FOAK: iPods
Discussion in 'UK Motorcycles' started by Cane, Nov 13, 2006.
  1. Cane
    Cane Guest
    Can you run two iPods off the same PC without them having to share the
    same playlists?
    Cane, Nov 13, 2006
  2. Cane
    antonye Guest
    Yes.
    antonye, Nov 13, 2006
  3. Cane
    Cane Guest
    Goody Gum Drops
    Cane, Nov 13, 2006
  4. Cane
    WillF Guest
    You might find it easier to set up different user accounts in windows
    for the different iPods.
    It can be a fiddle tbh.
    Will
    WillF, Nov 13, 2006
  5. Cane
    antonye Guest
    My bro-in-law has 4 running off his laptop - his own
    and 3 for his sons. They all run under the same account
    but are seen as having separate libraries and so on.
  6. Cane
    Cane Guest
    That's good news. The kids are getting them for Xmas and I wanted to
    keep all the mp3 files centralized.
    Cane, Nov 13, 2006
  7. Cane
    antonye Guest
    You'll have to import them into that iPod's library
    each time, but if you've got them organised then
    just point it at the upper-most directory and use
    the import folder feature.
    As long as you don't use the "move music into
    iTunes directory" option or store them as Apple's
    own format, then you should be fine.
  8. Cane
    Ben Guest
    It's easiest if you turn off the auto-iPod-update feature and manually
    move music between iTunes and the iPods.
    Does anyone know how to create new libraries? At the moment I've got
    both mine and Anya's albums in one library, but I'd rather have them
    separate. At the moment I've set up 2 playlists, one with each of our
    stuff on it, but that's not really ideal.
    Ben, Nov 13, 2006
