FOAK: Win7
Discussion in 'UK Motorcycles' started by Derek Turner, May 30, 2011.
  1. Derek Turner
    Derek Turner Guest
    Purely hypothetically, if someone found a Windows 7 Home Premium OEM DVD
    and wanted to try it out, purely for research, on his machine that has
    two linux distributions and XP Home already on it;
    Would the OEM disk simply reformat the whole disk for itself without
    asking (as some previous versions did)? or would he get the chance to
    choose which partition it was temporarily installed on?
  2. Derek Turner
    Every version of Windows for as long as I can remember has let you
    choose which partition to use, & asked if you want to format it. I
    don't know which version you think reformatted a whole disk without
    asking, but I suspect you're wrong.
    Krusty, May 30, 2011
  3. Derek Turner
    Ivan D. Reid Guest
    It would ask which partition to install itself in, I'm sure,
    but I'm also fairly sure it would take over the MBR so you'd have to work
    out how to re-install your Linux boot-loader.
    Ivan D. Reid, May 30, 2011
  4. Derek Turner
    Paul - xxx Guest
    When I did this it asked where I wanted it putting, then made a folder
    called 'Old Windows' or something similar, which had the full contents
    of the old windows install on it. I never tried it as a dual-bbot 'cos
    W7 just suited me far better and I deleted the old windows folder after
    transferring documents etc.
    I have no clue what it'd do to a Linux boot sequence though.
    Paul - xxx, May 30, 2011
  5. Derek Turner
    Steve Parry Guest
    If you're concerned download VMWare player, it's free and you can create a
    vm to run Win 7 in
    Steve Parry
    87 BMW R80RS, 03 BMW R1100S Boxercup, 07 BMW K1200GT SE
    87 Yamaha FS1, Sukida SK90PY,
    91 Kawasaki AR50, 82 Suzuki GN400, BMW 330Ci
    www.gwynfryn.co.uk
    Steve Parry, May 30, 2011
  6. Derek Turner
    It isn't true.
    It's Ebola.
    Pip Luscher, May 30, 2011
  7. Derek Turner
    Derek Turner Guest
    Dos 6.22 certainly did that. So did the floppy-disk version of Win95. Not
    sure about the CD of Win 95 as my mobo wouldn't boot from a CD-ROM then.
    Win NT 3.51 and (I think) 4 did the same. This one my friend (ahem) said
    started the installation without asking which partition.
  8. Derek Turner
    No it didn't.
    No it didn't.
    No they didn't.
  9. Derek Turner
    Ivan D. Reid Guest
    Nods vigorously to all except the "no experience" claim. TBH, I
    don't recall exactly what I did when I put a legit (corporation) copy of
    Win7 on the NetBook; I think I probably just said "sod it" and installed
    the latest Ubuntu over what had previously been in the Linux partition.
    I used to try to have separate partitions for everything, but got
    caught out once when a new install of ubuntu wanted a larger /boot
    partitiion. So these days I usually just reserve 3 for Linux; a sensibly
    sized /, an adequate /swap and the rest for /home. That way you can keep
    /home untouched for upgrades or new distros. I've also gone off
    dual-boot, I rarely use it.
  10. Derek Turner
    Simon Wilson Guest
    Heh. The crn of Microsoft installations. I'm pretty sure the only
    programs that format a disk without asking are called
    virusses^H^H^H^Hviriii^H^^H^H malware.
    Simon Wilson, May 30, 2011
  11. Derek Turner
    Mups Guest
    The only Windows disk I've seen which don't allow you to chose which
    partition to install into are those OEM rescue / re-install disks.
    Mups, May 30, 2011
  12. That's only the Lazy OEM's as well.... our W7xx recovery media boots
    to WinPE and then gives you a multitude of options, inc recovering to
    the factory WIM, Clean Install from the DVD, a nice front end gui for
    diskpart allowing the customers to go totally partition bonkers, as
    well as other useful tools n gubbins.
    Brownz (via Gurgle Gruppez), May 31, 2011
  13. Derek Turner
    Derek Turner Guest
    Exactly. That's what my friend has and that was why I asked the question.
    Derek Turner, May 31, 2011
  14. Derek Turner
    Paul - xxx Guest
    ... and they don't work without some effort on other make computers.
    Paul - xxx, May 31, 2011
  15. Apart from Dell OEM ones (Win XP), which is what I've been running on a
    series of non-Dell PCs for years. Sure, it wants to phone home, but it's
    just told 'no' right at the start.
    Grimly Curmudgeon, Jun 2, 2011
  16. Derek Turner
    Paul - xxx Guest
    Interesting to know .. ;)
    Paul - xxx, Jun 2, 2011
