naked
    jsp, Nov 21, 2003
  17. I do that a lot. Fair shits up the odd driver on the other side.
    GS 850 x2 / SE 6a
    SbS#6 DIAABTCOD#16 APOSTLE#16? FUB#3
    FUB KotL OSOS#12? UKRMMA#19
    Grimly Curmudgeon, Nov 21, 2003
  18. HooDooWitch
    Platypus Guest
    Use two, pointing forward, taped to the sides of your helmet. If you
    see them, they'll see you...
    Platypus - Faster Than Champ
    VN800 Drifter, R80RT, Z200
    DIAABTCOD#2 GPOTHUF#19
    BOTAFOS#6 BOTAFOT#89 FTB#11
    BOB#1 SBS#35 ANORAK#18 TWA#15
    Platypus, Nov 21, 2003
  19. HooDooWitch
    Platypus Guest
    OFFS. Just hold the brake on - identical effect.
  20. Ah! I understand!! I wondered what those shirt-button barely visible
    little lights on bikes were about. Tsssk! Someone'll invent nice,
    friendly, furry ear-like things for helmets next.
    Dave OSOS#24 Remove my gerbil for email replies
    Yamaha XJ900S & Wessex sidecar, the sexy one
    Yamaha XJ900F & Watsonian Monaco, the comfortable one
    http://dswindell.members.beeb.net
    Dave Swindell, Nov 21, 2003
