FOAK request
Discussion in 'UK Motorcycles' started by Dentist, May 16, 2011.
  1. Dentist
    Dentist Guest
    If one were to order 14 tonnes of 'road scalpings', what would one
    expect to arrive?
    1. Chewed up old tarmac.
    2. Something else.
    Your answer could decide the fate of a Welshman....
  2. Dentist
    "Another term for ?road planings? i.e. material removed from the
    reconstruction or rehabilitation of roads by means of a planing
    machine."
    http://aggregain.wrap.org.uk/terminology/road_scalpings.html
    ogden, May 16, 2011
  3. Dentist
    Jim Guest
    Round here I always thought scalpings was the same as Type 1 Limestone
    chippings - makes quite a decent hard surface if laid properly. Paving
    Expert somewhat disagress with me though:
    http://www.pavingexpert.com/aggs01.html#scalpings
    Jim, May 16, 2011
  4. Dentist
    Something else. Type 1 MOT to be precise.
    Kill him.
    Krusty, May 16, 2011
  5. Free weed seeds.
    I got a donation of some pre loved road surface a couple of years back and
    with it some weeds that I had worked 20 years to eradicate.
    steve auvache, May 16, 2011
  6. Dentist
    Vass Guest
    ?>"Dentist" wrote in message
    Type 1 MOT, its a purple mixture of rocks ranging between 10 and 40cms in
    size
    when you compact it, its hard as nails.
    Vass, May 16, 2011
  7. Dentist
    Dentist Guest
    That's what I was expecting. However, what I got was a regional
    variation of type 1 MOT, as mentioned by Krusty which is, in fact, much
    better suited to the job in hand.
    Even though the Welshman appears to have done me a favour, I am minded
    to kill him anyway.
  8. Dentist
    Jim Guest
    The regional variation is part of the deal - it's basically just a term
    for quarry waste. Down here in Wiltshire it's nice stuff - limestone
    chippings with some clay in it which binds together nicely when it's
    compacted. But it depends on what your local quarry is producing.
    Jim, May 16, 2011
  9. Dentist
    It is, inasmuch as MOT stands for the same thing with both the vehicle
    test and the Type 1 aggregates.
    CT, May 16, 2011
  10. Dentist
    Ministry of Transport, because it's approved by them for use in road
    building. It does sound weird the first time you order some.
  11. Dentist
    Jim Guest
    Ministry of Trade. It boils down to there being a british standard for
    the type of stone and the minimum/maximum size of the bits (ie what size
    sieve the quarry put it through).
    Jim, May 16, 2011
  12. Dentist
    Jim Guest
    I mean, Ministry of Transport.
    Jim, May 16, 2011
  13. Dentist
    GeoffC Guest
    So we're talking serious boulders here?
    GeoffC, May 16, 2011
  14. Dentist
    Indeed. I lived in the Wye Valley and we used scalpings on the drive. The
    stuff from Livox Quarry by the Wye at Tintern was lovely stuff. Reddish
    brown muck in with the stones, compacted well and no mess. The stuff from
    the other side of the watershed at Drybrook was horrible. Red clay in with
    the stones that made heel of a mess. Fine as aggregate for roads but not
    what you want as the top dressing.
    wessie, May 16, 2011
  15. Dentist
    Dentist Guest
    Perhaps he meant mm.
    This stuff is in the range 40mm to dust, and appears to be a mix of
    granite, slate and crushed concrete.
  16. Dentist
    crn Guest
    Scalpings:
    Fine gravel to dust, literally scalped up from under the machinery
    at the local quarry.
    Road Scalpings:
    Either Scalpings as above, used to fill the gaps and aid compaction
    when the stone/gravel base of a road is laid OR Chewed up old tarmac.
    It depends if you are talking to a road builder or a resurfacing
    contractor.
    crn, May 16, 2011
  17. Dentist
    Vass Guest
    Doh! mm
    Vass, May 16, 2011
  18. Dentist
    GeoffC Guest
    Yes that sounds more reasonable, sounds like an excellent way to dispose of
    toxic waste / spent fuel rods and the like, just mix it all up and flog it
    to unsuspecting punters to spread on the driveway.
    Who is ever going to know?
  19. Dentist
    mark Guest
    Never heard those two words put together...
    This would be planings....
    (What we call) Scalpings are 'dirty' stone aggregate that isn't really
    good enough for 'proper' work but is OK for back fill etc. Sort of all
    the crap from the quarry. It doesn't usually contain anything too big as
    they put it through a sieve to try and rescue to bigger stuf to go back
    though the crushers.
    MOT type 1 is a sub base for road building. Sort of one up from
    scalpings. Better than scalpings but these days they are allowed to put
    recycled concrete into it; as long as it's clean and passes the tests
    for sub-base aggregate.
    /Worries
    mark, May 17, 2011
  20. Dentist
    zymurgy Guest
    Your 2 headed offspring ?
    Paul.
    zymurgy, May 17, 2011
