FOAK: JBL Control 1 monitor speakers?
Discussion in 'UK Motorcycles' started by Timo Geusch, May 22, 2008.
  1. Timo Geusch
    Anybody got any experience with them? Decent speakers or not?
    Basically, I do need/want to replace the current computer speakers with
    something that sounds a little better but I've got a bit of a size
    problem - the standard "bookshelf" speakers I bought are just too effing
    big. The Control Ones are smaller and may *just* about fit the available
    space...
  2. Timo Geusch
    davethedave Guest
    Very nice indeed. The price is right for the quality. Had some at work
    once as monitors on the sound desk. They're only little but the do have
    quite a good range for their size.
    Bear in mind though the sound card is going to be the weakest link
    anyway. So unless you have a shiny sound card and external DAC and will
    be playing from high quality sources such as DVD etc. You shouldn't need
    any better.
    If you need an amp make sure its big enough to drive them properly or
    you may risk blowing them up. C1 needs 10 - 80w they say and the C1 Pro
    will need about 100W. Both cover the same freqency range of 80hz - 20khz
    with the pros probably being a little more crispy and quick to react at
    the lower end of the spectrum. (see sound card note above and go cheap!)
    I have cheap a chinese control 5 copies which are fine (My neighbours
    disagree sometimes). Good sound is hard to come by in Turkey due to
    excessive taxation on imported goods.
    Have fun!
    davethedave, May 22, 2008
  3. Timo Geusch
    Oh, jolly good.
    OK, that sounds about right then.
    OK. I think they're non-pros which would be good as I didn't want to
    hide a big amp somewhere around here. And I should be able to drive the
    regular C1s off a Cyrus One or similar.
  4. Timo Geusch
    Beav Guest
    Timo, if you've got a "Sound Control" shop/emporium near you, go there and
    go to the "Recording/Moniitoring" section and have a listen to lots. Don't
    get involved with the monkeys, go straight to the keeper, coz they've gone a
    bit tits up have Sound Control, so you can haggle like a good 'un, but the
    only one to argue with, is the man i charge. He'll probably know more aobut
    monitor speakers than the monkeys too.
    I scored a nice spanking new 16-4-2 mixing desk yesterday which normally
    retails for around 550 quid. I paid less than half retail .
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, May 22, 2008
  5. Timo Geusch
    NickNoxx Guest
    There are two different models 4ohm and 8 ohm and the 4 ohm version is
    noticeably better quality (providing you have a matching amp). Great
    speakers.
    http://www.jblpro.com/products/installedsound/Control/control1pro.html
    http://www.jbl.com/home/products/pr...=ENG&Country=GB&Region=EUROPE&cat=CLA&ser=COS
    (also available in black)
    NickNoxx, May 23, 2008
