FOAK: XP mass file rename
Discussion in 'UK Motorcycles' started by Jeremy, Jul 5, 2006.
  1. Jeremy
    Jeremy Guest
    I have hundreds of files in a folder (on windows xp) which all have
    names such as
    Time 1 Add.png (i.e. capital letters and spaces)
    I want to do a mass rename so that such a file would subsequently be
    called
    Anyone suggest a utility that might handle this requirement?
    jeremy
    '01 Triumph Sprint ST in green
    jeremy0505 at gmail.com
    Jeremy, Jul 5, 2006
  2. Any use ?
    http://support.microsoft.com/kb/320167/
    Brownz @ Work, Jul 5, 2006
  3. Jeremy
    Jeremy Guest
    Not really thanks - I want to retain the original "structure" of the
    name - the article looks as though it will rename multiple files to have
    the same name as each other with a number appended.
    thanks though
    jeremy
    Jeremy, Jul 5, 2006
  4. Jeremy wrote
    Standard fare for a *nix shell.
    Install cygwin.
    steve auvache, Jul 5, 2006
  5. Jeremy
    Dan White Guest
    http://www.alatar.de/projects/renamefiles/index.html
    It's bloody good, been using it for years. Make sure you look at the
    "preview" option, with "Only show files that will be changed" selected
    before you commit. Then you can see what the files *will* look like.
    Dan White, Jul 5, 2006
  6. Jeremy
    Jeremy Guest
    I feared that might be the suggestion - I guess we're talking an 'mv'
    command with some [ABCDE] [abcde] type construct?
    jeremy
    Jeremy, Jul 5, 2006
  7. They're PaintShopPro files right? Hmm, I don't think PSP Batch
    conversion allows a file name change in that manner, but, IIRC
    Photoshop Batch conversion might. I don't have it installed here to
    check.
    DoetNietComputeren, Jul 5, 2006
  8. Jeremy
    Jeremy Guest
    Not sure of the origins - it's part of a set of business icons that I
    just bought. There are also .gif files in there too - really looking for
    a generic file management utility rather than something within another
    application if at all possible.
    jeremy
    Jeremy, Jul 5, 2006
  9. Jeremy
    don't you know any scripting languages?
    about 6 lines or Perl ought to suffice.
    Hell, you could bodge something in ASP or PHP if you're desperate.
    darsy, Jul 5, 2006
  10. Jeremy
    Higgins@work Guest
    Have you forgotten who you're talking to?
    Higgins@work, Jul 5, 2006
  11. Jeremy wrote
    Why? Having some form of *nix on your system gives a you very powerful
    set of simple administrative tools and it seems to me that you are in
    need of some.
    It is *nix, there are at least 57 different ways of doing it.
  12. Jeremy
    Jeremy Guest
    Exactly what I wanted Dan - works a treat - ta.
    jeremy
    Jeremy, Jul 5, 2006
  13. Jeremy
    Jeremy Guest
    Dabble with ksh as required but it's not part of my "day job". In the
    time it took to download and install cygwin, I had the job done using
    Dan's suggestion.
    I was desperate, but not *that* desperate ;)
    jeremy
    Jeremy, Jul 5, 2006
  14. Jeremy
    Jeremy Guest
    Jeremy, Jul 5, 2006
  15. Jeremy wrote
    Yebbut you ain't learned anything have you? You are just as fucking
    iggerrant now as you were an hour ago.
    6 lines is five lines of overkill anyway.
  16. Jeremy
    Steve Parry Guest
    open a CMD prompt .. .navigate to the folder containing your files
    type
    press enter
    Job done
    Steve Parry, Jul 5, 2006
  17. Jeremy
    Steve Parry Guest
    easy in XP too
    cmd prompt
  18. Jeremy
    Jeremy Guest
    Repeat 1365 times for that one folder.
    jeremy
    Jeremy, Jul 5, 2006
  19. Jeremy
    Steve Parry Guest
    what are you on about ? That one line will rename all files matching those
    filters in one hit.
  20. Jeremy
    Steve Parry Guest
    PS bad form etc
    try it create a folder with a couple of renamed txt files in matching your
    original naming scheme then apply that command within that folder
