FOAK: Paging the linux beardies
Discussion in 'UK Motorcycles' started by Slower Than You, Apr 30, 2008.
  1. I have an old PC that acts as a server (apache, exim, spop3d, and
    bind). It has a 633MHz Celeron CPU and 128MB of ram. It has been
    running Red Hat linux 7.3 for as long as I can remember (i.e. many
    years...)
    The hard disk is making unpleasant noises and I think it might die soon.
    So, I am replacing the HDD with an 80GB one. Should I just use my
    ancient Red Hat CD or is there a better alternative? I don't care about
    graphics or GUIs - the machine just sits in a cupboard.
    Is there a modern distro which targets using shonky old PCs as servers?
    Most of the ones I've looked at either want more than 128MB RAM, or
    they are more concerned with pretty GUIs and desktop apps like
    OpenOffice which I'm not bothered about.
  2. Slower Than You
    Adrian Guest
    Have a look at CentOS.
    Adrian, Apr 30, 2008
  3. CentOS 5 - as has been said elsewhere.
    Soy.
    Soylent Green, Apr 30, 2008
  4. Slower Than You
    osvif Guest
    You may have some luck here http://distrowatch.com/
    osvif, Apr 30, 2008
  5. Slower Than You
    Switters Guest
    I used this page to make some comparisons...
    http://en.wikipedia.org/wiki/Comparison_of_Linux_LiveDistros
    I tried Damn Small Linux and SimpleMEPIS - both supposedly aimed and
    shonky old PCs. On my old PII w/ 128MB RAM box, MEPIS wouldn't even boot
    from the CD, and I couldn't just force an install. DSL booted into
    command line mode, but wouldn't run a GUI - something I was wanting to do
    at the time. Again I couldn't force an install.
    This "try the live, before you install" is all well and good, but for old
    PCs with slow CD drives and little memory, it doesn't work so well. As I
    had nothing on the HD I was willing to try an install straight off to see
    if I liked it, but I just gave up as the requirements at the time passed,
    and I moved on to painting the bedroom instead.
    PS I don't have a beard - hope this is OK.
    Switters, Apr 30, 2008
  6. Slower Than You
    Catman Guest
    Do you *want* to reinstall and set up? If not, boot of a live distro CD
    and dd the old disk onto the new one.
    Make the new disc bootable (though you may not even need to do that)
    then plug the new in where the old was.
    JD
    www.cuore-sportivo.co.uk
    Catman, Apr 30, 2008
  7. Slower Than You
    prawn Guest
    Other than the likes of DSL, any up-to-date headless biased server distro
    should *just* match your shonky spec :)
    A random search gives:
    <https://help.ubuntu.com/8.04/serverguide/C/preparing-to-
    install.html#id2550947>
    as an example.
    prawn, Apr 30, 2008
  8. Ubuntu 6.06 LTS. It's what I run on one of our webservers and that box
    makes your PC look modern..
    By default it doesn't install all the GUI stuff unless you customise
    the install to tell it to. Just select 'Install LAMP server' from the
    boot menu, answer a few questions and Robert is your fathers
    cross-dressing auntie.
    Phil
    Phil Launchbury, Apr 30, 2008
  9. Hmmm... Clever. I didn't realise that was an option. I'll probably go
    with a fresh install just for the "life experience"[1] - one thing I
    neglected to mention was that the current HDD and the complete install
    used to be in an old 133MHz Compaq P5. That machine died suddenly so I
    tried removing the disk and bunging it straight into another machine
    (totally different set of hardware). Amazingly, it mostly worked
    although I have to type "modprobe 8139too" whenever I reboot the box
    before the network works.
    Also, my cavalier attitude to keeping everything up-to-date probably
    means I'd benefit from a fresh install.
    Ta for the info.
    [1] I think that's the polite way of saying "for shits and giggles".
  10. Magic. I think I'll go with this option as I have a small amount of
    experience with Ubuntu (I played around with a liveCD of Greedy Gonads
    or whatever it's called a while back).
    Didn't realise Ubuntu would be happy to install on such low-spec h/w.
    Thanks for the help everyone.
  11. It's not really kept very busy - it's the primary DNS server for a
    domain, handles a few hundred incoming SMTP connections per day (mostly
    spam, natch), and does a bit of webserving on the side (including SSL
    for remote webmail access using Iloha, and a phpBB forum). No samba or
    NFS or anything like that.
    5:33pm up 42 days, 3:28, 2 users, load average: 0.00, 0.00, 0.00
    I'd be lost without it though.
  12. Slower Than You
    prawn Guest
    My headless server now runs 8.04 albeit with quite a lot more RAM.
    So far, so good.
    prawn, Apr 30, 2008
  13. Slower Than You
    crn Guest
    Slackware.
    Just pick the bits that you need - easy.
    crn, Apr 30, 2008
  14. Slower Than You
    prawn Guest
    Really? I'll have a rummage. Just as well I don't use SMB[1] then.
    [1] No need, see?
    prawn, Apr 30, 2008
  15. Slower Than You
    Catman Guest
    I have done it several times to get off shonky discs. Very painless.
    - one thing I
    Linux tends to be like that.
    Arse. I thought 'for shits and giggles' *was* the polite way :(
  16. Indeed. I'm migrating all my current linux boxes here at work over to
    one version[1] and it's possibly the one I'll use. Mind you most of the
    linux boxes are P4's with 256M RAM so I may just stick to 6.06 LTS.
    Phil.
    [1] To make them easier for people other than me to look after in case
    I meet a bus face-on one morning. Or leave.
    Phil Launchbury, May 1, 2008
  17. That's a kind offer, thanks. I'll stick with my existing box though -
    it's like an old friend, although it's a bit like Boycie's paintbrush
    in Only Fools and Horses ("it's lasted me 20 years, but its had four
    new handles and five new heads").
    However, although it doesn't help with diminishing your hardware stack,
    if any of those Compaq's have got a couple of 128MB or greater 168pin
    DIMMs in them that you wouldn't mind losing, I'll post you an SAE and
    some beer tokens for them...
    Slower Than You, May 1, 2008
  18. Slower Than You
    Switters Guest
    Cue the pedants!
    Switters, May 1, 2008
  19. Slower Than You
    Catman Guest
    Trigger's broom.
    Catman, May 1, 2008
  20. Slower Than You
    Heh. I've got a few like that.
    Hmm, I think they're all pretty much down to the usable minimum I'm
    afraid.
    Timo Geusch, May 1, 2008
