FOAK: Solar motorcycle trickle chargers
Discussion in 'UK Motorcycles' started by Guig, Jan 16, 2006.
  1. Guig
    Guig Guest
    Guig, Jan 16, 2006
  2. Guig wrote The idea is sound but a much better one would simply be to install 15V
    worth of noonday solar capacity on the bikes upper surfaces and connect
    it through a diode and forget it.
    Why? Your alternator charges the battery in seconds. All you need to
    do is ride your bike regularly. Where regularly is not measured in
    annual increments.
    The only other reason I could see for having one would be in a garage
    with no mains supply. Under these circumstances you should be looking
    to generate 30V at noon and trickle charge a couple of large capacity
    batteries. Which you then tap power from as and when.
    steve auvache, Jan 16, 2006
  3. Guig
    Guig emerged from their own little world to say
    I've never come across one specifically targeted at the motorcycle market
    but similar items work well in cars.
    It costs the same as an Optimate which would be much better. Don't you have
    a mains outlet within range of your bike?
    wessie, Jan 16, 2006
  4. Guig
    R obbo Guest
    R obbo, Jan 16, 2006
  5. Guig
    I didn't until a bit over a month ago. Now I have a heated and lit
    garage with power sockets :)))))
    Despite that, I just bought one of those solar panels a couple of days
    ago - for the car.
    Pip Luscher, Jan 16, 2006
  6. Guig
    Pip, Jan 16, 2006
  7. Guig
    Guig Guest
    Fraid not, the bike is living in the shed which is a distance from the
    house and currently the battery is out and being trickle-charged in
    the house. We do plan to do some work soon and get water and
    electricity down to the shed as soon as we clear the backlog of other
    work which needs done in house and garden.
    Guig, Jan 16, 2006
  8. Guig
    Guig Guest
    Guig, Jan 16, 2006
  9. Guig
    Guig Guest
    I haven't been able to ride the bike much over the winter for numerous
    reasons.
    *ding*
    Guig, Jan 16, 2006
  10. Guig wrote
    Provided you keep the door open you can do more than just sit on it in
    the shed going, "Vroom, vroom." You do know this don't you?
    Then go the whole hog and fit it out with a substantial 24V store.
  11. Guig
    Stuart Gray Guest
    Stuart Gray, Jan 17, 2006
  12. Guig
    Stuart Gray Guest
    It's a Merkin site FFS.
  13. Guig
    Guig Guest
    I know, but was looking for something a little more elegant until I
    can lay in the electricity properly.
    Guig, Jan 17, 2006
  14. Guig
    BGN Guest
    Get a 90ft extension lead and arrange it in flower shaped blossoms and
    don't forget to paint them. That'd be elegant.
    BGN, Jan 17, 2006
  15. Can be had for free at a London Bus bus-stop near you...
    Dr Ivan D. Reid, Jan 17, 2006
  16. Guig
    Guig Guest
    Not a bad idea but the local neds would just nick it :) I plan to dig
    a channel down to the shed lay on some plastic piping and stuff it
    underground, and get a proper spark to do the necessary to wire it
    into the house main.
    Guig, Jan 17, 2006
  17. Guig
    raden Guest
    I have one (about 18" long, same make) which I use on the 520i which
    I've driven twice in the past two months. I keeps the battery charged
    against the security system, it seems to work
    you might want to compare the price on the CPC website, it might be
    cheaper
    raden, Jan 17, 2006
  18. Guig
    raden Guest
    Antipodean thug ...
    raden, Jan 17, 2006
  19. Guig
    Guig Guest
    CPC?
    Guig, Jan 18, 2006
  20. Guig
    raden Guest
    justfukingoogleit.com
    is your friend
    raden, Jan 18, 2006
