FOAK U/D fork fiddling
Discussion in 'UK Motorcycles' started by Pete Fisher, Jan 18, 2010.
  1. Pete Fisher
    Pete Fisher Guest
    Today I returned from Magnum with an Avon club race tyre fitted on a
    17inch 3.0 rim built on to a spare front hub for the YZ250.
    I had carefully measured up clearances and checked tyre dimensions
    before plumping for a 120/70. I went for the AM22 partly because I have
    a suitable AM23 already that will drop on to the standard rear rim,
    partly because I liked AM22/23 when I had the Husky, and partly because
    there was good deal on Ebay for one in what, by the thumbnail test once
    it arrived, is a nice sticky compound.
    I had new bearings fitted while the wheel was being built and on putting
    it in was pleased to see that my fettled oversize disc and caliper
    fitted with fancy pads all came together without a hitch. It certainly
    revealed how knackered the bearings in the old wheel were. Spun well
    with a nice brake action, at hand spin speed anyway.
    It was always going to be a tight squeeze on the way up through the fork
    stanchions and slider protection guard guides but my calculations had
    predicted a safe margin for error.
    What I had omitted to take account of though was that the wheel is very,
    slightly offset between the stanchions. The rim is perfectly aligned,
    and I notice that the lad's YZ85 is similar, except offset towards the
    brake side. I was pretty certain I hadn't left a spacer off the spindle
    or got them in the wrong way, and quick check with a straight edge shows
    that the wheel centre is perfectly in line with the centre of the
    steering head.
    I've used all kinds of dodges to try and measure that all will be well,
    but can't be certain. Not being a fat bastard, I can't lunge the forks,
    even with the tyre up against a wall hard enough to get the widest bit
    of tyre through the gap IYSWIM. I can get it close enough to see it is
    going to be close, but not enough to ensure clearance.
    I can get the bike up on a stand with the forks fully extended and wheel
    clear of the ground, so I wondered about taking off the top nuts so that
    I could then let it down and the wheel should travel up to its limit.
    Are the springs going to escape with great force and will I get them
    back in to place again?
    The conventional Marzocchis on the Morinis are fine in this respect but
    I've never opened up U/D forks.
    In the worst case scenario I reckon I can remove the slider guards and
    guards to gain a couple of mm., as I know of at least one NHCA rider of
    a MX bike (another 250 as it happens) that has done the same. No
    shrapnel being thrown up by the bike in front on hill climbs!
    | Pete Fisher at Home: |
  2. Pete Fisher
    davethedave Guest
    Ratchet straps?
    davethedave, Jan 18, 2010
  3. Pete Fisher
    Pete Fisher Guest
    Now there's a thought. I've got a pair of FOAD ones that use on the
    trailer.
