FOAK: Volume
Discussion in 'UK Motorcycles' started by Cane, Sep 14, 2004.
  1. Cane
    You keep banging on about this. A litre is a unit of volume. One litre
    of water has the same volume as one litre of air, in exactly the same
    way that one pound of feathers has the same mass as one pound of lead.
    If he was asking what _mass_ of water could be held within that cylinder,
    you might have a point. But he didn't, and you're starting to get very
    repetitive in an "I'm a smart arse and I know better" kind of way.
    ogden, Sep 14, 2004
    #61
  2. Cane
    Robbo Guest
    Try this calculation then
    Consider a circle of radius a (the end of the tank) and imagine that
    the liquid has reached height h, measured from the lowest point on the
    circle. Note that 0 <= h <= 2a. The area A of the segment of the
    circle covered by the liquid is:
    A = pi*a^2/2 - a^2*arcsin(1-h/a) - (a-h)*sqrt(h(2a-h))
    The volume of liquid is just A*L, where L is the length of the tank.
    OK !!!
    Robbo
    1500GL 1988 Goldwing (Halfway rebuilt)
    BMW K100 RS 1984
    B.O.S.M 2003, 2004 .FURSWB#1 KotL..YTC449
    PM#7
    Robbo, Sep 14, 2004
    #62
  3. Cane
    gomez Guest
    First time I mentioned it. And the point is still being missed.
    gomez, Sep 14, 2004
    #63
  4. Depends if it's hollow, and how hollow it is, obviously.
    Whinging Courier, Sep 14, 2004
    #64
  5. Cane
    PeterT Guest
    Cane
    No worries. One question, one answer. As you didn't ask
    how to calculate this, I didn't bother typing out long equations,
    and still getting them wrong as so many others here. ;-)
    PeterT, Sep 14, 2004
    #65
  6. Cane
    What a very IBM answer.
    Muck, Sep 14, 2004
    #66
  7. Cane
    Cane says...
    None if it has no bottom.
    Lozzo, Sep 14, 2004
    #67
  8. Cane
    Ginge Guest
    Hardly, the first question IBM might ask is whether there is anything
    else in the cylinder before the water is added.
    and then it'd be a question of whether that item floated...
    and then...
    <breathes out, and thinks of far away places>
    Ginge, Sep 14, 2004
    #68
  9. Cane
    tallbloke Guest
    Temperature and pressure?
    tallbloke, Sep 14, 2004
    #69
  10. Cane
    I was thinking along the lines of totally correct but useless answers.
    Muck, Sep 14, 2004
    #70
  11. Cane
    Steph Guest
    They're going to be bloody heavy - approx 992 pounds or almost 71 stone
    each. I hope they're not planning on standing them on some cheap display
    unit or on an unstrengthened floor.
    Shame they'd be crap for keeping fish, or I'd ask you to make some for
    me too - surface area is too small <sulk>
    Steph, Sep 14, 2004
    #71
  12. Cane
    mups Guest
    Ginge says...
    IBM would insist that you use their hugely expensive dihydrogenoxide
    rather than 'ordinary' water.
    mups, Sep 14, 2004
    #72
  13. Cane
    Weight could be cut substantially by putting a smaller cylinder inside, with
    about a 1" gap all round, and only fill the space between the cylinders with
    water. This will give you a cylindrical shell of water - if they're
    planning to bubble air through, for instance - and a dry core for lighting
    or display. In fact, you could run all sorts of interesting lighting
    effects on the inner cylinder a la perspex dinosaurs.
    platypus, Sep 14, 2004
    #73
  14. Cane
    mups says...
    and then...
    Lozzo, Sep 14, 2004
    #74
  15. Cane
    Ben Blaney Guest
    You don't understand - though Cane will have, having heard me expound
    on this theory: all quantities are "some" and all foreign money is
    "things".
    Ben Blaney, Sep 15, 2004
    #75
  16. Cane
    That'll be the "Blaney code".
    Muck, Sep 15, 2004
    #76
  17. Cane
    Mark Olson Guest
    If you'd said ~460 litres you wouldn't be wrong, but 462 is a
    wrong answer.
    olsonm@debian:~$ echo '4*a(1) * (650/2)^2 * 1400 / 10^6'| bc -l
    464.56301364959067513431
    Mark Olson, Sep 16, 2004
    #77
  18. Cane
    tallbloke Guest
    Do keep up at the back!
    tallbloke, Sep 16, 2004
    #78
  19. Cane
    Wizard Guest
    OY!
    <8P Wizard
    Suzuki GS550 "I like that. Nicely shite" - TOG
    Golf GTi 16v
    ANORAK#17b BOMB#19 BOTAFOT#138 BREast#5 COFF#24
    COSOC#8 DFV#11 STG#1
    Wizard, Sep 16, 2004
    #79
  20. Cane
    FFS find the snipping wizard, will you? It is becoming tiresome
    having to scroll through a screenful of quoted text to find your
    single-line addition at the bottom.
    Pip, Sep 16, 2004
    #80
