FOAK: Welding helmets/masks
Discussion in 'UK Motorcycles' started by Buzby, Dec 2, 2010.
  1. Buzby
    Buzby Guest
    Screwfix as done it to me again and I seem to have acquired a mig
    welder for a not a lot and as I know there's a few wot know about these
    things I though I'd ask.
    Whats the preference for welding helmets/masks? Are the light sensitive
    ones found all over that auction site any good? I also wear glasses
    which may or may not be an issue I suppose.
    This will probably end in tears (see sig).
    TIA
    Buzby, Dec 2, 2010
  2. Buzby
    JB Guest
    Get an light-sensitive (LCD) one. They are excellent, especially for a
    beginner. Look for one which can be adjusted for shade (8-12 is adequate for
    a small MIG), and also adjusted for response time (sensitivity).
    I've got 2 cheap ones and a damned expensive one and they are all pretty
    good. I've cut down one mask to get into hard to reach places.
    JB
    JB, Dec 2, 2010
  3. Buzby
    Adrian Guest
    This the Kende 150 that they're punting out for £130?
    Have a look at this - might be a chunk too powerful, with a minimum 60A
    setting...
    http://www.mig-welding.co.uk/forum/showthread.php?t=8035
    Otherwise, though, I've just succumbed and bought a second-hand Cebora
    130 on fleaBay - so I'm in the same boat as you...
    Adrian, Dec 2, 2010
  4. Get a light-sensitive automatic one, they're *so* worth the money.
    Chris Bartram, Dec 2, 2010
  5. Buzby
    Buzby Guest
    That's the one. I fully expect to be burning holes in everything, most
    likely starting with the garage. . . .
    Buzby, Dec 2, 2010
  6. Buzby
    Buzby Guest
    Thanks - will investigate
    Buzby, Dec 2, 2010
  7. Buzby
    Buzby Guest
    Now having done my research after the event[1] I think I might put
    their returns policy to the test.
    [1] In line with SWMBO's M&S policy
    Buzby, Dec 2, 2010
  8. Buzby
    Malc Guest
    For some reason I read the title as Wedding Helmets/Masks AISMPS
    Malc, Dec 2, 2010
  9. Buzby
    Absolutely. Though I've found that an inspection lamp placed overhead
    can cause mine to darken unexpectedly.
    Pip Luscher, Dec 2, 2010
  10. Buzby
    Buzby Guest
    Recommended make or are they all much the same?
    Buzby, Dec 2, 2010
  11. Yep. I bought a cheapy auto one a few years ago and it's still working
    fine. You can, of course, pay as much as you want.
    Never had a problem with binns and welding helmets of any type.
    Grimly Curmudgeon, Dec 2, 2010
  12. Buzby
    I'm not in a position to recommend, TBH, as I've only used the one.
    Mine's a Sealey, I think; it was supposedly on special offer at the
    local tool emporium.
    It does the job; has adjustable tint.
  13. I've got a cheapy light sensitive one.
    Same here with binns, no problems.
    Best thing to have next to a decent pair of welding gloves.
    Turning the florescent lights on over the bench some time will trigger
    it.
    Mick Whittingham, Dec 3, 2010
  14. Buzby
    Donnie Guest
    Ditto, got my helmet from fleabay, about 28 quid and postage, auto
    darkening the lot, excellent and has a grinder setting too.
    Donnie
    "**** the world, it's time to fight back"
    Lambretta Series 2 186cc "The Shitter"
    Lambretta LD 175cc "The Chopper"
    Honda CB500R "Look out, Donnie's about!"
    Donnie, Dec 4, 2010
