FOAK: Wifi recommendation.
Discussion in 'UK Motorcycles' started by SD, Jan 13, 2006.
  1. You have an unusually warped mind? Even for this place.
    Because if you're going to sling the dirt at them, then making sure it
    is accurate reduces the opportunity for a smart comeback.
    Work in progress, Jan 14, 2006
  2. In uk.rec.motorcycles, SD amazed us all with this pearl of wisdom:
    I bought a Linksys modem/router and laptop card for 40 quid out of
    PCWorld a couple of weeks ago. Piece of piss to set up (with some
    telephone help) and has everything in the box for hard wired and
    wireless stuff.
    It's -not.bad- but it does take some getting used to, it can be slow, it
    can just drop the signal for no reason and I generally found it to be
    not as good as wired and have gone back to wired. That said though, if I
    really do need to play Doom while I'm sitting in the shitter then Wi-Fi
    is a good thing.
    Whinging Courier, Jan 14, 2006
  3. SD
    Buzby Guest
    Totally agree - I have the DG834GT which has performed faultlessly since
    the 5 minute installation a year ago.
    Buzby, Jan 14, 2006
  4. SD
    Rope scribbled on the back of a napkin:
    AOL - all the wireless gear here is Netgear and it "just works". Mind
    ewe, me being me, I bought one of their "industrial strength" access
    points as opposed to their normal consumer items.
    Timo Geusch, Jan 14, 2006
  5. SD
    SD Guest
    What's the difference between this and 192.168.1.1 ?
    Both you and Pipex suggest "0.1", but D-Link manual suggests "1.1",
    which doesn't have the same boxes to fill in as Pipex's "0.1"
    screenshots.
    SD, Jan 14, 2006
  6. SD
    SD Guest
    PS "0.1" gives "The page cannot be displayed" error message.
    SD, Jan 14, 2006
  7. Using the patented Mavis Beacon "Hunt&Peck" Technique, SD
    If the manual says '1.1', use that. The exact address will vary
    depending on the router and your current network config.
    In fact, at this point, start a command prompt, type "ipconfig" and post
    the results here.
    Wicked Uncle Nigel, Jan 14, 2006
  8. SD
    SD Guest
    Ah. Bit of a clue here ...
    IP Address 192.168.1.2
    Subnet Mask 255.255.255.0
    Default Gateway 192.168.1.1
    SD, Jan 14, 2006
  9. Using the patented Mavis Beacon "Hunt&Peck" Technique, SD
    That's the puppy, then.
  10. SD
    SD Guest
    I thought it might be. I'm not quite as green as I'm cabbage-looking,
    you know. Ta.
    <signs off>
    SD, Jan 14, 2006
  11. Using the patented Mavis Beacon "Hunt&Peck" Technique, SD
    Right, that's got rid of him for a few months.
  12. Isn't it past your bed time son?
  13. Using the patented Mavis Beacon "Hunt&Peck" Technique, Work in progress
    "Call it an Oedipus Complex if you like, but I want my mummy!".
  14. SD
    SaladDodger Guest
    Yoo Hoo!
    It's me. ;-p
    SaladDodger, Jan 14, 2006
  15. SD
    SaladDodger emerged from their own little world to say
    another glass of Chablis, thanks
    wessie, Jan 14, 2006
  16. Using the patented Mavis Beacon "Hunt&Peck" Technique, SaladDodger
    Excellent. On the new configuration?
    Pint of Hobgoblin, please.
  17. SD said
    <tries not to think about it> <fails> Wear mittens.
    Work in progress, Jan 15, 2006
  18. In uk.rec.motorcycles, Rope amazed us all with this pearl of wisdom:
    My Sister bought one at the weekend and could I get her laptop to talk
    to the modem? Could I buggery...
    Whinging Courier, Jan 15, 2006
  19. SD
    SD Guest
    Sort of.
    'old yer 'orses.
    The BigBox talks to the internet.
    The laptop does, too. Occasionally. And Slowly.
    They do not appear to know that the other exists.
    They've both had that big long code thing keyed in[1], and the
    192.168.1.1 thing knows that they both exist.
    I've tried setting up a w/l n'work manually, but it seems I need a USB
    flash drive - or does that just save the typing?
    [1] A right PITA on an unfamiliar lappy k'bd.
    SD, Jan 16, 2006
  20. Using the patented Mavis Beacon "Hunt&Peck" Technique, SD
    Hmm... Dunno. I'd have thought so.
    Does your lappy Wi-Fi connection report a signal strength?
    What's the output from running 'ipconfig' on the lappy?
    What's the output from 'ping www.google.com' on the lappy?
    Who won the F.A. cup in 1923?
    Wicked Uncle Nigel, Jan 16, 2006
