FOAK: working out distances using lat & long
Discussion in 'UK Motorcycles' started by Buzby, Oct 23, 2004.
  1. Buzby
    Buzby Guest
    I'm a bit stuck here - should have been a bit more attentive at school..
    Using VB script for a web page, how do you work out the distance between two
    places, both of known longtitude and latitude.
    Basically what I want to be able to do is enter a place and find everything
    in a database say less than a mile from this one point.
    I'm sure it's easy if you know how - buggered if I do.
    TIA
    Buzby
    Buzby, Oct 23, 2004
  2. I can remember finding some code to do just this about 30 years ago, and
    using it on a variety of machines from HP desktop calculators, through BBC
    Micros, to Acorn RISC machines. It was published in Radio Communication
    yonks ago, but I don't have a copy. Radio amateurs often need to work out
    Great Circle distances between two stations anywhere on the surface of the
    Earth, but normally they will be using a program written by someone else,
    rather than coding it themselves.
    If no joy, I think that an enquiry on uk.radio.amateur would bear fruit.
    Good hunting
    Rick
    Richard Sterry, Oct 23, 2004
  3. Buzby
    Buzby Guest
    Thanks - however just managed to 'lift and adapt' something which seems
    surprisingly accurate!
    Buzby, Oct 23, 2004
  4. Buzby
    mb Guest
    It's called "Great Circle Navigation", probably.
    mb, Oct 23, 2004
  5. Buzby
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, mb
    It is, but for small distances a rhumb line works pretty well. For a
    mile, it'd be more than accurate enough.
    Nigel Eaton, Oct 23, 2004
  6. Buzby
    Eiron Guest
    Not needed for distances of a mile or so.
    For the distance between two points:
    Take the difference in latitude in degrees, multiply by 10000 and
    divide by 90 to get it in kilometres.
    Do the same for longitude but multiply by the cosine of the latitude.
    Take the square root of the sum of the squares of the above two values
    and Bob's your uncle.
    Eiron, Oct 23, 2004
  7. Buzby
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Champ
    **** me! AFAIC, it's just a straight line on a chart.
    Having looked at that webpage, I'll never go to sea again.
  8. It was somewhere around Barstow, on the edge of the desert, when the
    Eek!
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Oct 23, 2004
  9. Buzby
    Buzby Guest
    Perfect. Thanks very much.
    Buzby, Oct 24, 2004
  10. Buzby
    I had to study (nautical) navigation when I was about 17, but I don't
    think we ever approached it in that way. Instead we based it all on
    3-d trigonometry, using cosh, shin and than h for hyperbolic, IIRC).
    Piece of piss in practice, as they work for a shape (line, engle,
    whatever) on a sphere's surface in exactly the same way as their
    normal cousins on a flat surface.
    Ace, Oct 25, 2004
