FOAK: Grease question
Discussion in 'UK Motorcycles' started by Eiron, Dec 24, 2008.
  1. Eiron
    Eiron Guest
    So what's the correct grease for rear suspension linkages?
    They are needle rollers rather than just bushes, if that makes a difference.
    The manual says Suzuki Super Grease A but Halfords don't sell it.
    I've always just used the same stuff for everything but I guess
    that you really should use different stuff for wheel,
    steering head, and suspension bearings.
    Eiron, Dec 24, 2008
  2. Eiron
    MikeH Guest
    Paging BGN
    MikeH, Dec 24, 2008
  3. Eiron
    hah - exactly my thoughts.
    darsy, Dec 24, 2008
  4. I use wheel bearing grease or Castrol bog standard, whichever I find first.
    Don't plaster it on though.
    Mungo \Two Sheds\ Toadfoot, Dec 24, 2008
  5. Eiron
    Use a good Lithium Based Grease like Castrol LM.
    Or Castrol Moly
    Hog, Dec 24, 2008
  6. Bad man.
    The Older Gentleman, Dec 24, 2008
  7. Eiron
    I use this too.
    Lozzo, Dec 24, 2008
  8. Eiron
    Tim Guest
    I misread that as "Molly".
    Tim, Dec 24, 2008
  9. Eiron
    I can't help but think that BGN and Molly might be a match made in heaven.
    Hog, Dec 24, 2008
  10. Eiron
    Eiron Guest
    Are we still in the BGN subthread?
    If not then I guess I'll just use the LM stuff that's in the grease gun.
    On the other hand, a grease gun with its long narrow nozzle might be
    just the thing for BGN.
    Eiron, Dec 24, 2008
  11. White waterproof grease, commonly found in chandlers, is yer maun. At a
    pinch, any straight normal grease will do, but I'd only use it if there
    was provision to lube easily, ie, with a nipple.
    Grimly Curmudgeon, Dec 24, 2008
  12. Eiron
    Eiron Guest
    I don't think so. These are needle rollers with rubber seals and
    supposed to be sealed for life
    so a waterproof grease shouldn't be required. It looks like LM grease is
    right for most things but
    "Comma CV & Lith-Moly Grease 500G is a popular car maintenance grease
    that is
    designed to be used on Constant Velocity Joints & for multipurpose
    greasing."
    would be better for things that only move a bit and carry a heavy load.
    Perhaps I'll go to Halfords and get some white, black, blue and red grease
    so I can always use the wrong one for any job.
    Eiron, Dec 24, 2008
  13. If the rubbers look like they'll stay proper, then ok. Did the old ones
    still have their shape and sealing ability intact? If so, job's a good
    un. I've found that many of these so-called 'sealed for life' designs
    are quite shit, really.
  14. Using the patented Mavis Beacon "Hunt&Peck" Technique, Grimly Curmudgeon
    Rubbish. "Sealed for life" is just that.
    When the seal breaks down, the component's life is over shortly
    thereafter.
    QED.
    Wicked Uncle Nigel, Dec 24, 2008
  15. Eiron
    Eiron Guest
    Haven't taken it apart yet. Just thought I should as I got an advisory
    notice
    at the last MOT for a leaking shock absorber so for the next I need to
    either
    wipe it with a cloth just before the test, or get the shock rebuilt.
    And if the latter, I might as well check the rest of the suspension.
    So who is good for rebuilding shocks?
    Eiron, Dec 24, 2008
  16. Eiron
    MCT in Stowmarket rebuild those that can be stripped, but I'd buy a new
    one from someone like Maxton
    Lozzo, Dec 24, 2008
  17. Eiron
    Eiron Guest
    Thanks for the advice.
    Eiron, Dec 24, 2008
  18. Eiron
    boots Guest
    Considering the state of the axle on a boat trailer I assisted with
    replacing earlier this year I'd concur.
    boots, Dec 25, 2008
  19. Eiron
    Ducati front wheel bearings are particularly shit. Sealed both sides, they
    corrode to shit. Point of Note Ant.
    Hog, Dec 25, 2008
    Dr Ivan D. Reid, Dec 25, 2008
