FOAK: trackdays with a "more mature" bike?
Discussion in 'UK Motorcycles' started by Pip Luscher, Aug 19, 2005.
  1. Pip Luscher
    Anyone got any idea / opinions about just how high a mileage a bike
    can have before it's not worth taking on a track day?
    It's just that in the last four track days that I've been on, three
    ended prematurely due to mechanical failure:
    1) FZR600 exhaust camshaft failed on session 2 in the morning
    2) same bike, new engine, head gasket failed (well it was leaking
    before the trackway, I just hadn't twigged what the problem was) just
    before lunch.
    3) This year, TLR radiator leak.
    The TL's got over 34K miles on it and I'm wondering whether it's worth
    the risk. It ticks when warm but the general consensus seems to be
    that it's the scissor gears rattling - they're known to produce odd
    noises.
    Anyone?
  2. Pip Luscher
    How did this fail? As in what way did it fail? It can be because of
    lubrication, dirt, cam tensioner, lobe wear... all sorts.
    Doh.. leaking head gaskets can be a sign that the engine has been in an
    overhead condition at some point in the past.
    Radiators can get pinged with all sorts of crud. It may have been
    corroded though.
    Get someone to have a look / listen to it, service it, or at the very
    least, give it an oil change with some good synthetic before you go to
    the track.
    No idea about TL noises.
    Muck, Aug 19, 2005
  3. Using the patented Mavis Beacon "Hunt&Peck" Technique, Muck
    That's Platy's Drifter fucked then...
    and Ducati Race Engineer.
    Wicked Uncle Nigel, Aug 19, 2005
  4. Pip Luscher
    tallbloke Guest
    Follow this advice.
    tallbloke, Aug 19, 2005
  5. Pip Luscher
    ITYM "more fucked"
    sweller, Aug 19, 2005
  6. Using the patented Mavis Beacon "Hunt&Peck" Technique, sweller
    Good point, well made.
    I am obliged.
  7. Pip Luscher
    platypus, Aug 19, 2005
  8. Pip Luscher
    Oh fucking hell.. my fuddly fingers.. Overheat not overhead...
    <skulks off muttering>
    Muck, Aug 19, 2005
  9. Pip Luscher
    tallbloke Guest
    muck@_TEETH_rulex.net (Muck) wrote in muck@_TEETH_rulex.net:
    Don't let your head get overheated ;-)
  10. Using the patented Mavis Beacon "Hunt&Peck" Technique, Muck
    Actually, some of us would say that you should cut all your fingers
    off[1] for using the phrase "in an overheat condition", when "has
    overheated" would have sufficed.
    [1] Or should I say "place yourself in a zero digital extremity
    scenario"?
  11. Pip Luscher
    Monz Guest
    Linked, of course [1]
    [1] Yes, I know car brakes are linked anyway [2]
    [2] WTF are we discussing cars for
    Monz, Aug 19, 2005
  12. Pip Luscher
    Monz Guest
    oooooooooooooooooooooooooooooh
    Monz, Aug 19, 2005
  13. Pip Luscher
    Flange on the end broke up. Debris worked its way along the camshaft
    tunnel, thus got caught under the cam lobes. Result: three stuck
    valves and one piece got punched through the cam tunnel wall,
    liberating oil all over the exhausts...
    Engine from a breaker. History unknown.
    Corroded. In fact, I had a replacement all lined up, it just beat me
    to it...
    Already had someone who knows TLs listen - he reckoned it's not a
    problem - probaby the scissor gears or maybe the decompressors.
    I've already given it a full service at 30K miles: this includes the
    valves etc. Nothing untoward.
    The problem is, having been spat off at around 80 by the Head Gasket
    incident and spent a month hobbling, I tend to be very cautions
    nowadays.
    Pip Luscher, Aug 20, 2005
  14. Pip Luscher
    Bad form etc.
    I see what you meant. I always ensure that bikes have fresh oil at
    most a few hundred miles before taking on a track and I *always* check
    them over the day before the track day itself - be silly not to.
  15. Pip Luscher
    That's nasty. :/
    I think that maybe Suzukis tend to get a bit noisy when they've got any
    miles on them. Well.. not only Suzukis. My Yamaha is a bit noisy, but
    judging by the other FZR250s I heard, they all do that sir. :)
    Was that at a track?
    Muck, Aug 20, 2005
  16. Pip Luscher
    Sounds as though you've just had some bad luck with bikes on track days,
    and there's nothing much you can do about that.
    Muck, Aug 20, 2005
  17. Pip Luscher
    Between Bridge and (I think) Priory on the Silverstone International
    circuit - absolutely loved it. Until the crash, that is. Luckily I
    hadn't got the hang of Bridge corner - kept going too deep and
    squaring it off - or it might have been faster still.
  18. Pip Luscher
    Look on the bright side. At least there were no cars, and all the
    traffic was going in the same direction.
    Muck, Aug 20, 2005
  19. Grimley_Feindish, Aug 20, 2005
  20. Pip Luscher
    Heh! Nice try. Unfortunately I doubt I could raise more than 3 - 3.5K
    ATM if I sold the TL.
    I've been spending money like water lately in an effort to tart the
    house up ready for sale. Once it's sold, though, I may be able to
    liberate a bit of capital, depending on what I get for it...
