FOAK: Hard drives
Discussion in 'UK Motorcycles' started by Doki, Oct 9, 2008.
  1. Doki
    Doki Guest
    Requirements are IDE, 3.5", reliable and quiet. Less than 500 gigs. What
    maker's flavour of the month?
    Doki, Oct 9, 2008
  2. Doki
    Greybeard Guest
    Any, bar Hitachi or Samsung.
    I have a cupboard full of said rubbish waiting to be collected for "warranty
    assessment"
    Greybeard
    FLHR -03 UK (95 cu-in Stg 2. Big Boy 2!)
    Garmin Zumo 550, To get me home!
    ukrm@foxtails[dot]co[dot]uk
    Greybeard, Oct 9, 2008
  3. Doki
    ginge Guest
    I've been buying seagate 7200.11's which have a 5 yr warranty, but not
    sure if they do <500GB. Not sure there's much point buying smaller
    either as 500gb is less than 50 quid these days.
    ginge, Oct 9, 2008
  4. Doki
    Buzby Guest
    Greybeard wibbled:
    You can add Maxtor to that list as well.
    Buzby, Oct 9, 2008
  5. Doki
    Derek Turner Guest
    MY mileage varies. Been using Samsung Spinpoint series from 20G IDE
    through to 500G SATA for the last mumble years. Six in all, all still
    working fine. The one disk that wasn't Samsung in that time is the only
    one that broke (WD IIRC).
    Derek Turner, Oct 9, 2008
  6. Doki
    Brownz Guest
    Hmmmm.... two of the most reliable drive mfrs in the market place at
    the moment.
    In the last six months I've had about 60k drives from both Samsung and
    HGST, both are stunningly reliable running at under 0.5% eAFR .
    (Collected from over 800000 part weeks of data).
    You must have the midas touch ;-)
    Brownz, Oct 9, 2008
  7. Doki
    Greybeard Guest
    They must have improved their Quality Control then.
    It's been a while since our company bought any, maybe we'll try them again
    then.
    60K drives is a lot of drives we get through about 500 a month on average,
    most now though are SAS, FC, & a few SATA drives. Very Few failures on new
    ones, HP (are main supplier) never sends "cheap" drives.
    Greybeard
  8. Doki
    Greybeard Guest
    I'm not self employed! nor a consultant, just a mere hardware monkey ;o)
    Greybeard
  9. Doki
    Greybeard Guest
    Most small drives seem to cost a fortune nowadays, by comparison.
    We still have to source <4gb ones on occasions for a particular client! Not
    easy or cheap, by comparison.
    Greybeard
  10. Heh, we can get through 500 a day quite easily with all the lines running !
    Mostly 3.5" SATA and 2.5" SATA (Fuji/Hit/Tosh Mainly) and a smattering of
    SAS for good measure.
    Samsung had a shaky start in the hdd market but seem pretty solid now with
    well robust proucts in the S1 / S2 Drives.
    Hitachi were average when they shook off the ibm stigma but again are solid
    now.
    Brownz \(Mobile\), Oct 9, 2008
  11. Doki
    Greybeard Guest
    Thanks for the info.
    I'll recommend we try them again.
    Since you seem to be gobbling up the world's supply of HDD's single handedly
    <sp> at the moment, it's a recommendation I feel safe with ;o)
    Cheers.
    Greybeard
    Greybeard, Oct 10, 2008
  12. Doki
    Greybeard Guest
    That may be the case.
    But a bad name takes a while to shift, and if I was fitting a bad product to
    your system, you wouldn't be very happy. Things change my friend, and I'm
    open to refreshing my prejudices on sensible advisement.
    Greybeard
  13. Doki
    Dan L Guest
    Heh, best of luck trying to get Samung to accept a warranty return.
    Useless shower of twats
    Dan L
    Too much time to think, too little to do.
    http://thebikeshed.spaces.live.com/
    2002 Triumph Sprint RS 955i (It's big, and it's black)
    1996 Kawasaki ZR1100 Zephyr (Gone, but not forgotten)
    BOTAFOT #140 (KotL 2005/6/7/8)
    X-FOT#000
    DIAABTCOD #26
    BOMB#18 (slow)
    OMF#11
    Dan L, Oct 10, 2008
  14. Doki
    deadmail Guest
    Interesting.
    I've got (at the moment) 8 Samsung spinrites running in various
    machines, including a media centre (with three of the fuckers) that's on
    24/7 and records I would guess in the region of 6 hours of crap a day on
    average.
    I've not heard complaints about the Samsungs before. Would be
    interested if anyone (bar champ who had a DOA) also had problems with
    Samsung drives.
    deadmail, Oct 10, 2008
  15. Doki
    Catman Guest
    Quite the reverse. They were my preferred brand for a while, never saw a
    failure unlike Seagate and Fujitsu. My sample is hardly of a
    statistically valid sample size.
    C
    www.cuore-sportivo.co.uk
    Catman, Oct 10, 2008
  16. Doki
    Greybeard Guest
    Exactly.
    Greybeard
