FOAK: SQL & IIS & buggery bollocks
Discussion in 'UK Motorcycles' started by Buzby, Feb 4, 2005.
  1. Buzby
    Buzby Guest
    Asking as a last resort and there are some what knows these things in here.
    Just installed SQL 2000, set up users, set up dsn, to which I can connect to
    the db through dreamweaver and run queries, so far so good. all appears to
    be working fine using login 'MenuPlanner' (see below)
    When I run the page on iis which is installed locally on the same machine as
    sql server I get
    Microsoft OLE DB Provider for ODBC Drivers (0x80004005)
    [Microsoft][ODBC SQL Server Driver][SQL Server]Cannot open database
    requested in login 'MenuPlanner'. Login fails.
    Is this an iis or sql issue? I completely stuck - any bright ideas, or
    should I just lob it out the window and go and get pissed?
    Ta
    Buzby
    Buzby, Feb 4, 2005
  2. Buzby
    Preston Kemp Guest
    Does it work if you use a connection string rather than a DSN? That
    should help narrow it down a bit. I don't know about SQL Server, but I
    gave up trying to get MySQL to work with a DSN. It's fine with DSN-less
    though.
    Preston Kemp, Feb 4, 2005
  3. Buzby
    Buzby Guest
    Works either way, just not on the local webserver. Just cannot figure it.
    Buzby
    Buzby, Feb 4, 2005
  4. Buzby
    Stonge Guest
    User rights to the data directory?
    Stonge, Feb 4, 2005
  5. Buzby
    Preston Kemp Guest
    I'd try disabling anonymous access in IIS (assuming you're using it) &
    logon as Administrator when it prompts you. That'll at least indicate
    whether it's the IIS user permissions or something else causing the
    problem.
  6. Buzby
    Buzby Guest
    Where would I find that - I think it's all set as allow anonymous access as
    far as I can see.
    Buzby, Feb 4, 2005
  7. Buzby
    Buzby Guest
    That's nailed the bugger. I owe you a beer. TYVM!
    Buzby
    Buzby, Feb 4, 2005
  8. Buzby
    Preston Kemp Guest
    No probs. If you find in the near future that everytime you open a
    website, it prompts for a username & password for whatever site you're
    visiting, it's because the local site you just disabled anonymous
    access on is the default (port 80) & you're running an add-blocking
    hosts file.
    It took me a good half hour of head scratching to work that out the
    first time it happened - oh how I laughed when I realised...
