FOAK: USB - Serial Adaptors
Discussion in 'UK Motorcycles' started by Krusty, Jun 2, 2006.
  1. Krusty
    Do they always work on all kit, or more specifically, will they work
    for connecting a Power Commander (serial) to a USB-only laptop? Any
    recommendations on what/where to buy?
    Krusty.
    http://www.muddystuff.co.uk
    http://www.muddystuff.us
    Off-road classifieds
    Krusty, Jun 2, 2006
  2. Krusty
    catman Guest
    Definitely not, no. Things have probably improved these days though
    Not really. I'd aim for one that claims 100% compatability if it was
    critical. Hopefully SWK from direct experience will be along soon.
    Alternatively my new toughbook has serial port if you're anywhere near
    Chavnorth
    www.cuore-sportivo.co.uk
    catman, Jun 2, 2006
  3. Bought a random cheap one from my local pc shop for talking USB laptop
    to Clifford car alarm. That worked fine, first time. If you want me to
    find out the exact details then I can have a look when I get in.
    You'll probably be fine - just grab the first one you see...
    (You do have some other form of transport to take the fused Power
    Commander to a workshop right ?)
    Bryan.Williams, Jun 2, 2006
  4. Krusty
    Swot I feared, & they seem a bit expensive to take a risk on.
    I've got an old Dell laptop with a serial port, but no screen. I could
    probably use that by VNC'ing from the other laptop if necessary. Ta for
    the offer though.
    Krusty.
    Krusty, Jun 2, 2006
  5. Krusty
    antonye Guest
    Dunno about all kit, but Mitch The Mechanic uses one to
    program the PCIIIs on the dyno using his Dell laptop.
    antonye, Jun 2, 2006
  6. Krusty
    Ooh - just the sort of answer I was looking for, except for the one
    vital part... Any way of finding out which one he's got?
    Krusty.
    Krusty, Jun 2, 2006
  7. Krusty
    Switters Guest
    I got one to program my GPS from my laptop. I also used it once to drive
    a friends old plotter that was serial only after their computer died.
    Both occassions it worked first time. Mine was a Targus job I think.
    Switters, Jun 2, 2006
  8. Krusty
    antonye Guest
    I don't know off hand, but I will email him and find out.
  9. Krusty
    Thanks, you're a star.
    Krusty.
    Krusty, Jun 2, 2006
  10. Krusty
    antonye Guest
  11. Krusty
    Excellent - thank you kindly.
    Spamming ****.
    Krusty.
    Krusty, Jun 2, 2006
  12. The computer radio I use is a serial port version and several folk have
    recommended converters based on particular chip - I'll have a look for
    it later.
    Grimly Curmudgeon, Jun 2, 2006
  13. Krusty
    antonye Guest
    I aim to please.
  14. Looking up old posts relating to this, I find mention of the maker
    'Prolific' and the figure UC310 on ones that work. 'Buxcomm' and Radio
    Shack cheapies too. Probably the most predictable might be the Belkin
    F5U409.
    Grimly Curmudgeon, Jun 3, 2006
  15. Krusty
    I lugged the screenless laptop & a monitor down to the garage last
    night to check it could actually talk to the PCIII before investing in
    an adaptor (this laptop has a serial port). The software found the
    PCIII ok, but when I tried to download the current map it said "File
    and Power Commander version incompatible".
    Googling suggests this means the software can't find the PCIII on the
    selected port, which definitely doesn't apply in my case (the TPS
    reading on the screen changed with throttle movement, & I could read
    the hardware info from the PCIII). So I'm a bit stumped now.
    Krusty.
    Krusty, Jun 3, 2006
  16. Krusty
    catman Guest
    Indeed, although everyone seems to think they will work.
    That'll be fun :)
    catman, Jun 3, 2006
  17. Krusty
    It would've if it had worked. The garage is just out of range for the
    wireless router though, & I couldn't be arsed to dig out a crossover
    cable. So I lugged a monitor down to the garage instead!
    Krusty.
    Krusty, Jun 3, 2006
  18. Krusty
    catman Guest
    Most modern (ish) stuff shouldn't really need a crossover, you know....
    catman, Jun 3, 2006
  19. Krusty
    Really? I didn't know that, no.
    Krusty.
    Krusty, Jun 3, 2006
  20. Krusty
    antonye Guest
    We had exactly the same problem, but I can't remember how
    we fixed it...
    I think it's something to do with the map being hand programmed?
    It doesn't like trying to download a hand programmed map compared
    to one that has been adjusted through software.
    antonye, Jun 3, 2006
