FOAK: Simple(ton) customer databases
Discussion in 'UK Motorcycles' started by Donnie, Jan 7, 2010.
  1. Donnie
    Donnie Guest
    Right, I'm sure someone here will be able to point me to what I need (I
    hope)
    I'm looking to set up a customer database [1] but Ive never used
    databases before so I'm looking for something simple that will allow me
    to do the following.
    Enter all the following information:
    Name / Address / Phone and email details which I see as being the top
    level info.
    Now, I'm going to try and explain this best I can, I also want to be
    able to enter all transactions they make with me including the item,
    price, date etc and I need it to be searchable in the sense that I
    could look up a customer and search for example, their most popular
    buys or the total spent in a given period etc.
    I'm assuming this is part and parcel of a databases function but would
    also think it's the old adage that "what you put into something is what
    you'll get out"
    Also, I'm assuming that this would be doable in some form of generic
    package like excel or Sun's Openoffice database package or should I be
    looking at physically buying a particular piece of software?
    Any recommendations would be great.
    [1] Only needs to be run on a laptop / desktop, don't need anything
    online
    Donnie, Jan 7, 2010
  2. Donnie
    Buzby Guest
    Donnie wrote:
    I used Sage Act a while back - I think it would probably do everything
    you're looking for and more.
    I was able to produce quotes, record telephone calls/emails made/sent,
    set chase up times, track orders very efficiently and so on. Saved me
    huge amounts of time.
    Buzby, Jan 7, 2010
  3. 'Customer information'.
    Normally one would do this in several layers:
    Order Information
    -Order number
    -Order Date
    -Customer
    -Status
    -Order Line Information
    --Item
    --Quantity
    --Unit Price.... etc
    Very much so. You also need to think of all the likely variations that
    you would want to search or pull reports on. It's a right **** when
    you've built something and someone says 'and can you also cut the data
    this way?' when they'd previously told you 'the other way' was the only
    way they needed it.
    Well, excel isn't DB software, although it can be somewhat butchered to
    produce data in a similar fashion.
    Access is the standard Microsoft product.
    Is Bento available for your chosen operating system?
    doetnietcomputeren, Jan 7, 2010
  4. Donnie
    Derek Turner Guest
    I'd suggest going down the Structured Query Language (SQL) route if only
    because the skills you gain will be transferable. There are many free and
    non-free applications based on SQL. FWIW MySQL is cross-platform,
    powerful, fast and free and can be run on a web-server on your own
    machine. You'll need Apache and probably PHP too, both also free. It's a
    steep learning curve (one that I'm currently near the bottom of!) but
    very satisfying when things start to work (and make sense).
    hth
    Derek Turner, Jan 7, 2010
  5. Donnie
    Donnie Guest
    doetnietcomputeren said:
    You've summed up pretty much what I was trying to say :)
    Using windows vista on the main laptop and the desktops on XP if that
    makes a difference, as for Bento, never heard of that so I'm off for a
    google.
    Access I have on the desktop though quite an old version of it circa
    1996 and only have openoffice on the main laptop.
    I don't mind having to buy a programme though if its going to do what i
    need as it'll be useful in the long run.
    Donnie, Jan 7, 2010
  6. Donnie
    Donnie Guest
    Derek Turner said:
    Hmmm, I see what you're saying but I want to make a start on something
    that will be up and running relatively quickly.
    I don't have the time to learn SQL etc at the moment :-/
    Donnie, Jan 7, 2010
  7. Donnie
    Pete Fisher Guest
    How much is your time worth to you?
    Do you want to become a database software guru or quickly achieve a
    working system that fulfils your requirements?
    You may not have to reinvent the wheel if you search for templates or
    examples. Might even be some based on openoffice or other free database
    engines or 4GLs.
    You can do almost anything with Excel and external data queries, but
    something that natively supports a relational database model and SQL is
    going to make it a lot more functional.
    Some paid for development systems come with pretty well thought out
    examples that can save a lot of work. Foxpro's 'Tastrader' comes to
    mind.
    An off the shelf package as Buzby mentioned may save you even more time.
    I suppose it depends how much you want to expend in terms of cost to buy
    a package and time to get to grips with it, given what it might save
    you, or make for you, using the resulting management information.
    | Pete Fisher at Home: |
    Pete Fisher, Jan 7, 2010
  8. Donnie
    Pete Fisher Guest
    You could do it with Access, given a bit of thought about the structure
    and configuration.
    See other reply.
  9. Donnie
    Jeremy Guest
    I know you said you didn't want it online but.... there are loads of CRM
    systems to choose from which will do what you wnat and more and will
    take you no time to get up and running. some v cheap, like less than
    £10/month for a single user.
    Probably have easy excel-type downloads if you want a copy of the data
    for local reference purposes.
    Jeremy, Jan 7, 2010
  10. Donnie
    Donnie Guest
    Jeremy said:
    It's not that I don't *want* it online, more that I don't see the need
    but am willing to be convinced certainly
    Donnie, Jan 7, 2010
  11. Donnie
    Donnie Guest
    Pete Fisher said:
    A lot when running a small business.
    The latter.
    Sounds good, I'll have a look
    This is it, I'm not necessarily looking for something free moneywise,
    as I value my time as much if not more, hence I'm certainly willing to
    explore an off the shelf package, as long as its not stupid money and
    it'll meet my needs.
    Mentioning Buzby's post made me think to revisit the sage act and it
    seems it can be intregated with sage instant accounts which I already
    have. What Im not sure about looking at the sage site is what sort of
    reports it can generate, still, I think I might download the free trial
    and go from there.
    Donnie, Jan 7, 2010
  12. Donnie
    Donnie Guest
    Buzby said:
    Had a look at it online and am going to download the trial to see what
    sort of reports etc it can do :)
    Donnie, Jan 7, 2010
  13. Donnie
    central Guest
    http://www.sugarcrm.com - it might be overkill, but you'll find out in 2
    years time (if it wasnt, then good). You cant also get this as a pre-
    built vm, which means installation is easy. Its also free.
    central, Jan 7, 2010
  14. Donnie
    DozynSleepy Guest
    Have you checked the price yet, £211.50 inc VAT for a single user
    license of ACT! by Sage 2010.
    We use ACT! Premium at work as it fits our requirements.
    Don't know how practical it is to use SugarCRM on your own laptop.
    http://www.sugarcrm.com/crm/download/sugar-suite.html#installers
    Look for stack installers for Sugar Community Edition.
    I would have preferred SugarCRM as it does the same job, probably better
    and meets my most important requirement, that of having an open source
    *free* community edition.
    If you need help I can probably help out as I ran a trial when we were
    comparing it against ACT!
    DozynSleepy, Jan 7, 2010
  15. Donnie
    Buzby Guest
    Have a look a fleabay 280446857370
    Buzby, Jan 7, 2010
  16. Donnie
    Donnie Guest
    Buzby said:
    <adds to watchlist>
    Donnie, Jan 7, 2010
