FOAK: Using AC-DC Adapters in the USA
Discussion in 'UK Motorcycles' started by Elly, Mar 15, 2006.
  1. Elly
    Elly Guest
    Right then, I'm not afraid to admit that I'm a complete numpty when it
    comes to thing electrical. This being the case, I would appreciate
    any advice you seasoned travellers have about adaptors.
    The story so far ...
    I have an iRiver H10, lovely little thing it is, I'm planning to take
    it to the States with me in a bit over a week so that I don;t have to
    put up with my lecturer's choice of music in the minibus.
    As yet they don't do a car charger for this, so I did a bit of delving
    around and worked out that I probably needed a step-up converter to
    enable me to charge it from the mains whilst I'm out there. I bought
    one, it's arrived and guess what, due to the orientation of the UK
    charger (big sticky up bit above the earth pin) it doesn't bloody fit!
    Aaargh (1).
    However, having read the numbers on the back of the charger, I'm
    wondering whether it will work out there with the correct travel plug
    adapter. It says that the input is 100-240V ~ 50/60Hz 350mA - the
    input on the step-up adapter says 110V ~ 50/60Hz.
    Now I'm sure there's probably some fundamental electrical thing that
    I'm missing here but surely if the input ranges from 110-240V I should
    be able to use it in the States without the step-up converter?
    Any advice would be very much appreciated.
    (1) Yes I am truly a fuckwit for not checking first, I know.
    Elly - a confuzzled Pixie
    ZX9R-E1 - <Giggles>
    Spike - FZ400 - It's dead Jim!
    MRO#32 ibW#25 BoTAFOT#46 BoTAFOF #46 GP#1 UKRMRM#00 TWA#3
    http://www.garagepixies.co.uk
    elly at garagepixies dot co dot uk
    Elly, Mar 15, 2006
  2. Elly wrote
    Buy a charger/adapter locally. I had a result when I was in Jamaica
    when I bought a charger that outputs 3-15V through half a dozen
    different sized plugs and runs on *anything* as long as it is mains.
    350 bucks local it cost @ 106 to the pound.
    Ditch the ginger git and come over to a real man.
    steve auvache, Mar 15, 2006
  3. Elly
    Ali Hopkins Guest
    You can definitely use it without the step up converter, all you need it a
    three to two pin adapter. Which you can buy at LHR or wherever, if you
    don't find it elsewhere. Did it not come with one? Don't leave it till you
    get to the US, btw, it's damn difficult to get UK to US plug adapters
    anywhere except airports over there. I've used loads of devices over there.
    Ali
    Ali Hopkins, Mar 15, 2006
  4. Elly
    Switters Guest
    Yes, you can use it as is. Just get a travel plug and you're sorted.
    No comment.
    Switters, Mar 15, 2006
  5. Elly
    simonk Guest
    That will work fine - as will many laptop, phone and gadget chargers - just
    read the voltage rating.
    All you need is the relevant US 2-pin adapter.
    simonk, Mar 15, 2006
  6. Elly
    Timo at Work Guest
    Yep, get a travel plug at the airport, sorted. Alternatively if the
    Spiccy one is going to come around to pick up that battery he's
    supposed to pick up sometime next week before you leave, I should have
    a spare one that you can borrow.
    Timo at Work, Mar 15, 2006
  7. Elly
    Elly Guest
    <snip electrickery numptiness>
    Thank you all ... I shall source the relevant travel plug adapter.
    Elly - a less confuzzled Pixie
    ZX9R-E1 - <Giggles>
    Elly, Mar 15, 2006
  8. Elly
    Elly Guest
    <grins>
    Elly - a tired Pixie
    ZX9R-E1 - <Giggles>
    Elly, Mar 15, 2006
  9. Yep, many of the external chargers/PSUs these days are 'World' rated. It
    should be fine to plug it in once you get to the States. As far as the
    physical plugging in goes... you need to make up a short flylead with a
    single trailing 13A UK socket on one end for your charger and a US plug
    on the other.
    GS850x2 XS650 SE6a
    Folding@Home Team UKRM
    Grimly Curmudgeon, Mar 15, 2006
  10. remind me to leave a couple out when you pop over next week.
    Adie
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=4583091887
    Triumph 955iSS / ZX9R / GSF1200 bandit (for sale) / CG125
    Adrienne M Bonwick, Mar 15, 2006
  11. Where abouts you going again? how long for?
    Just that it seems that I'll be heading that direction on April 3rd too.
    Dnc
    B1200 - +30bhp ~|~ ZZR1100 - faster when upright
    V2300 - flat cap and rug ~|~ A6 2.5TDi V6 Quattro Sport
    DoetNietComputeren, Mar 15, 2006
  12. Elly
    ChrisDC Guest
    I have the same bit of kit, bought in a recent trip to Japan.
    Yes, your 100-240 input adaptor will work in the states, you may need
    a physical adapter so it can be plugged into their mains.
    You do NOT need a step-up adapter.
    I find a more convenient option is to use a variety of USB power
    adapters, these let me charge it from - a USB port, the mains, a 12V
    cigar plug and so on.
    ChrisDC, Mar 15, 2006
  13. Elly
    Elly Guest
    Will do, cheers :)
    ZX9R-E1 - <Giggles>
    Elly, Mar 15, 2006
  14. Elly
    Elly Guest
    Southwest USA taking in amongst other things Meteor Crater, The Grand
    Canyon, Mt Zion National Park, Glen Canyon Dam and Monument Valley.
    We'll be arriving in Las Vegas on April 3rd and then heading back to
    LA to fly home on April 5th.
    ZX9R-E1 - <Giggles>
    Elly, Mar 15, 2006
  15. Gah. So close.
    Landing on the 1st, I have a free day in LA on the 2nd. Then flying from
    LA to Chicago on the evening of the 5th.
    Small world.
    Dnc
  16. Elly
    Elly Guest
    Indeed!
    We depart LA at 20:50 on 5th April - maybe see you at the Airport :)
    ZX9R-E1 - <Giggles>
    Elly, Mar 15, 2006
  17. [elly's escapade]
    Should be good - not seen any of those other than on the telly.
    You'll barely get past the jet lag before coming back! That's a hell of
    a long way to go for a rampaging tour spread over 2 and a bit days.
    Have a good time nonetheless.
    Paul Corfield, Mar 15, 2006
  18. Elly
    Elly Guest
    Ah, what I neglected to mention was that we actually start off in Los
    Angeles on 27th March and do all the above before arriving at Las
    Vegas on 3rd April.
    Even so, looking through the field course guide, it's going to be a
    hell of a trip nontheless. We'll be in a different hotel every night
    of the trip apart from spending 2 nights in Williams and 2 nights in
    Las Vegas.
    The bizarre thing is that this year's first years aren't interested in
    doing this field course in their second year. Only 12 have signed up
    compared to about 40 of us this year.
    ZX9R-E1 - <Giggles>
    Elly, Mar 15, 2006
  19. Elly
    Elly Guest
    Fortunately this step-up adapter only cost me £6.50. I'll have to see
    if I can shift it on Ebay at some stage.
    ZX9R-E1 - <Giggles>
    Elly, Mar 15, 2006
  20. Elly
    Switters Guest
    Pssst... guys... fight behind the bike shed, after school, pass it on.
    Switters, Mar 16, 2006
