FOAK: Plasterboard walls and LCD TVs
Discussion in 'UK Motorcycles' started by SteveH, Apr 7, 2005.
  1. As Wales is such a lovely place and the houses are so reasonably priced
    - why can't you afford one with a bedroom large enough for a bed and a
    small TV? Does the bedroom door open outwards?
    Simon Atkinson, Apr 8, 2005
  2. SteveH
    SteveH Guest
    Erm, we just don't have any suitable furniture to put a CRT set on, and
    I'm not changing decent furniture for something else just to sit a telly
    on it.
    No. Although I don't see how this matters.
    SteveH, Apr 8, 2005
  3. Why bother with a TV in the bedroom - or has the wife turned into a bit
    of a munter these days?
  4. SteveH
    SteveH Guest
    Sunday morning, coffee and croissants, Sunday Times and News24.
    SteveH, Apr 8, 2005
  5. SteveH
    JackH Guest
    Has yours stopped taking you from behind, yet?
    JackH, Apr 8, 2005
  6. SteveH
    rb Guest
    We had these in an old house securing a radiator to a partition wall.
    Every time I removed the rad I unscrewed the bolts and let the wings
    drop into the partition. Then simply use new fixings when replacing it.
    rb, Apr 9, 2005
  7. Sounds ghastly. Get up and eat brekkie in the garden - or if you must
    wallow around in bed listen to the wireless.
    Simon Atkinson, Apr 9, 2005
  8. You've had a hard life and strange life haven't you?
  9. "steam radio"
    The Older Gentleman, Apr 9, 2005
  10. SteveH
    dwb Guest
    This assumes you have a) ones that do that b) they actually do that.
    The one I had wouldn't unscrew, wouldn't let go... it was just a general
    palaver.
    dwb, Apr 9, 2005
  11. SteveH
    Ben Blaney Guest
    Get a radio, and tune it to BBC Radio Four.
    Ben Blaney, Apr 10, 2005
  12. SteveH
    SteveH Guest
    It's got to be mounted to the internal wall, that's why.
    SteveH, Apr 10, 2005
  13. Why not? It's only 2.4GHz - I know high range hearing drops off with
    age, but for good ness sake...
    Anyway in Wales they can only Get Radio Taff on VHF or the Home Serice
    on Long Wave.
    Simon Atkinson, Apr 10, 2005
  14. It was somewhere around Barstow, on the edge of the desert, when the
    drugs began to take hold. I remember (SteveH)
    saying something like:
    Ceiling, laddy. Look up - there are skinny beams in that ceiling.
    After you've fastened your bedroom muff-diving-while-dangling-from
    the-light-fitting apparatus to them, you can also screw the brackets for
    your telly.
    Grimly Curmudgeon, Apr 10, 2005
  15. SteveH
    Mike Hill Guest
    I fit CRT and plasma's into pubs for a living :) These are the
    strongest cavity fixings I've found to date :
    http://www.screwfix.com/app/sfd/cat/pro.jsp?ts=00153&id=18266
    Make sur you really tighten them all the way in. Fixing to the
    studding is still the best bet though.
    Mike.
    '02 GSF1200 in silver : RD250LC (not at all mint, yet)
    www.rivingtonbarn.com (Rivvy website)
    http://www.rivingtonbarn.com/phpbb/portal.php (Forum)
    Email address spamtrapped.
    Remove "your clothes" to reply.
    Mike Hill, Apr 11, 2005
  16. SteveH
    frag Guest
    Simon Atkinson scribbled:
    I know, too many ultrasound discos when I were young...
    BBC world Service, I remember having a tour round the transmitter
    place, water cooled valves two feet high, glowing orange, job going for
    someone to look at the dials all day long and play cards...
    frag, Apr 11, 2005
  17. Wooferton. Water cooled output valves on the TX - nice...
    Simon Atkinson, Apr 11, 2005
  18. Heh - they don't like it up 'em Mr Mainwaring...
    I do like wandering around big transmitters... Happy days. We used to
    use quite a small one on a station I worked on 2.5kW AM it was. It had
    a slight fault that the top of one of the TX valves would gradually
    charge up to a fair old voltage.
    Listening to the output you'd occasionally hear a little click - in the
    TX room, however, it was like the end of the world as a spark would
    leap about 3 feet to a metal support bracket...
    Eventually I got fed up with it and soldered a small choke between
    earth and the top of the valve and stopped it - and also cancelled the
    type approval but I was fed up of being the shortest path to earth
    whenever I walked past.
