FOAK:Generating network traffic
Discussion in 'UK Motorcycles' started by Dr Zoidberg, Jul 13, 2004.
  1. Dr Zoidberg
    Dr Zoidberg Guest
    Does anyone have any suggestions for software that can run on a server to
    generate network traffic to simulate a large load on switches and routers
    under test.
    Its easy enough to do this for a short period by moving files around etc but
    we could do with something that can run continually without attention.
    Alex
    "I laugh in the face of danger"
    "Then I hide until it goes away"
    www.drzoidberg.co.uk
    www.upce.org.uk
  2. Dr Zoidberg
    Eddie Guest
    What OS?
    For Windows, something like "ping -t -l 8192" should get things warmed
    up; for *nix-like systems, the equivalent would be "ping -s 8192".
    HTH, and don't forget to RTFM.
    Eddie, Jul 13, 2004
  3. Dr Zoidberg
    Dr Zoidberg Guest
    2k or 2k3
    Constant pings are ok for testing connectivity , but we could do with a lot
    more load to stress the switches a bit.
    Alex
    www.upce.org.uk
  4. Dr Zoidberg
    Dr Zoidberg Guest
    Hehehe , nice idea ,but the switches will be on a separate network for
    testing purposes.
    I know there is software that you can buy to generate simulated traffic ,
    but a free solution would be better.
    At the mo I think a batch file to copy a bunch of files from one machine to
    another then delete them and start again is looking likely
    Alex
    www.upce.org.uk
  5. Dr Zoidberg
    Dr Zoidberg wrote in
    I've sent you an email. Forward it to everyone on the network and make sure
    they run the attachment. That should do it.
    wessie, Jul 13, 2004
  6. Dr Zoidberg
    Eddie Guest
    Wack up the packet size, and run a load of them in parallel?
    Eddie, Jul 13, 2004
  7. Dr Zoidberg
    Eddie Guest
    :begin
    xcopy //servername/rootshare /e /q /h /y
    goto begin
    .... in a batch file should keep it busy for a while, *and* saves having
    to delete the files each time.
    Eddie, Jul 13, 2004
  8. Dr Zoidberg
    Dr Zoidberg Guest
    Ta.
    Alex
    www.upce.org.uk
  9. Dr Zoidberg
    antonye Guest
    Microsoft NetMon I think it was called. Comes as standard
    with something like Exchange, purely for that purpose.
    I'll have to go back through some old course notes if
    it's not right, but that sounds familiar.
    antonye, Jul 13, 2004
  10. Dr Zoidberg
    Greybeard Guest
    Batch file looping, copy large files backward and forward.
    No special software needed.
    Greybeard, Jul 15, 2004
  11. Dr Zoidberg
    and using something like ab to stress a web server across the link.
    Muck, Jul 15, 2004
