FOAK: Petrol
Discussion in 'UK Motorcycles' started by David Ellis, Sep 23, 2004.
  1. David Ellis
    David Ellis Guest
    In an idle moment I was wondering whether petrol is oxygenated like
    water is when it's stirred or in the case of petrol pumped into the
    tank.
    If so, would there be an increase or decrease in performance from a
    freshly filled tank or would the oxygen levels be saturated any way
    due to the carb/injector air mixture process?
    Just wondering, as one does.
  2. David Ellis
    I don't have a definitive answer, but I can think of a simple home
    experiment you could perform to investigate:
    1) get two empty 2-litre plastic lemondate bottles (wash them out
    first!) and half-fill each with petrol.
    2) put the caps on both bottles, leave one to stand, and give the other
    a vigourous shaking for 3-4 minutes
    3) take the caps off, and hold a lighted match over the top of each
    bottle, and see what happens.
    HTH.
    darsy, Sep 23, 2004
  3. David Ellis
    flash@work Guest
    *Whoosh!*
    flash@work, Sep 23, 2004
  4. David Ellis
    *Whumph!*
    ogden, Sep 23, 2004
  5. David Ellis
    dwb Guest
    Shouldn't it be 'lit' rather than 'lighted'? If not, why not? :)
    dwb, Sep 23, 2004
  6. David Ellis
    *Where'd my eyebrows go?*
    darsy, Sep 23, 2004
  7. David Ellis
    "lighted" is just an alternative to "lit" - there's no difference in
    meaning - both are the instransitive forms of "light". But I feel that
    because "lit" is also the past tense form, "lighted" gives more of a
    sense of "still on fire".
    darsy, Sep 23, 2004
  8. David Ellis
    David Ellis Guest
    In the 3rd Millenium, on 23 Sep 2004 01:40:51 -0700, "darsy"
    Do you think I'm stupid or something?
    I'll use my Zippo.
