FOAK:Honda CB 250 RS
Discussion in 'UK Motorcycles' started by dave eades, Feb 18, 2005.
  1. dave eades
    dave eades Guest
    were they any good?
    Thinking of buying one for the 20 mile round trip daily commute.
    anything to look out for?
  2. dave eades
    AJSMITH Guest
    can't remember if there is anything to look out for but the one i had was
    100% reliable, great fun, v good mpg and went fairly well for a 250 single,
    buy a decent one and i'll be suprised if you have any cause for concern.
    AJSMITH, Feb 18, 2005
  3. dave eades
    dave eades says...
    I used a 170,000 mile one for a 100 mile a day flat out commute down the
    M1, M25 and M4. It wasn't happy doing it, but it managed it. I then
    retired it to a 50 mile a day commute, which it was a little happier
    with.
    As long as the cam and camchain don't rattle, it's had very frequent oil
    changes and the mileage looks right then buy it. Other than that, check
    the condition of the rear sprocket cush drives. They have a habit of
    wearing out and wrecking the rear wheel hub. As does the large circlip
    that holds the rear sprocket in place. If the rear sprocket has sideways
    moevement then you'll have trouble repairing the groove it sits in and
    the chain will wear like buggery. Everything else is straightforward and
    the type of things you'd check on any used bike. Just bear in mind that
    the CB250Rs doesn't have an oil filter as such, so frequent oil changes
    are very important.
    Lozzo, Feb 18, 2005
  4. dave eades
    Steve Dixey says...
    What bearings? The cam sits direct in the head.
    Lozzo, Feb 18, 2005
  5. dave eades
    Perhaps he missed a "a lack of" in the sentence.
    sweller, Feb 19, 2005
  6. dave eades
    Dave Emerson Guest
    The cam running directly in the head is common to all the models and clearly
    a weakness in the design. Cheap oil, infrequent changes or low level can
    cause permanent damage.
    The cush drive and chain wear problem was solved with the RS-D, along with a
    few other niggles. Only issue was they took off the kickstart and added an
    electric start with a poor engagement mechanism (sounds like an old Ford
    Cortina). Anyway the electric start is fine if the bike is used everyday
    and the battery is in good condition - otherwise it's trouble.
    There is a way to put the kickstart back in an RS-D but it does require a
    little engineering. My sister did it on her CL250 (same engine) with great
    success. She was talking about putting some instructions together but, as
    she's in the middle of moving house, this isn't likely to be top priority.
    Dave Emerson, Feb 19, 2005
  7. dave eades
    Yep, same with my Bandit and my FZR.
    Muck, Feb 19, 2005
  8. dave eades
    I had an RS-A for a few year - did about 24K on it and sold it at
    about 48-50K miles and the engine was still going strong.
    I *think* I replaced the camchain early on but ISTR that this was a
    precaution really as it was getting near the limit - I never really
    trusted the odometer reading.
    The alternator died once: replaced from a breakers. Rear wheel
    bearings went; rear sprockets were always loose due to worn hub/clip.
    It was not fast: it struggled to make seventy into a strong headwind
    but it was economical.
    The auto-decompressor never worked becaues the cable was seized and
    the cam arm inside the RH case had broken off, but it was always easy
    to start.
    It was comfortable: I once rode with the then GF to Loch Lomond on a
    camping trip, and several times commuted to Sheffield from Newmarket
    on weekends.
    Oil must be changed regularly because there's no proper filter.
    I got through one pair of aftermarket shocks during the time I had it.
    Oh, a couple of rear wheel spokes broke, but that could have just been
    bad maintenance on my part.
    The only other mechanical problem I can recall was when it started
    fading and misfiring on cold damp days after about ten minutes on the
    A14. It had never suffered this before. These days, people would shout
    "carb icing!" but I'd never heard of the condition back then.
    After much head scratching I found that the carb float chamber
    breather was clogged. Once I'd taken it off and cleaned it, the
    problem went away. To this day I don't know whether it was the
    breather itself, or whether in cleaning it out I also cleared
    something else, maybe the main jet feed.
    Oh, yes, just remembered: I *think* I've still got a spare rear wheel
    and possibly a LH engine cover (no alternator, though), if anyone
    wants them.
