FOAK: Tents
Discussion in 'UK Motorcycles' started by SteveH, Oct 22, 2007.
  1. SteveH
    Makes them easier to find when they blow away
    wessie, Oct 22, 2007
  2. SteveH
    des Guest
    Was there a 'missing' smiley in there or is that their reasoning ?
    D.
    des, Oct 22, 2007
  3. SteveH
    Smileys are for the hard of thinking.
  4. SteveH
    Depends who you share the cabin with, surely?
    CT, Oct 22, 2007
  5. SteveH
    SteveH Guest
    Fantastic. Cheap as chips, too.
    Worth buying one just for the novelty factor alone.
    The Khyam Biker is still my favoured option, but I may buy both.
  6. SteveH
    I get seriously bored on the 90-odd minute Dover-Calais crossing.
    platypus, Oct 22, 2007
  7. SteveH
    SteveH Guest
    It's a bit different when you can go to the bar, have some food, get
    pissed then go to bed.
    The following morning, you can wake up to a decent breakfast, go for a
    dip in the pool, then leisurely get your stuff together before driving
    off.
  8. SteveH
    Pikey Joe Guest
    I've got one of these:
    http://www.findmeatent.com/specs/Outwell/Black-Rock/
    It's easy to put up, got a good sized porch (with groundsheet) for your kit,
    and enough room inside to fidget. There are lighter tents around (though
    this is only 5kg), and there are tents that fold up smaller - but that porch
    is so bloody useful.
    The bad news is that I don't think they make it any more, but there's bound
    to be something similar available.
    Pikey Joe, Oct 22, 2007
  9. SteveH
    (SteveH) wrote in :
    Have you been across Biscay before?
  10. SteveH
    SteveH Guest
    No, I read that it can be a bit rough - but it's a fair sized ship built
    for that route, so I was kind of assuming they'd managed to make it
    tolerable.
  11. SteveH
    (SteveH) wrote in :
    I hear Pont Aven is pretty good, when it's not being repaired.
  12. SteveH
    SteveH Guest
    Heh - it's the best option if you want to hit Spain - the P&O crossing
    from Portsmouth is several hours longer and only saves around 40 quid.
  13. SteveH
    Nothing wrong with a bit of rough, biker boy.
  14. Some bugger who doesn't snore would be good.....
    The Older Gentleman, Oct 22, 2007
  15. I've been across the BofB on one of those ferries and, trust me, it gets
    a bit movementy.
  16. SteveH
    The BoB broke the Pont Aven which had to limp back to Brittany Ferries base
    in Roscoff. Apparently, they've armour plated the vulnerable bits.
    http://en.wikipedia.org/wiki/MV_Pont-Aven
  17. SteveH
    ISTR boredom not being your only problem, Mr Bean.
    platypus, Oct 23, 2007
  18. I've got a tree man Khyam[1] with two 'porches'[2] that goes on the bike
    no trouble.
    [1] The only way to go if you have ever put up one of those dome tents
    that you thread the pole through.
    [2] You stick the Givi boxes et al in one porch and come in and out
    through the other.
    Mick Whittingham, Oct 23, 2007
  19. SteveH
    I was on the Rosslare Cherbourg ferry one time many years ago. This
    is, even at the best of times, a long (22hr) fairly choppy crossing.
    This particular time, the weather was so bad, that although we'd
    reached French waters, it was judged to be too rough to make a safe
    entrance to the harbour, and so we ended up bobbing up and down
    outside for another 7-8 hours. Of course, being a student at the time,
    I hadn't got a cabin, so we had to doss down in the bar the whole
    time, which wasn't a particular problem.
    Just about everyone was sick. I mean, everyone was sick. The heads had
    had so many people sick down the toilets and sinks that they had all
    become blocked, and the floor was covered with a roughly 15cm deep
    pool of sick and piss. People were just opening up the outside door
    and pissing/puking in through it into this pool.
    of course, the sight and smell of this was causing a knock-on effect
    were people were throwing up before they could make it to the bogs/
    outside, and so just about everywhere (outside of the bar) was covered
    in sick.
    It wasn't a pleasant journey.
    I wasn't sick, mind.
    darsy, Oct 23, 2007
  20. SteveH
    pretty much. I find that if I feel ill, just getting some fresh air
    helps it go away. And if you've already been drinking, the swaying of
    the floor doesn't seem so bad.
    darsy, Oct 23, 2007
