FOAK: Knees
Discussion in 'UK Motorcycles' started by Cane, Sep 18, 2006.
  1. Cane
    Cane Guest
    You're a priest or you work at a Gloryhole... sorry, same thing.
    Cane, Sep 18, 2006
  2. Cane
    mb Guest
    Non-destructive testing...
    mb, Sep 18, 2006
  3. Cane
    Owen Guest
    Catilage damage? See you doc... Knees, you don't really wannabe
    without them... See your doc before it gets worse, don't suffer, as I
    did for 6 months, before having the op...
    Good luck with it, hopefully it's nothing serious...
    Owen, Sep 18, 2006
  4. Cane
    TMack Guest
    Its fucked - I'll give you a tenner for it
    TMack, Sep 18, 2006
  5. There you go. Slaloming in your sleep.
    Grimly Curmudgeon, Sep 18, 2006
  6. Cane wrote
    I get that, particularly in my right knee, it is a proper bugger and
    really only shows up when on a bike. If the bike is moving, even just
    an inch and my right foot is in contact with the ground it fucking
    hurts. "Fair wear and tear," the quack says, "now **** off and let me
    get on with treating sick people." Hey ho.
    Nope.
    steve auvache, Sep 18, 2006
  7. Cane
    Yes. It'e very effective at penetrating into the joint.
    Wrong. It diffuses through the various body tissues. Take-up into the
    blood stream is much slower, thankfully, otherwise the stuff would be
    no good whatsoever.
    And only a very small proportion of it then reaches the required area.
    Indeed, only a small proportion of it even gets into the blood in the
    first place - the gut is not an ideal environment for drug uptake.
    You are. Very much so. Topical anti-inflammatories are _much_ more
    effective for joint problems (talking here about OTC drugs), as they
    allow a much higher active dose at the swelling/pain site than could
    reasonably (i.e. without risking severe adverse reactions) be attained
    via the oral route.
    _______
    Ace, Sep 19, 2006
  8. Cane
    Scraggy Guest
    I recently have/had a similar type of thing, I believed it tobe a loose
    piece of crud from the kneecap which I damaged in the '80s. An examination &
    x-ray failed to show anything other than some arthritis in the joint.
    They all do that Sir.
    After a couple of months it disappeared overnight. So I still believe it was
    caused by crud which could drift into the joint again at anytime. Of course
    this minor agravation is no reason to use a much more expensive scan to id
    the problem. Perhaps if I were foreign...
    Scraggy, Sep 19, 2006
  9. Cane
    gomez Guest
    Could be a torn cartilege and / or damaged ligaments casued lateral
    instability. I have lived with it for twenty odd years after a (its a
    football injury) but it seems to betting worse now I no longer sit on
    my arse in an office all day but do manual work instead.
    gomez, Sep 19, 2006
  10. ACL (Anterior Cruciate Ligament) - a lot of NFL players get that injury
    and talk about it in similar terms.
    Phil
    Phil Launchbury, Sep 19, 2006
  11. Yes. They put a lot of work in to get the active compound past the skin
    barrier. I'd hate to think it was entirely wasted.
    Err - in the case of the knee then there is very little between the
    skin and the joint. The synovial membrane is pretty much just under the
    skin. And very little of it actually gets into the blood - from memory
    it diffuses through the intra-cellular fluids.
    A lot less gets to the site when you take it orally. It's better for
    taking stuff that you want to affect a lot of sites but for specific
    sites then a good topical ointment is better.
    On UKRM? Perish the thought.
    Phil
  12. Cane
    Cane Guest
    Aha, that'll be it. I was playing wide receiver for the Chicago Bulls
    last week.
    Cane, Sep 19, 2006
  13. Cane
    I've use Voltaren and Ibulieve gel (amongst others I can't remember)
    and never found them bad on the leaving it sticky front, which is
    something I don't like either. So maybe it's just your brands.
    _______
    Ace, Sep 19, 2006
  14. Cane
    Heh.
    So have you seen the doctor yet? I await confirmation of my 'cartilage
    damage' diagnosis.
    _______
    Ace, Sep 19, 2006
  15. Cane
    Cane Guest
    Oi, you're getting a bit previous son, no one likes a cocky cripple ;)
    Actually I've not been to the Docs. GPs tend to treat symptoms rather
    than cure things, rather like BMW service centres. I'm sticking with
    the old man's suggestions and exercises although my plans to train this
    evening have changed as it quite sore this evening. I get pissed off
    when I can't train.
    My spider senses tell me that in two weeks time I'll saying something
    like "Blimey Bruce, turns out it's cartilage damage and I been making
    it worse"
    Cane, Sep 19, 2006
  16. Cane
    Pete Fisher Guest
    Google chondromalacia. SWMBO has had to restrict skiing, cycling and
    mountain walking after buggering her knees with too much of all three,
    and in particular riding an old bike for miles with knackered gears
    (before my time).
    Steroid injections helped for a while and a few years ago she had an
    arthroscopy which helped a bit.
    OK she is nearly as long in the tooth as me, but the first symptoms
    showed up in her forties.
    A potential early warning sign?
    | Pete Fisher at Home: |
    | Voxan Roadster Moto Guzzi Mille GT/Squire RS3 Gilera Nordwest |
    Pete Fisher, Sep 19, 2006
  17. Cane
    Interesting. I had often (for relative values of often, it never kept
    me awake at night) wondered whether these gels actually penetrated. I
    more-or-less came to the same conclusion as Eiron. It just goes to
    show that skin isn't the barrier it seems.
    Pip Luscher, Sep 19, 2006
  18. Cane
    Cane Guest
    Now there's a thing. You're one of these funny old blokes who I've read
    plenty of, met once and have a strange respect for.
    So I'll check that out.
    Cheers Peter
    Cane, Sep 19, 2006
  19. Cane
    Eiron Guest
    It seems that some medical scientists had doubts about the subject:
    http://rheumatology.oxfordjournals.org/cgi/content/abstract/38/6/564
    Perhaps Cane could do some tests by putting ibuprofen gel on his other knee
    instead for a couple of days.
    Eiron, Sep 19, 2006
  20. Are either of those available as patches. I hate the gels, they
    don't absorb and stick around rubbing off on the carpet all night. I
    found a while ago that ibuprofen worked wonders on my arthritis(?) in my
    feet, but soon realised that it was cutting my stomach up something
    chronic[1]. Paracetemol did nothing. Once as a desperate measure I used
    combined paracetemol+aspirin tablets. They worked, but it took me a
    couple of doses to realise that if para didn't work, it must ne the
    aspirin doing the trick. Bingo! And its effects last longer than
    ibuprofen (several days at times). But it just doesn't take quite as much
    edge off the fire as ibuprofen, and has a reputation for stomach damage
    too, so I'd like a clean, non-gut delivery method for IB.
    [1] I hate vomiting blood.
    Dr Ivan D. Reid, Sep 19, 2006
