FOAK Joining Avi and Wmv files ?
Discussion in 'UK Motorcycles' started by Paul - xxx, May 8, 2007.
  1. Paul - xxx
    Paul - xxx Guest
    We have a few avi and wmv files [1] we'd like to join to make continuous
    stream that we'll eventually make into a video, but not sure how to do it
    other than using a video editor and importing the 'bits' one by one, and
    then making them into one video. It gets a bit tedious when the first 'bit'
    which might be 500m long needs the next bit adding which might only be 20m
    long. We'd like to have a (preferably freebie or ver' cheap) software that
    could take a folder full of maybe 50 or 60 files and simply turn them into a
    single file. Most will be avi's, some will be wmv's, but we'll only be
    joining avi to avi, not avi to wmv or vice-versa. Most similarly named and
    with consecutive numbers, ie file001.avi, video0001.wmv.
    Any suggestions, please.
    [1] Not for publication or professional use, just films taken by the kids on
    their respective digital cameras, which we want to keep more permanently.
    Mostly BMX bike riding, jumping, tricks etc.
  2. Paul - xxx
    Clearly not a professional tool, Windows Movie Maker, which I believe
    is a standard part of MS Office (or XP?) allows you do do pretty much
    exactly what you want. You need to drag & Drop each clip onto a
    storyboard, but once it's all there you can edit bits out, repeat
    sections or insert extra effects.
    Veggie and others will be alng shortly to point you in the direction
    of more professional tools, I'm sure.
    _______
    Ace, May 8, 2007
  3. Paul - xxx
    VirtualDub lets you open a file then 'Append AVI Segments' but I don't
    think it'll work with WMVs. I have done similar with AVIs in the past
    just using the dos copy command with the +b switch, which is probably
    the quickest way of doing it. No idea if that would work with WMVs
    though.
    Krusty
    www.MuddyStuff.co.uk
    Off-Road Classifieds
    '02 MV Senna '03 Tigtona 955i '96 Tiger '79 Fantic Hiro 250
    Krusty, May 8, 2007
  4. Paul - xxx
    Bad form - I meant /b. So for example:
    copy /b file001.avi + file002.avi + file003.avi merged.avi
    If you use notepad to create the command so you can cut & paste like
    crazy it shouldn't take long. I'd suggest trying it with just a few
    files first though in case it doesn't work with the format the cameras
    spat out.
    Krusty
    Krusty, May 8, 2007
  5. Paul - xxx
    Veggie Dave Guest
    For what he wants, just drag and dropping everything in Windows Movie
    Maker sounds the only solution to me.
    Veggie Dave
    UKRMHRC#2 BOTAFOF#08
    IQ 18 FILMS http://www.iq18films.com
    POST PRODUCTION http://www.iq18films.co.uk
    Toxic Shock Syndrome Gets More Girls Than Me
    Veggie Dave, May 8, 2007
  6. Paul - xxx
    Pip, May 8, 2007
  7. Paul - xxx
    <Thud>
    _______
    Ace, May 8, 2007
  8. Paul - xxx
    Paul - xxx Guest
    Heheheh, thanks for the suggestion and confirmation.
    You can pick your chin up off the floor now, Ace. ;)
  9. Paul - xxx
    Paul - xxx Guest
  10. Paul - xxx
    Krusty, May 8, 2007
  11. Paul - xxx
    raden Guest
    Apart from the other suggestions, you could look on www.afterdawn.com
    it's a site dedicated to all things audio and video (?)
    raden, May 8, 2007
  12. http://www.bobyte.com/
    GS850x2 XS650 SE6a
    river cleaned out in a day.
    Grimly Curmudgeon, May 9, 2007
  13. Paul - xxx
    I dunno - but the suffixes Paul quoted above look just like split
    files.
    Pip, May 9, 2007
  14. Paul - xxx
    Paul - xxx Guest
    Haven't got a folder of files yet, but will try it after this weekend.
    Certainly when the downloaded app. is expanded and the 'read me' perused it
    would seem to be able to join almost any files which have a progression, so
    it looks a winner.
    Appreciate the suggestion, thanks. ;)
    Paul - xxx, May 9, 2007
  15. Paul - xxx
    Paul - xxx Guest
    Had a litle play with the apps ... unfortunately they don't work.
    The 'joiner' part only joins parts that have been split by the 'splitter'
    part, and have exactly the same filename, with the 'oo1 ...oo2 etc' added.
    Thus video001.avi, video002.avi, video003.avi are all seen as separate parts
    .... So I tried renaming the parts (irfanview, a great bit of software) to
    video.avi.001, video.avi.002 etc but the program saw through this and still
    refused to play ball.
    No worries, nice try but no biscuit, thanks for the effort though.
  16. Paul - xxx
    Paul - xxx Guest
    You da man ... Combi-Join works brilliantly for what we want.
    Many, many thanks. This'll save a shit-load of time 'playing'.
  17. NP. I've been using Combi-Movie for 'artistic' films.
    GS850x2 XS650 SE6a
  18. Paul - xxx
    Veggie Dave Guest
    Er, you've spent days fucking around looking for free software when you
    could have done it in 30 mins using Movie Maker...
    Veggie Dave
    Veggie Dave, May 9, 2007
  19. Paul - xxx
    Well only if he's actually got it.
    _______
    Ace, May 9, 2007
  20. Paul - xxx
    Veggie Dave Guest
