FOAK: Wireless gear
Discussion in 'UK Motorcycles' started by Doki, Sep 22, 2007.
  1. Doki
    Doki Guest
    I've got a load of Netgear WG311 cards. Unfortunately they're the V3, which
    means they're unreliable rubbish. Can anyone recommend an alternative that
    works in both XP and if possible Linux, and works with WEP? I've not got the
    time to keep fucking around with these things in the hope of eventually
    makign them work. I bought 3 from Ebuyer several months ago and have only
    lately gotten round to fitting them and found out that they're rubbish...
    And can anyone recommend an alternative to the Netgear 834G router, as
    whilst I've got one that I'm very happy with, I'm loathe to buy anything
    else from the cunts after they produced a load of shite cards and failed to
    reply to my emails to support.
    Doki, Sep 22, 2007
  2. Doki
    Doki Guest
    Or even WPA. The 311s do work with WEP, but play up with WPA.
    Doki, Sep 22, 2007
  3. Doki
    I had trouble with a Netgear MA311 USB adapter. It worked fine with my
    laptop but not with my new desktop. Netgear replaced it with a newer
    version. Couldn't get that working reliably with either PC. I bought an end
    of line Linksys one from Novatech for a fiver. It works lovely. So does the
    Linksys router it talks to (been going strong for over 4 years).
    So, without being able to identify a specif product to recommend, anecdotal
    evidence suggests Linksys is the brand to seek.
    wessie, Sep 22, 2007
  4. Doki
    Doki Guest
    A fiver? These PCI cards were thirty quid each! I'm a bit loathe to use USB
    though as a) it's not the most reliable thing to get working under Linux
    IME, and b) I get patchy reception with another wireless card that I know
    works at my place in Sheffield, so it's useful to be able to use an external
    aerial.
    Doki, Sep 22, 2007
  5. Doki
    M.Badger Guest
    Have a look at the Pheenet stuff from www.solwise.co.uk
    Claims to support Microsoft Vista/XP and Linux. I run Pheenet wireless stuff
    via PCMCIA or USB, depending on the laptop, under Linux with no issues at
    all.
    When I needed support from Solwise regarding my router, they were quick to
    reply and accurate with the answer. Turned out to be my Blackdown java
    install didn't play quite as nicely as the Sun variant. Not many companies
    would know the difference, let alone on a Linux platform.
    Hopefully their support staff as still as clued up.
    M.Badger, Sep 22, 2007
  6. Doki
    The router was current technology in 2002, so 802.11b. The USB adapter from
    Linksys is an .11b bought in 2005, so fine for me but not sexy enough for
    most people, hence the bargain bin. They had some laptop PC card things for
    the same price at the time IIRC.
  7. Doki
    Timo at Work Guest
    Is that under Linux only or Linux and XP?
    I've got a bunch of WG511 v1 cards which work fine under XP with WPA
    enabled but are a tad annoying to get to work under Ubuntu with WPA as
    they don't do hardware WPA so you've got to fiddle around with
    wpa_supplicant.
    That said, they do work reliably with WPA under both OSs, it's just
    that due to some issues with Ubuntu 7.04, you have to resort to
    command line h4x0ry to get them to connect...
    Anyway, the 511 v2 is supposed to not suffer from this problem. If you
    want to borrow one of the v1 cards to try them out, I should have one
    back in the UK. Drop me a line if you're interested and I'll try to
    find it when I'm back.
    Timo at Work, Sep 22, 2007
  8. Doki
    Doki Guest
    Pheenet? Whoo?
    Cheers.
    Doki, Sep 22, 2007
  9. Doki
    Doki Guest
    Under XP. Not tried them under linux, but apparently it's a problem due to
    the chipset used on the V3 board, which is different to both V1 and V2. IMO
    different chipset = completely different board, and should be a different
    model number - I bought these on the basis of review which were about 90%
    excellent (for the V1 and V2) and 10% poor, all for the V3, which obviously
    gave a good average review score on the site I bought them from.
    Could do. I'm rushed off my feet ATM so wouldn't be wanting to set it up
    for a while yet.
    Doki, Sep 22, 2007