    Pip Luscher, Feb 19, 2005
  9. dave eades
    Dave Emerson Guest
    You probably had some water in the bottom of the float chamber that was
    freezing in these conditions.
  10. dave eades
    If it was in a position to cause trouble, I'd expect it to be more
    trouble as a liquid because it could then get sucked into the main
    jet. As it was, I don't recall finding any water in the bowl.
  11. dave eades
    Dave Emerson Guest
    Not always obvious, it usually looks like a small orange/brown (rusty)
    maggot swimming around the bottom of the bowl, if you take the time to look.
  12. dave eades
    I know what water in the float bowl looks like.
    Like I said, if there's water in the float bowl then it'll cause
    problems as soon as the petrol starts getting drawn in quantity into
    the main jet, not several miles into the journey, so it's unlikely it
    would've been coming in with the petrol because there would've been
    water contamination from the start of the journey.
    It's highly unlikely it would've got drawn up and in through nearly a
    foot of breather pipe, especially as it was clogged.
    Anyway, the icing effect occurs at the venturi and the emulsion/needle
    jet, not the bottom of the float bowl because:
    a) as the petrol is drawn into droplets, it will evaporate too and
    that will have a major cooling effect;
    b) the venturi's job is to lower the air pressure over the jets. It's
    fundamental to a gas's behaviour that a drop in pressure will result
    in a drop in temperature;
    c) the float bowl gets a continuous supply of fresh petrol at ambient
    or more likely just above ambient due to engine heat/ rider's knees
    warming the tank, so even if there was water in the bowl, I'd be very
    surprised if it managed to freeze. On the occasions it occurred,
    ambient was above freezing.
    HTH.
    Pip Luscher, Feb 20, 2005
  13. dave eades
    Dave Emerson Guest
    Agree with the physics of latent heat of evaporation but I've seen frost on
    the outside of a floatbowl when the ambient was above freezing; particulary
    on my Morini and a friends Ducati 450.
    Any water in the float bowl can freeze to crystals that get drawn into and
    block jets.
    That's as well as any frost that forms directly in the venturi.
    The best fix, on top of cleaning any water from the carb/tank, was an
    additive sold by VW agents for Beetles, as these are alos known to suffer
    from icing.
    Dave Emerson, Feb 20, 2005
  14. It was somewhere around Barstow, on the edge of the desert, when the
    drugs began to take hold. I remember "Dave Emerson"
    Methanol. Cheaper by the drum.
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Feb 20, 2005
  15. dave eades
    dave eades Guest
    Well In reply to all those replies,
    I went and bought it.
    only problem is, there is a lttle bit of sideways movement on the rear
    sprocket (chain seems OK though).
    still, it managed the 60 mile trip home without any clitches,
    I recieved with it quite a bit of history, and it has has regular documented
    oil changes, the last one being about 120 miles ago.
    It is the non-electric start version, and goes first kick.
    seems good for about 70 mph, which is fine for what I want it for (work and
    back, no motorways).
    Overall the condition is good, the only non standard part is a motad 2-1
    exhaust which look fairly recent.
    I also picked up a Haynes BOL with it.
    It has almost 12 months MOT and is Taxed till the end of april, all for the
    princley sum of £275
    thanks for all of the replies
    tomorrow I shall be mainly going to work on a little cb 250 rs
    dave
    dave eades, Feb 20, 2005
  16. dave eades
    dave eades says...
    Good for you. I have shitloads of 250RS spares if you ever need
    anything.
    Lozzo, Feb 20, 2005
  17. dave eades
    WavyDavy Guest
    Try using top... If you have a long enough, straight enough road and are
    mechanically unsympathetic, you can get 'em to nudge an indicated 85+... I
    stress *indicated* however...
    You seen the prices of the std 2 into 2? The motad is a good buy...
    You were ripped off, mate... Lozzo's was *way* cheaper... :)
    Enjoy. They really are *great* bikes and shame the latest 250 jobbies (the
    new CBF250 is 20-odd years newer and less powerful, for a start...)
    But watch out for the chain going notchy and, as soon as it gets a tight
    spot (and it will), replace the bugger 'cos when they snap they can flail
    around a fair bit....
    WavyDavy, Feb 20, 2005
  18. dave eades
    Frost or condensation?
    Why would it get drawn into the jet only as ice crystals and not when
    it was water?
