[FOAK] Hard disk swap-over
Discussion in 'UK Motorcycles' started by HooDooWitch, Apr 1, 2004.
  1. HooDooWitch
    HooDooWitch Guest
    Fount Of All Knowledge.
    I've just had delivered a 120gb hard disk and plan to put in into my
    (old Dell) Win2k server at home.
    My plan of action is:
    1) Slave new disk
    2) Format, partition & copy all files over from existing disk
    3) Remove existing disk & master new disk
    Is it really as simple as that?
    Are there any ovbious pitfalls with this approach?
    Will I get away with pre-partioning or do I have to just leave it as
    one huge bucket and Partition Magic it later?
    Worst case scenario, I'll hoik out the old bugger, and build from
    scratch but I was looking to save a couple of hours.
    All knowledge gratefully rec'd etc.
  2. HooDooWitch
    jeremy Guest
    jeremy, Apr 1, 2004
  3. HooDooWitch
    HooDooWitch Guest
    Pretty much sums up your IT knowledge.
  4. HooDooWitch
    Err, you seem to be missing 'install operating system' from that list.
    Ace, Apr 1, 2004
  5. HooDooWitch
    simonk Guest
    Are you trying to copy the volume that you boot from (i.e. drive C:) to the
    new disk? Cos if you are, you might struggle. Norton Ghost is your friend.
    simonk, Apr 1, 2004
  6. HooDooWitch
    TLSG Guest
    AOL with bells on.
    TLSG, Apr 1, 2004
  7. HooDooWitch
    Catman Guest
    No. You can't copy files that are in use by the OS. As Ace said,
    Ghost is your pal. And I am *heartily* fucking *SICK* of it right now
    Sorry, I'll calm down now
    www.cuore-sportivo.co.uk
    Catman, Apr 1, 2004
  8. HooDooWitch
    TMack Guest
    Yes if you are proposing to to do a fresh install of the OS on the new disk
    first and you simply intend to transfer data files (but see my comment
    further down about potential drive letter problems). However, if you want
    to transfer the entire setup from the old disk to the new disk (and you are
    using win 2000 or winXP) you will need to use partition magic or similar
    software booted from a floppy and copy the old disk (or partition) to the
    new disk. If your new disk is larger than the old you will need to
    subsequently resize the partition or set up a new partition on the remaining
    space on the new disk.
    If your OS is win98 or win95 it is possible to use the dos xcopy command
    (with a whole bunch of switches) to transfer the old disk to the new after
    the new drive has been partitoned. For win 98 I think it is XCOPY C:\*.*
    D:\ /c/h/e/k/r but you would need to check (use google)
    One obvious one, which is easy to overlook, is the need to set the partition
    on the new disk to 'active' (use fdisk) before attempting to boot from it.
    Only one partition can be active at a time so the primary partition on the
    new disk can not be set to 'active' while it is slave to the old disk.
    Also - dont boot into windows 2000 or XP with the new drive as slave as the
    OS will then give it a drive letter other than C: (your old drive will have
    the C: designation) and this will be retained when you boot from the new
    drive - having your boot hard drive as anything other than C: can cause all
    kinds of hassle.
    Unless you have a particular need for more than one partition there is no
    obvious reason to create additional partitions - there is a slight storage
    'overhead' that is incurred with large partitions but storage space is not
    much of a factor these days when the cost per megabyte of storage is so
    cheap
    Assuming that you don't need to rebuild from scratch the only part of the
    process that takes a while is the disk or partition copy process - how long
    depends on the size of the disk/partition being copied.
    NB - if you are using a non windows OS such as linux or OS/2 then you will
    need to ask in a specialist newsgroup such as alt.linux or comp.os.os2.misc
    Tony
    TMack, Apr 1, 2004
  9. HooDooWitch
    TLSG Guest
    Why ? I love Ghost.
    If Ghost does not float your boat have you tried Power Quest Drive Image
    Pro ?
    TLSG, Apr 1, 2004
  10. HooDooWitch
    Ben Blaney Guest
    hth
    Ben Blaney, Apr 1, 2004
  11. HooDooWitch
    Ben Blaney Guest
    I'm guessing that he's been using it a lot recently.
  12. HooDooWitch
    TLSG Guest
    Ah ! Too much of a good thing.
    TLSG, Apr 1, 2004
  13. HooDooWitch
    Catman Guest
    I loved it to
    Nah. I know Ghost. It's only that I've Ghosted 136 machines over the
    last 14 days, and the end users keeps finding things wrong [1] with
    the (12) images
    [1] Defined as 'Thgings we forgot to ask for'
    Catman, Apr 1, 2004
  14. HooDooWitch
    TLSG Guest
    Heh ! Been there done that...
    But the beauty of it is - throw Bootable CD in Drive - reboot- whistle -
    machine imaged, init ?
    I use PQDI over the Lan to image our servers once a month - a citrix
    server farm component takes 20 mins, so that's a 20 total restore.
    All laptops have a std image all on CD. Saves, ooh, hours a week.
    TLSG, Apr 1, 2004
  15. HooDooWitch
    Ben Blaney Guest
    Ha! Fuckers.
  16. HooDooWitch
    HooDooWitch Guest
    Actually, it's dual boot Win2k/Win98.
  17. HooDooWitch
    HooDooWitch Guest
    "TMack" <> somehow managed to post:
    <Loads of good advice snipped>
    Cheers all who replied. I think following the list of pitfalls I'll be
    taking the path of least resistance. ...
    Back up the filestore, slap the new disk in, rebuild from scratch. It
    is currently dual boot (win2k/Win98) and this is a piece of piss to
    sort out later.
    It'll only take a few hours anyway. I was just trying to be lazy.
    Also, I'm a cheapskate bastard and can't be arsed to fork out 60quid
    for a Norton tool I'll only use once.
    Cheers all.
  18. HooDooWitch
    Eddie Guest
    "I can't find Freecell."
    "Why can't I run Solitaire?"
    "Did you install the Internet on here?"
    Etc., etc?
    Eddie, Apr 1, 2004
  19. I use both, and they do the job fine. Use the Disk-Disk copy or 'Clone'
    facility, allowing the partition(s) on the smaller source drive to expand to
    fill the available space on the the new one, if desired. Takes all the pain
    out of replacing (working) hard drives.
    Drive Image now appears to be part of the PQ "Deploy Center" (my copy is
    v5.5).
    Rick
    Richard Sterry, Apr 1, 2004
  20. HooDooWitch
    Catman Guest
    dingly fucking ding
    oh and 'Ahh we need these two apps as well, and that part of Office
    removed'.......
    Catman, Apr 1, 2004
