FOAK - stuck caliper piston
Discussion in 'UK Motorcycles' started by ts, Jul 28, 2006.
  1. ts
    ts Guest
    Around 20-year old Brembo, so I should perhaps have queried in ukrmc.
    Anyhow, I now have the caliper off the rear wheel; one piston would not
    return back into the caliper. After applying some force I managed to
    press it back in, and after some further pressing in/out, it can now be
    moved in (fully) and out fairly easily.
    Will it rapidly seize again if I just put the caliper back on, soon
    requiring another strip? I.e. is further cleaning of the piston
    (including caliper splitting) recommended, now that I have the caliper
    off already?
    Thanks for constructive suggestions!
    ts, Jul 28, 2006
  2. ts
    deadmail Guest
    muck@_TEETH_rulex.net (Muck) wrote in message
    Motorworks sell a complete set of seals and also slider pins and all the
    rest of the gubbins. The pistons are ceramic as well so they don't rust
    in the way that chromed ones do.
    If it were mine I'd strip it and clean it properly. Actually, when I
    stop and think about it that's exactly what I did to my 20+ year old
    K100. Not really a difficult job.
    deadmail, Jul 28, 2006
  3. ts
    Mickey Guest
    It's definitely worth doing the whole job... they will seize up again
    soon if you don't, and your brake's will work properly if you do.
    You don't need new seal's either [unless they're badly damaged], just
    be careful and clean the seal's with a stanley knife blade to scrape
    the corrosion off. The easiest way to get the corrosion out of the seal
    seat, is to bend a small electrical screw driver to just over 90
    degree's and scrape it out with that, being careful not to damage the
    surface in the process... clean the rest as you see fit.
    Keep your brake's in good condition at all time's, is my advice.
    Hope ive helped a bit.
    Mick.
    Mickey, Jul 29, 2006
  4. ts
    Unhinged Guest
    seat, is to bend a small electrical screw driver to just over "90
    degree's" and scrape it out with that, being careful not to damage the
    Mick.
    Unhinged, Jul 29, 2006
  5. ts
    deadmail Guest
    Are you sure about this? We're talking about a twenty year old bike.
    deadmail, Jul 29, 2006
  6. ts
    ts Guest
    Thanks for all comments. When reading my OP it may seem like I would
    skip the rebuild completely - that was not my intention!
    I should have specified that the options were:
    a) put it together now, ride[1] the rest of the summer (no salt on
    roads), hopefully without problems. Strip and rebuild all three
    calipers[2] sometime during winter when the bike is not used much, and
    when I have more time to order and wait for spare parts to arrive.
    b) complete split and rebuild now[3], which means I cannot ride the bike
    for anotherr week.
    [1] only leisure, I do not commute on it
    [2] if one has seized, all have been at risk and may follow suit if not
    restored
    [3] since the caliper _will_ seize again in two weeks time
    ts, Jul 29, 2006
  7. ts
    deadmail Guest
    (ts) wrote in message
    Why don't you just buy the caliper rebuild kits and rebuild when they
    arrive?
    It took me about 3-4 hours to rebuild the three calipers on my K100
    including taking them off the bike, cleaning, putting them back on the
    bike bleeding etc. etc.
  8. ts
    1. It is only a back brake.
    2. It will probably be fine for the rest of Summer.
    3. Get the parts before undertaking dismantling.
    4. Make sure you have the correct parts before undertaking
    dismantling.
    5. Think about how long it has been since your last brake service -
    therefore how long it has taken to seize in the first place.
    Not an issue then, is it?
    Equally bollocks.
    Get on it and ride it - remember to use the rear brake a good bit,
    then it will be less likely to seize. Sort it properly in Winter.
    Pip, Jul 29, 2006
  9. ts
    ts Guest
    (snip)
    That was actually what I hoped to hear :)
    ts, Jul 29, 2006
  10. ts
    ts Guest
    (snip)
    You obviously have more practice than I. My approach to bike servicing
    has ended up rather spending a bit more time figuring out how to take
    things apart without destroying other bits of the bike in the process.
    And figuring out how to do things in a practical way, instead of
    following the step-by-step instructions in the BoLs. Like how to avoid
    depressurising the fuel system and taking off the tank to get access to
    the air filter, as Clymer suggests. I would probably need a week-end to
    rebuild 3 calipers, on and off, doing other things at the same time.
    ts, Jul 29, 2006
  11. ts
    Unhinged Guest
    Ive stripped and cleaned endless amounts of old and new brakes and
    bought a set of seals once ['70's GS 550 i think]!
    I ride a 1978 Z 650 and a 1989 FZR 600 and do all my own work...
    Ofcourse im sure else i wouldnt have put it on here...
    Unhinged, Aug 2, 2006
  12. ts
    Unhinged says...
    I sure as hell wouldn't trust a set of seals that old. They can perish
    and they can shrink and also swell over time. If you're going to have
    the brakes apart you may as well put new seals in and know the job is
    done properly.
    In all fairness, a 1978 Z650 and a 1989 FZR600 aren't in the same league
    as a ZX-6R in the braking stakes to start with, so you probably wouldn't
    notice a drop in performance like you do when a Tokico starts to play
    up. The Tokico 6 pots fitted to the ZX are notorious for requiring a
    full rebuild often or the braking performance drops dramatically. A full
    rebuild in my opinion is a set of seals as well. If you remove them,
    replace them with new ones.
    A tip for the OP. Don't buy genuine Kawasaki seals, source them from
    your Suzuki dealer. Some Suzukis, such as the Hyabusa and TL1000R, used
    the same style of 6 pot Tokico calipers and the Suzuki seals are half
    the price of Kawasaki ones. Just make sure you get the right size seals
    as some Kawasakis, such as the ZX-7R, have two sizes of piston in each
    caliper. All the Suzukis I've seen have all 6 pistons the same size as
    the Kawasaki's larger ones, but this may not be the case with all
    Tokicos.
    Lozzo, Aug 2, 2006
  13. You sir, are a dangerous ****.
    Grimly Curmudgeon, Aug 2, 2006
