FOAK: Noisy PSU fan
Discussion in 'UK Motorcycles' started by platypus, Dec 3, 2005.
  1. platypus
    zymurgy Guest
    <perk>
    Don't happen to have a 5V 40mm fan lying around you don't need do you ?
    Original was a SUNON KDE0504PFB3-8 5VDC 0.4W (40 mm)
    The one that goes in a 3Com OfficeConnect hub.
    Cheers
    Paul.
    zymurgy, Dec 4, 2005
  2. platypus
    zymurgy Guest
    Hmm, looks munged, is that rot-13 ?
    P.
    zymurgy, Dec 5, 2005
  3. platypus
    Wik Guest
    Does it make any more sense if you apply a ROT-13 to it?
    Wik, Dec 5, 2005
  4. platypus
    Biffa @ Work Guest
    Mmm Hmm !
    What would be cool is a photo of the header/connector, these can be bespoke
    depending what bit of kit the fan is in.
    Biffa @ Work, Dec 5, 2005
  5. platypus
    zymurgy Guest
    Wik made up :
    Well, if I was anywhere near my linux box i'd have done. Unfortunately
    i'm on windows here !
    This all seems like a lot of work. Maybe i'll mail him at his website
    P.
    zymurgy, Dec 6, 2005
  6. platypus
    simonk Guest
    You need a copy of cygwin, you do. All of the useful bits of *nix, with
    none of the attendant shite
    simonk, Dec 6, 2005
  7. platypus
    zymurgy Guest
    Don't you fucking start !!
    The day I take technical advice from you ... ;-)
    Paul.
  8. platypus
    Cab Guest
    You lack a pen and paper? Notepad is good for ROT-13ing.
    Cab, Dec 6, 2005
  9. platypus
    zymurgy Guest
    Standard 2 pin female header plug with polarity notch, to go onto 3mm
    spacing PCB pins.
    Rgds
    Paul.
  10. platypus
    zymurgy Guest
    Lovely. Thanks.
    Paul.
    zymurgy, Dec 7, 2005
  11. platypus
    ... is the day you end up with a blue rinse.
    Not at all.
    Pip, Dec 12, 2005
