FOAK: Noisy PSU fan
Discussion in 'UK Motorcycles' started by platypus, Dec 3, 2005.
  1. platypus
    The fan in my PSU (Bestec ATX 1956F) has gone noisy. It's not rubbing on
    anything, and I reckon it's the bearings. And it's bloody irritating,
    droning away all evening. So, should I dig into it and replace the fan, or
    buy a replacement? And if I should replace it, what's good?
  2. Easy enough to replace. Try www.overclockers.co.uk and have a look at
    the 80mm cooling fans from YS Tech - cheap and quiet.
    Grimly Curmudgeon, Dec 3, 2005
  3. platypus
    That'll do. Ta.
  4. platypus
    Even better. I'll dig it out an find the specs tomorrow night.
  5. platypus
    Eiron Guest
    For any lubrication problem the answer is NOT WD40.
    Eiron, Dec 3, 2005
  6. platypus
    Howard Guest
    Then what is it?
    Howard, Dec 3, 2005
  7. platypus
    A lubricant. This isn't rocket science, you know.
    Pip, Dec 3, 2005
  8. platypus
    Eiron Guest
    Yes. WD40 is OK for washing out the crap in bits you can't dismantle
    but is not a good lubricant. A drop of '3 in 1' oil is ok for a motor
    with a sintered bush.
    Some people are quite imaginative in their misuse of this water displacer.
    A couple of old articles from the Daily Telegraph:
    <quote>
    Retired engineer bill Hall from Stockton-on-Tees writes to tell of his
    fortuitous discovery for his painful arthritic joints. He's a great fan
    of WD40, the universal lubricant whose 1,001 uses include loosening
    rusty joints. He noticed his wrist and finger joints seemed more supple
    after using it and now finds that a couple of sprays to his knee joints
    have the same effect.
    "When she read this column a fortnight ago, Mrs P. P. from Dorset was
    struck by the Stockton engineer's description of the beneficial effects
    of the universal lubricant WD40 when sprayed directly onto painful
    muscles and creaky joints - and resolved to act immediately. She herself
    has had a lot of pain from an arthritic knee joint, which that Sunday
    was being "particularly troublesome". So she asked her husband if he
    would kindly fetch the magic potion from the garage. "I gave the knee
    two squirts, rubbing it in to save dribbling on the carpet, and a couple
    to my painful thumb for good measure," she writes. "And, blow me,
    neither knee nor thumb have bothered me since."
    There is an obvious analogy here with Dorothy's lubrication of the Tin
    Man's rusty joins in the Wizard of Oz - although the mechanism of action
    must presumably be different - and as another reader points out, the
    instructions include the admonition: "Avoid contact with the skin"; so
    care should be taken not to overdo it.
    </quote>
    Eiron, Dec 3, 2005
  9. platypus
    Cab Guest
    WD40 always works for me too. It sorted out a laser printer that I got
    from work that was squeaking and leaving tracks and traces on
    printouts. It's great for sorting out dodgy contacts and the like too.
    But I'd never oil my bike chain with it.
    Cab, Dec 3, 2005
  10. I know what you mean, better to use something like DWF that has a
    lubricant in it...
    eric the brave, Dec 3, 2005
  11. Snake Oil.
  12. platypus
    Eiron Guest
    As straight as a bat made from Corkscrew Willow and definitely below the
    belt.
    What do you call that form of sarcasm? Is it litotes?
    Eiron, Dec 3, 2005
  13. platypus
    deadmail Guest
    Looking at the CV on your website, not very much.
    I'd rewrite it if I were you since there's little chance of that
    encouraging anyone, apart from a fuckwit, to employ you.
    Here's a free tip; a CV is not the place for 'humour'.
    deadmail, Dec 3, 2005
  14. platypus
    deadmail Guest
    Jesus fucking wept.
    Many years ago I had the misfortune to see a poster suggesting to
    mechanics that keeping oily rags in trouser pockets was a bad idea; a
    picture of a very badly affected set of bollocks. Scabby, red, swollen
    and with flaking skin. I'd suspect that rubbing WD40 on your skin would
    have a similar outcome with time.
    Plus Gas on the other hand...
  15. platypus
    80mm x 80mm x 25mm, as it happens. Good guess.
    Arrgh. Forgot this, and I've just put the PSU, PC et al abck together
    again. Bugger.
    I couldn't find the WD40, so I used a couple of drops of 3in1. Lovely,
    quiet.
  16. Not just that: now it's recognised as being carcinogenic.
    Quite possibly, iwt.
  17. platypus
    deadmail Guest
    I thought that it *might* have mentioned cancer but wasn't certain.
    FWIW this was in a Wiltshire County Council DLO workshop 19 years ago...
    Still, if they're old it'll save on the pension.
  18. platypus
    deadmail Guest
    Not quite the impression your CV gave, but 'whatever'.
    *shrug* my comment was about the CV rather than anything else.
    deadmail, Dec 4, 2005
  19. platypus
    raden Guest
    You might just as well buy a 650 watt quiet psu for about 25 quid
    otherwise you might be able to ping the rotor off and re-oil with a
    light oil and hope you haven't distorted it too much
    raden, Dec 4, 2005
  20. platypus
    raden Guest
    Squirt some WD40 at it
    prolly fix it until you can do a proper job
    raden, Dec 4, 2005
