FOAK: Straight spoke tightening ?
Discussion in 'UK Motorcycles' started by OH-, Sep 20, 2004.
  1. OH-
    OH- Guest
    Last Friday I upgraded my agricultural equipment. The XT is for
    sale and a Yamaha TT600R has taken over.
    Now, being semi modern, the TTR has these straight spokes,
    no bend at the hub end.
    Some of these on the drive side of the rear wheel are really loose.
    How do I tighten them ? The nipple thread is "a bit" reluctant to
    move and of course all that happens when I try to tighten is that
    the whole spoke turns. Do I grip the spoke with some pliers ?
    Some trick I don't know of ?
    OH-, Sep 20, 2004
  2. OH-
    Robbo Guest
    Found this site quite interesting
    http://www.dansmc.com/spokewheels.htm
    Robbo
    1500GL 1988 Goldwing (Waiting Sale)
    BMW K100 RS 1984
    B.O.S.M 2003, 2004 .FURSWB#1 KotL..YTC449
    PM#7
    Robbo, Sep 20, 2004
  3. OH-
    OH- Guest
    Thank you. Interesting, yes, but I've searching the net quite a bit
    and found all sorts of sites but none that even mention the problem
    I'm experiencing.
    Did you know that there is quite a debate among pushbike wheel
    builders about the pros and cons of linseed oil as a combined
    locking compound and rust protection ?
    I got a tip on R.M.T. that sounds good. Grip the spoke with some
    pliers with some soft metal in between to protect it.
    OH-, Sep 20, 2004
  4. OH-
    Antoine Guest
    It might sound daft, but something like wheels is as far as I am concerned,
    as important as something like tyres, and brakes. If you can't quite get it
    right, like the website Robbo linked to suggests, either work at it real
    slow (including get further advice if necessary) or what I would do would be
    to take it to someone professional to build it up for you - or even just to
    consult their advice.
    Antoine, Sep 20, 2004
  5. OH-
    tallbloke Guest
    Maybe a cast off wheel rim weight with a bit of emery wrapped round?
    tallbloke, Sep 21, 2004
  6. OH-
    OH- Guest
    Good idea. I tested today with some thin steel strip and a pipe wrench,
    no luck. Gave the nipples a new dose of penetrating oil and will try
    again in a few days with some other materials.
    Unfortunately, the realistic way to go seems to be a set of new spokes
    at the next rear tyre change.
    OH-, Sep 21, 2004
  7. OH-
    OH- Guest
    Thanks for the concern but I think I know a bit about how to take care
    of my bikes. Some years ago I successfully rebuilt a rear wheel and it was
    rather fun, actually. The problem is that this is not nice well lubed new
    parts and it has a spoke type I'm not familiar with.
    OH-, Sep 21, 2004
  8. OH-
    tallbloke Guest
    Heat will work. You can try this with the tyre on, but you'll be wanting
    a new rim tape later. Use Mole grips set to F.T. on the mid spoke with
    the emery round soft metal folded round and heat the nipple with a gas
    torch. It won't do the chrome on the spokes any favours, but it's
    cheaper than a wheel rebuild.
