FOAK, TV on computer monitor.
Discussion in 'UK Motorcycles' started by Paul - xxx, Oct 27, 2009.
  1. Paul - xxx
    Paul - xxx Guest
    I have a laptop, that I also use in the caravan to stream TV
    occasionally, which is fine so long as I have a good signal. So I got
    to thinking, are there external TV tuners available that can output to,
    say, a computer (VGA) monitor?
    Or can you get such a thing as a TV to VGA cable? Had a search of
    Maplins and couldn't find anything suitable.
    Main reason is I have a small 10" monitor that's a brilliant size for
    our small caravan and if I could hook this up to, say, a Freeview box
    or somesuch then it'd be ideal to just leave in the 'van instead of
    having toi take the laptop everywhere .. caravans being known for their
    security and such .. :)
    Anyone any ideas, pointers, links etc ... Cheers .. :)
  2. Paul - xxx
    Derek Turner Guest
    For less than £20 you can get a frewview USB dongle. Needs windows to
    work though.
    Derek Turner, Oct 27, 2009
  3. Paul - xxx
    Dr Zoidberg Guest
    http://www.avermedia.eu/avertv/UK/Product/ProductDetail.aspx?Id=281
    Dr Zoidberg, Oct 27, 2009
  4. Paul - xxx
    You can certainly get scart to vga cables, & you can plug a freeview
    box straight into a monitor using s-video (if they both support it).
    Whether a freeview box would work with a scart to vga cable though I
    know not.
    Krusty, Oct 27, 2009
  5. Paul - xxx
    Dave Emerson Guest
    Try
    http://www.7dayshop.com/catalog/product_info.php?products_id=106147
    Dave Emerson, Oct 27, 2009
  6. Paul - xxx
  7. Paul - xxx
    DozynSleepy Guest
    I've got a KWorld TVBox 1440. Plugs into your monitor vga port and
    allows you to plug in normal AV, S-Video etc from a freeview box, dvd
    player, xbox 360 or PS2. This one also has an analog tuner built in.
    Search for VGA Gamer Box.
    http://www.maplin.co.uk/Media/PDFs/A18GX.pdf
    I've just done a search "Kworld TVbox 1440" and you should be able to
    pick it up for around £35 delivered (ebay 150383711583 £23.50 or
    250507015862 £35) or some online retailers have it stock .
    Can't see any with DVB built in which would save an extra box.
    There are newer models out.
    http://www.kworlduk.com/TVBOX-VGABOX-PlayXBoxOnTFT/index.kworld
    DozynSleepy, Oct 27, 2009
  8. Paul - xxx
    Dave Emerson Guest
  9. Paul - xxx
    Paul - xxx Guest
    Many tanks for the responses, much appreciated. Now I know more what
    to lok for it's a damn sight easier. ;)
  10. Paul - xxx
    I usually find it helps, yes.
    Krusty, Oct 28, 2009
  11. Paul - xxx
    ian field Guest
    Depends on the freeview box.
    Years ago I bought a freeview USB stick which turned out to be a complete
    POS, so I bought a scart converter for the PC, out of several STBs only one
    was compatible.
    Some freeview boxes can be changed in the setup menu between composite video
    and RGB output, so that's worth checking before you give up.
    ian field, Oct 31, 2009
