FOAK - need to recover data from reformatted hard disk...
Discussion in 'UK Motorcycles' started by Chris N Deuchar, Feb 1, 2007.
  1. I've looked on my backup drive, under the sofa and behind the fridge
    but I still can't find some files I thought I'd backed up from my
    previous hard disk.
    Foolishly[1] I reformatted the old disk prior to putting it in
    storage. No new data was written to it therefore[2] all the old data
    might be recoverable from the old (FAT32) partition.
    My old copy of 'Lost & Found 1.06' doesn't seem to like either my Zip
    drive or my shiny new NTFS disk so I can't use that.
    What does the FOAK recommend please?
    Chris D
    [1] in retrospect
    [2] note the uncertainty in my phraseology
  2. Chris N Deuchar
    Cane Guest
    http://www.runtime.org/
    Cane, Feb 1, 2007
  3. Chris N Deuchar
    Catman Guest
    One of my clients did something similar
    Recover my Files did what it said on the tin.
    and has done on several other occasions
    Took a while, mind. Renaming everything everything afterwards was their
    problem
    www.recovermyfiles.com
    www.cuore-sportivo.co.uk
    Catman, Feb 1, 2007
  4. Chris N Deuchar
    Christofire Guest
    From just the other day, getdataback (all one word) will sort it. They
    do a free trial, which might do the job. There's FAT and NTFS versions
    when I last looked at it.
    Christofire, Feb 1, 2007
  5. Yes thanks for this, and the other responses. Runtime's Getdataback
    did indeed find my missing files, and I was even able to view and
    listen to content - but the trial version won't let you do recovery.
    Ordinarily I would be quite happy to pay for this sort of thing but,
    as I hope it is a one-off, and $120 seemed rather a lot, I naturally
    tried to find 'other help' through Google.
    The mess of virus-related sites seems to have overwhelmed what used
    to a simple 'pikey' solution so I was on the verge of giving up when
    I noticed something strange in my file manager. There, lurking
    amongst the usual cr*p in the 'My Documents' folder (which I normally
    make a point of avoiding) were files with strange names, but of
    identical size, to some of the files that had gone missing.
    In the twinkling of a mouse, I had copied said files to a USB drive
    and opened them on another machine. Magic! These were my 'lost and
    not recovered' files found by GetDataBack. All I had to do was rename
    them. Even more interesting, it didn't matter what program I tried
    to use on the original 'unrecovered' files (some had obscure suffixes
    and were no longer registerd file types - even 'Notepad' worked) as
    copies still got put in 'My Documents'.
    So there we are then. The ultimate pikey solution. No username, no
    registration code, no dosh required.
    Chris D
    ('Winston suddenly realised that, at last he *loved* 'My Documents'.)
    Chris N Deuchar, Feb 7, 2007
