FOAK: Race cans and points
Discussion in 'UK Motorcycles' started by Mark Derbyshire, Nov 23, 2004.
  1. Mark Derbyshire
    Kiran Guest
    Well, you're both sort of right. Depends when you made the modification.
    At the outset of the contract, you have a duty to tell them anything that
    is material to the risk. So, if you have a race can, and don;t tell them,
    they could avoid the policy.
    But, say yoo start the year with a normal can but add a race can part way
    through. Its not a breach of utmost good faith, as that duty only applie
    to the start of the contract. But, insurer can still say there has been a
    material alteration of the risk, which entitles them to avoid the policy.
    In either case, it would have to be shown the change is material and
    would have influenced the prudent underwriter, not just in accepting the
    contract but also the terms it was written on (i.e. premium).
    It's a generally held view that a material alteration of risk is a much
    harder argument to run than a straighforward breach of utmost good faith.
    Don't agree. It is almost certainly material.
    Kiran, Nov 24, 2004
    #81
  2. Mark Derbyshire
    Why do old Plastic Pigs[1] all seem to have cracked and crazed bodywork
    then? Is this due to some other process, like ozone?
    [1]The three wheel type.
    Muck, Nov 24, 2004
    #82
  3. Mark Derbyshire
    Kiran Guest
    Ding. Insurers prefer paying out, cos its cheaper in the long run than
    disputing claims.
    Kiran, Nov 24, 2004
    #83
  4. Hm. Fairy nuff. I'd imagine that would just be the outer gel coat,
    though. And how much would be due to the bodywork flexing?
    I'm not disputing it - I'm just curious. I thought glass fibre lasted a
    long time.
    The Older Gentleman, Nov 24, 2004
    #84
  5. Mark Derbyshire
    Kiran Guest
    4ax.com:
    You've said this before. But why then have a small plate. A race can just
    creates more noise. A small plate, in the eyes of a copper means that
    gatsos might not read you plate, you could do a runner after an accident
    etc etc. Surely more likely to attract their attention?
    Kiran, Nov 24, 2004
    #85
  6. Mark Derbyshire
    The Older Gentleman says...
    Apparently so. I am told fibreglass delaminates when subjected to
    prolonged UV.
    Lozzo, Nov 24, 2004
    #86
  7. Mark Derbyshire
    Preston Kemp Guest
    That's the gel coat cracking due to flexing. It shouldn't noticeably
    affect the structural strength.
    Preston Kemp, Nov 24, 2004
    #87
  8. Mark Derbyshire
    Salad Dodger Guest
    No. The pipes on the Blackbird, going through the Limehouse Link, made
    the copper following a tipper truck wonder what the noise was - so he
    pulled out to have a look.
    3 points, £60.
    | ___ Salad Dodger
    |_\_____/_| ..73063../..17005.../..3180./.19406
    \|^|/ ANORAK#17 IbB#4
    Salad Dodger, Nov 24, 2004
    #88
  9. Mark Derbyshire
    Maybe the gel coat is there to protect the resin? I don't know, as I'm
    not a lover of either glass fiber or Plastic Pigs.
    Muck, Nov 24, 2004
    #89
  10.
    Christopher Des Clayes, Nov 24, 2004
    #90
  11. Interesting. I didn't know that. But they make aeroplanes out of g/f,
    don't they? And UV effects are worse at altitude.
    <googles>
    Well, there's a lot of talk about glass fibre being *resistant* to UV.
    And I found this on an architectural site:
    "Silicon glass has a much higher tensile strength than polyester;
    however, being glass is brittle. To over come this, the fibres are made
    to a very small diameter but are still subject to damage from repeated
    flexing. The advantage of glass is that it is not vulnerable to ultra
    violet attack which gives it a 30+ year design life."
    But there's way too much to digest in a 2-minute google.
    Anyone know for sure? As opposed to "someone told me"?
    (No offence, Lozzo - I'm genuinely interested here. I'd just like to get
    the opinion of SWK. Not least becasue The Doctor uses an old g/f
    lid....)
    #91
  12. Mark Derbyshire
    No offence taken, I was only going by what I'd always been told before.
    Admittedly, this came from helmet manufacturers and distributors.
    Lozzo, Nov 24, 2004
    #92
  13. I told mine[1] about the Goodridge lines and the Ohlins, only to be told
    that's fine but you will not be able to claim for these bits, Oh and are
    they BS certified. One Ins comp wouldn't even give a quote. I haven't
    mentioned the Scottoiler
    [1] H&R
    Mark
    ZX12R-B1 (Blue)
    CG125 (hers)
    Blata Ninja 3.4
    BOTSWCAW#3
    Mark Derbyshire, Nov 24, 2004
    #93
  14. AOL
    Mark
    ZX12R-B1 (Blue)
    CG125 (hers)
    Blata Ninja 3.4
    BOTSWCAW#3
    #94
  15. Mark Derbyshire
    Salad Dodger Guest
    I'm after a screenshot from the game. When the character becomes a
    werewolf, he can see smells as colours.
    Gaspode is surrounded by a bright green cloud all the time.
    Obliged, guv'nor.
    | ___ Salad Dodger
    #95
  16. Salad Dodger <> came forth with the following
    in uk.rec.motorcycles
    bvg> On Wed, 24 Nov 2004 13:25:33 +0000, steve auvache
    That would be Cpl Carrots Misses then - Ang... someting. Well fit cartoon
    characture whois half Werewolf
    Mark
    ZX12R-B1 (Blue)
    CG125 (hers)
    Blata Ninja 3.4
    BOTSWCAW#3
    #96
  17. Mark Derbyshire
    Salad Dodger Guest
    No, they don't appear in Discworld Noir.
    It's a "adventure game" where you take the part of a private
    detective, trying to find the Tsortese Falchion.
    At one point, you get bit, and becoem a werewolf. It's dead good,
    honest. Takes *ages*.
    | ___ Salad Dodger
    #97
  18. Mark Derbyshire
    Verdigris Guest
    On Wed, 24 Nov 2004 15:24:14 +0000, Preston Kemp wrote:
    It's not just to prevent your helmet being dragged off; it's also to
    prevent it being dislodged. If it gets moved too much it can increase the
    probability of a serious neck injury.
    Verdigris, Nov 24, 2004
    #98
  19. Mark Derbyshire
    Verdigris Guest
    On Wed, 24 Nov 2004 09:13:38 +0000, Champ wrote:
    I have also heard it suggested that they think modifications may make a
    bike more desirable to a thief. (Although that sounds like nonsense to
    me: a joy-rider might like something a bit fancy but the pros are going to
    be more interested in relatively standard machines.)
    #99
  20. Mark Derbyshire
    Preston Kemp Guest
    The gel coat is resin. It's a thin coat applied directly to the mold,
    making it effectively the surface of the piece you're making, giving it
    a smooth finish. In some applications the gel coat will be coloured so
    you don't have to paint it.
    Preston Kemp, Nov 25, 2004
