FOAK: PC switches itself off
Discussion in 'UK Motorcycles' started by Paul Carmichael, Aug 20, 2010.
  1. Paul Carmichael
    geoff Guest
    No - works fine
    geoff, Aug 20, 2010
  2. Paul Carmichael
    greybeard Guest
    Good, then it's probably just the out of value caps on the board. I replace
    hundreds on a monthly basis, although it appears to be getting a little less
    common now.
    greybeard, Aug 21, 2010
  3. greybeard escribió:
    I'm going to get a new PSU as it's only about 16 euros. Then when I go to
    change it I'll check all the caps. Worst outcome is I'll have a spare PSU -
    not a bad thing.
    Paul Carmichael, Aug 21, 2010
  4. Paul Carmichael
    geoff Guest
    Yeah - I replaced them on my son's motherboard a few years ago.
    geoff, Aug 21, 2010
  5. Paul Carmichael
    ian field Guest
    If its been in service a while there's no harm in taking the covers off and
    cleaning out the dust/fluff etc and inspecting the state of the capacitors.
    Bulged tops isn't the only bad sign, sometimes the top becomes slightly
    concave - the electrolyte has vented while the capacitor was running hot and
    left a vacuum when it cooled down.
    The state of the plastic sleeve around the capacitor can also be a clue - if
    its been running hot the plastic discolours and sometimes shrinks.
    If you're brave enough to run the PSU with the covers off, you can feel if
    any capacitors are getting hot - but one of the heatsinks is likely to be
    live at -320VDC (lethal!) as will be the aluminium cans of some of the
    capacitors on the primary side.
    Back in the days when I earned my living repairing the things (and before I
    bought an ESR tester) I found quite a few failed electrolytics just by going
    over the soldering, some capacitors leak at the seal and ooze electrolyte,
    this sometimes corrodes through one of its leads - re-heating the solder
    joints cooks the leaked electrolyte and makes a pretty evil smell.
    Some manufacturers put the covers on with pop rivets - you can drill them
    out and replace with self tappers, but make damn sure you get all the swarf
    out!
    ian field, Aug 21, 2010
  6. Paul Carmichael
    ian field Guest
    I've got one, but not everyone has.
    And IIRC its called an IR pyrometer.
  7. Using the patented Mavis Beacon "Hunt&Peck" Technique, ian field
    Those who don't really don't deserve to live.
    Wicked Uncle Nigel, Aug 22, 2010
  8. Paul Carmichael
    ian field Guest
    Presumably you mean the medical type which isn't much good at aiming at
    closely packed rows of electrolytics.
    I have one of those to check if I'm overheating and a proper test gear one
    with built in laser pointer.
    ian field, Aug 22, 2010
  9. Paul Carmichael
    geoff Guest
    I don't think that computer has EVER had the side panel on
    Pah - no more than a slight tickle
    On a power supply ?
    For £30 quid (800W) I just replace them
    geoff, Aug 29, 2010
  10. Paul Carmichael
    geoff Guest
    Do you mean those who do ?
    geoff, Aug 29, 2010
  11. Paul Carmichael
    geoff Guest
    But only really useful if you understand what you're measuring (i.e. the
    cone subtended, not just the bit the LED shines on)
    geoff, Aug 29, 2010
