FOAK: Password recovery on a Cisco 1700
Discussion in 'UK Motorcycles' started by Spike, Feb 16, 2005.
  1. Spike
    Spike Guest
    Got a 1720 series router, console cable etc.
    Can hyperterminal into the thing, then when I hit break to abort the loadup
    of the config, I get the helpful rommon 1> prompt, but then it refuses to
    accept any keyboard input...
    What am I doing wrong?... Trying to learn how these Cisco things work, but
    cant do so unless I can get into this router... I have the password recovery
    procedure here, but now Im stuck.
    Any pointers?...
    Spike, Feb 16, 2005
  2. Spike
    Dr Zoidberg Guest
    You don't seem to have much luck with console cables and networking
    equipment do you?
    Alex
    www.drzoidberg.co.uk
    www.sffh.co.uk
    www.ebayfaq.co.uk
    Dr Zoidberg, Feb 16, 2005
  3. Spike
    TW Guest
    said...
    If you let it boot up into IOS, can you get to a login prompt, press
    return and fail to log in ? If not, this suggests that either the
    router's serial port is broken, or that you're not connecting to it
    correctly.
    Also, hyperterm is utter crap, you're likely to be more successful with
    some other terminal emulator. E.g., teraterm.
    TW, Feb 16, 2005
  4. Spike
    Antoine Guest
    Why do you have to use a term emulator ? Cant you telnet to the IP in
    windows "dos", and just enter the details from there from a connected
    workstation to the router (assuming all is working on that side, and
    possibly that you have DHCP etc all working enough for the machine to be
    configured with networking correctly so it can see the router).
    Thats how I do it anyway. Couldnt be arsed with all that serial bollocks
    etc.
    Antoine, Feb 16, 2005
  5. Spike
    Statto Guest
    He needs to reset the telnet/console etc. passwords on a Cisco router.
    To do so requires a console connection to get into the router before
    the operating system loads. As has been suggested elsewhere, either
    the console cable or the console port is knackered.
    Statto, Feb 16, 2005
  6. Spike
    Statto Guest
    Long shot - try the console cable in the aux port.
  7. Spike
    Spike Guest
    Nope :-(
    But thanks everyone who replied... got it sorted in the end... It was
    Hyperterminal being shit. I downloaded Teraterm, and about 5 minutes later
    had a nice fresh router asking me if Id like to go through the initial
    config settings :)
    I am now Happy....
    Spike, Feb 17, 2005
  8. Spike
    Spike Guest
    Or HyperTerminal is shit.... Why the **** it would allow the break command
    to be sent,, but then crap out at sending any other keystrokes is a
    mystery...
    Cheers peeps.
    Spike, Feb 17, 2005
  9. Spike
    Antoine Guest
    Ah right. I assumed you could do all that jazz from the telnet, but I guess
    if you lose the pwd then you are fucked arent you and have to do that
    business.
    Ill keep that on file (just in case I ever need to it myself).
    Makes me recall the good old old days with them old terms you used to get
    and the old RISC UNIX machines etc.
    Antoine, Feb 17, 2005
  10. Hint - the router isn't up. Hence no IP stack is loaded. Hence no
    telnet capability.
    Then you have obviously never fixed a non-working router or configured
    one from new.
    Phil
    Phil Launchbury, Feb 17, 2005
  11. It is a crock of poo for that, I suspect it maybe an OS thing as well.
    Last time I needed to use HT I could send a break successfully from
    W98 but not NT.
    Boots Blakeley, Feb 17, 2005
