FOAK: WMWare
Discussion in 'UK Motorcycles' started by Higgins@work, Nov 24, 2004.
  1. Higgins@work
    Higgins@work Guest
    Pesky customers have tasked us to develop and modify a number of
    applications which interface with a distributed database and we want to
    have multiple copies of said DB that developers can modify, break,
    generally **** about with and blow away at their whim.
    Unfortunately the unique identifier of each copy of the DB is based on
    the server name on which the DB resides, which would appear to limit
    the potential for multiple copies of the DB on a single physical
    server, so the developers want to buy a bunch of servers to host these
    copies.
    Given that the purchase and maintenance of these servers would be down
    to me, I'm not too keen on that plan and have suggested that they look
    at VMWare Workstation to run virtual servers, with the added bonus that
    they can blow the DBs away and roll back to older versions with
    relative ease.
    The response has been that they are not keen to introduce such an
    "unknown" into the development and test environment. It seems to me
    that they would only be dealing with the OS and the DB and that the
    underlying "virtual hardware" would be irrelevant.
    So, what's the real story? Does VMWare add "unknowns" to the mix or is
    it effectively a pukka server? Win2K server in this case.
  2. Higgins@work
    Nigel Eaton Guest
    Win2K I don't know, but with assorted flavours of Linux *under* Win2K
    it "does what it says on the box".
    Very nicely.
    Honda GL1000K2 Kawasaki ZN1300 Voyager "Oh, Oh, It's so big"
    Nigel Eaton, Nov 24, 2004
  3. Higgins@work
    Higgins@work Guest
    I've played with it at home, running Win2k Server and Linux under XP,
    and, at the user level, I completely agree. I just don't have the
    knowledge to argue a decent case at developer level, I may need to
    insist on a trial run.
  4. Higgins@work
    Nigel Eaton Guest
    Well, I do an amount of development under it. And quite a bit of
    static relinking to include external 3rd party libraries, together
    with shared object library use.
    But I'd agree a trial run would be smart.
    Here endeth my knowledge.
  5. Higgins@work
    We use VMWare *extensively* at my place - probably got over a hundred
    virtual servers running at the moment. It's a cracking product, and
    has massively reduced our hardware cost, and given us a load of other
    benefits:
    - easy rollback (as you noted)
    - portability (hardware a bit busy? Just move a VM or 2 elsewhere)
    - cloning - build a copy of a server from an other one
    However, we only use the GSX "server" version, not the (much cheaper)
    work station version. The problem with the workstation version, as I
    understand it, is that only one person can access it at a time.
    hth
    Champ, Nov 24, 2004
  6. Higgins@work
    Higgins@work Guest
    That helps a lot, thanks. We haven't explored it in depth yet, but I
    was thinking that each developer could have their own copy of the DB
    running in a virtual server for dev and retain a single, controlled
    central DB for testing against, so single access would be fine.
    cheers,
  7. Higgins@work
    Higgins@work Guest
    Thanks, as per my response to Champ, it was my suggestion that we
    retain a conventional test environment with a real server which would
    alleviate a lot of that risk.
    The other option, of course, would be to attack the root cause of the
    problem, which is the POS which is the central DB. However, I suspect
    that the current contractual obligations around it are too tight.
  8. Higgins@work
    Tim Guest
    In message <>, "Higgins@work"
    VMWare works for serving W2K. If it didn't my place couldn't run them in
    the production environment. Tell the customer to stop being a poof.
    Tim, Nov 24, 2004
  9. Higgins@work
    Higgins@work Guest
    Well, since the DB is related to command and control information
    systems, the customer has a valid reason to ask questions.
    However, this discussion is between me and the developers at this
    point, it hasn't got as far as the customer yet.
  10. Higgins@work
    Daz Guest
    <snip>
    We use orkstation exclusively at our place. Build a Win2k VM on any
    desktop and it'll be seen on the network as a completely separate
    server. For development and testing purposes as Champ has suggested
    it utterly rocks. Just get the budget holder to look into the TCO
    compared with physical tin and they'll have their cheque book out in
    minutes.
    Only downside is the developer machines need 512mb RAM minimum. I've
    got four times that in my home machines but the number of clients I
    visit with developers trying to run VS.NET on 128mb is staggering so
    worth a mention.
    Also remember you still need licenses for the software you stick on
    them and when they are built make sure they're properly patched and
    secured. The same 128mb clients seem oblivious to the fact that the
    VM is as prone to attack/infection as any other machine on the
    network.
    Daz, Nov 24, 2004
  11. Higgins@work
    Daz Guest
    Now where did I put that Warhammer?
    Daz, Nov 24, 2004
  12. Higgins@work
    Higgins@work Guest
    That would be me then. I just need to convince the lackeys.
