FOAK: Race cans and points
Discussion in 'UK Motorcycles' started by Mark Derbyshire, Nov 23, 2004.
  1. Mark Derbyshire
    Wizard Guest
    No, JP said something like that: http://makeashorterlink.com/?W3BE24DD9
    <8P Wizard
    Suzuki GS550 "I like that. Nicely shite" - TOG
    Golf GTi 16v
    ANORAK#17b BOMB#19 BOTAFOT#138 BREast#5 COFF#24
    COSOC#8 DFV#11 STG#1
    Wizard, Nov 25, 2004
  2. Mark Derbyshire
    Zymurgy Guest
    ogden wrote
    I know, google groups was borked yesterday. I just got 'server error' on posting.
    Note to self: Must get better newsgroup access ;)
    P.
    Zymurgy, Nov 25, 2004
  3. Mark Derbyshire
    Zymurgy Guest
    Lozzo wrote
    Nah, not really, it's a big pussycat until you get to over 8k rpm,
    where all hell starts breaking loose. The bird just had bags of torque
    between 4 & 7k rpm, but no more real urge when thrashing it to the
    10.5K redline.
    Having been used to the linear power delivery on the bird, it takes a
    bit of getting used to the 'no power/full power' throttle. If the P.C.
    dials this out then so much the better.
    Right bike, just has rubbish fuel economy. I'm just moaning that this
    'problem' is made worse by PowerCommandering it.
    Cheers,
    Paul.
  4. (Zymurgy) came forth with the following in
    uk.rec.motorcycles
    It does. It's not so on/off around town and it does seem alot smoother
    through the range with the standard can on. Putting the Yoshi on made it
    go back to the snatchy feeling at the lower end of the revs. That's the
    case with the B1, the A2 I don't know because it was totally standard
    Mark
    ZX12R-B1 (Blue)
    CG125 (hers)
    Blata Ninja 3.4
    BOTSWCAW#3
    Mark Derbyshire, Nov 25, 2004
  5. Mark Derbyshire
    Salad Dodger Guest
    That's cos you had a gurlie one.
    Mine's going on a dyno tomorrow; then it's going back with the
    Promotives on, to see how many horsepower they convert into decibels.
    I suspect at least a handful.
    | ___ Salad Dodger
    |_\_____/_| ..73063../..17005.../..3180./.19406
    \|^|/ ANORAK#17 IbB#4
    Salad Dodger, Nov 25, 2004
  6. Salad Dodger wrote
    Proper attitude.
    Are you aware that in one measure of horse powers there are about 740
    watts? It is not the handful you should be looking for but the
    efficiency with which it is put to better use.
    steve auvache, Nov 25, 2004
  7. Mark Derbyshire
    That and whenever an in-line four with a bling race can goes past; the
    revs bouncing off the limiter in third, in town, there's an unspoken
    chorus of "wanker" from the masses.
    sweller, Nov 28, 2004
  8. Mark Derbyshire
    I don't have any real, hard and fast knowledge in this area but had
    always understood it as polycarbs were affected by UV hence their three
    year max usable lifespan. Glassfibre weren't but needed replacing every
    five due to compression.
    "What I know and what I do are two different things".
  9. FWIW the rule[1][2] with PPE used for commercial climbing applied to
    all equipment was user visually tests before every use[3]. A certified
    individual visually inspects at fixed periods usually 6 months or a
    year depending on usage. Any damage on a visual inspection that
    impacts on safety and the item is destroyed and replaced.
    Each piece of equipment along with it's serial number is recorded in
    the users log book, as soon as it's been five years since first use or
    ten years since manufacture the item is destroyed.
    [1] not sure if this was a legal requirement or industry best practice
    [2] usually GF helmets
    [3] yeah right
    Boots Blakeley, Nov 28, 2004
  10. Mark Derbyshire
    Wik Guest
    <beams>
    Well put.
    The only stop I had with that pipe/can combo ISTR recounting on here;
    Surrey Traffic (no, not /him/) by J2 of the M3. They pulled me 'cause
    of my rapid progress (~ a ton) and the fact they couldn't read my
    teensy-weensie plate.
    Only when they'd got me at the side of the road and had the opportunity
    to inspect the bike did the can come into play. The older, bearded one
    peered down it and needed no torch to spot the almost straight-through
    nature of said device.
    In the end, I simply got a rectification notice about the plate with the
    associated £20 fine.
    Mind you, they never really /heard/ the can...
    :-D
    | Wik -UKRMHRC#10- 2003 R1150GSA -DC#1 -'FOT#0 'FOF #39 - BOD#12 BOB#12
    |# You don't believe me | "Experience is the worst teacher.
    |That the scenery | It always gives the test first
    |Could be a cold-blooded killer. | and the instruction afterward."
    ***** human response from wik at blueyonder dot co dot uk *****
    Wik, Nov 28, 2004
  11. Mark Derbyshire
    Wik Guest
    Wik, Nov 28, 2004
  12. Mark Derbyshire
    Switters Guest
    Wankers do that without race cans as well.
    Switters, Nov 29, 2004
  13. Mark Derbyshire
    Salad Dodger Guest
    I'd expect "wtf was that?" to be more likely, considering how fast
    it'd be going.
    | ___ Salad Dodger
    _/_____\_ GLXR1500SEVRRSP/CBR1100XXX/KH500A8/TS250C
    |_\_____/_| .....73063...../..17090.../..3180./.19406
    Salad Dodger, Nov 29, 2004
  14. Mark Derbyshire
    Well, yes. The red line in 3rd on my bike is over 135mph. As I've
    often said before, on a Hayabusa it's 150mph.
    Champ, Nov 29, 2004
  15. Champ wrote
    The TS doesn't have a red line but I would hazard 40, mebbe 45 and it is
    short three cylinders to be of any real relevance but I just thought I
    would join in and lend my support by way of posting statistics being as
    this actually a thread about bikes.
    steve auvache, Nov 29, 2004
  16. Mark Derbyshire
    Good work, Captain
    Champ, Nov 29, 2004
  17. Mark Derbyshire
    Inline four, is it?
    ogden, Nov 29, 2004
  18. Mark Derbyshire
    It'll be anything you want it to be, slut.
    sweller, Nov 29, 2004
  19. ogden wrote
    It is a V1[1], but just because it hasn't got lots of cylinders doesn't
    mean it hasn't got heart. Even without the race can as well I have just
    as much right to be considered a wanker for screaming past flat out in
    third as the next man. More so in some respects.
    [1] Vertical
