FOAK: Tokico 6 pots
Discussion in 'UK Motorcycles' started by Sean Hamerton, Feb 13, 2011.
  1. My Google mojo eludes me, but I'm sure I read on here or elsewhere
    that it was a common fix to swap them for 4 pot calipers of some
    variety which bolt straight on.
    Anyone know which calipers I'm thinking of? The 6 pots on my SRAD are
    pissing me right off - I'm sure they've warped ANOTHER set of discs
    and I really can't be arsed rebuilding them again.
  2. Sean Hamerton
    Depending on the mounting bolt spacing you have a variety of options.
    If the spacing is 90mm you can use Tokico 4 pots from the later GSXR600
    and 750 or SV1000, you can also use Bandit 1200 or Triumph Nissin 4 pot
    calipers. The best ones to use are the quite rare 6 pot Nissins[1]
    found on the ZX7RR and Triumph Daytona 1200 SE.
    If it's 65mm your options are limited to 4 pot Tokicos from other SRADs
    and some Brembos, but the discs need spacing when you use the Brembos.
    [1] There are a set in my kitchen at the moment, destined for fitment
    to a ZX7R
    Lozzo
    they churn out)
    Lozzo, Feb 13, 2011
  3. Sean Hamerton
    feeble fucker - 1st hit got the lozzo anorak's pontification at
    https://groups.google.com/d/msg/uk.rec.motorcycles/eF19e3pfgHs/wOQZ7nb-m4gJ
    4 pots off the K1/2/3 version of the GSXR750
    wessie, Feb 13, 2011
  4. Sean Hamerton
    put that anorak in the wash you dirty fucker
  5. Sean Hamerton
    SIRPip Guest
    SIRPip, Feb 14, 2011
  6. All noted. Knew you'd have the answer. Which are the better 4-pots?
    Tokico or Nissin?
    Sean Hamerton, Feb 14, 2011
  7. Sean Hamerton
    Nissin, without a doubt. Tokicos are bare alloy on the working bits,
    Nissins are hard anodised all the way round. Nissins don't corrode,
    Tokicos do.
    Lozzo
    they churn out)
    Lozzo, Feb 14, 2011
  8. Sean Hamerton
    If the Nissins are hard to come by and ignoring the possible requirement
    for adaptor plates, not in themselves hard to do, Brembo Goldlines
    abound on eBay. Last set I bought were ~£50 pair (I've 2 spare sets
    tucked away for projects). Gold anodised and don't corrode. Obviously
    work pretty well.
    Hog, Feb 14, 2011
  9. I got that impression from your post.
    eBay has done sorted me out with a freshly rebuilt set from a B12 for
    £62 + £10P&P.
  10. Sean Hamerton
    Nissins are plentiful, cheap and work very well. They come in Japanese
    spacings, don't require adaptor plates and replacement seals are
    readily available... unlike Brembos.
    Lozzo
    they churn out)
    Lozzo, Feb 14, 2011
